All,
I have configured a fibaro motion sensor and a z-wave alarm on my home center lite.
I would like to be able to start a scene (e.g. when leaving the house) to turn the alarm on (manually).
I've configured the following scene (see below), but when I run it, it immediately triggers the alarm, without any movements detected by the motion sensor.
I've already tried to change parameter 1 of my motion sensor (sensitivity) but when I save it always returns to default state.
Scene (also attached)
Motion sensor    ==
Breached and armed   (no green time)   (0 s in red delay box)
Then
Alarm = Turn on  (no green time)   (0 s in red delay box)
I've tried with delays on both the motion sensor and the alarm but no luck.
What I do to activate the scene: arm the motion sensor and then hit RUN on the scene -> this immediately triggers the alarm, without motion of the motion sensor.
When I activate the scene even without the motion sensor being armed, it triggers right away (without any motion).
Furthermore the motion sensor works pretty fine... .
Anyone experience with this or any other way of configuring an alarm with manual triggering?
Tx.
Run bypasses conditions of block scene by default. If you want to test block scenes, replicate conditions in which it is expected to work.
    Admin,
    Thank you for the answer - if "Run" bypasses the conditions by default - how do I start a scene manually without it bypassing the conditions?
    Thank you,
    Christoph
    I've deleted the scene, if I arm the motion sensor and pass by it, the internal Fibaro alarm goes off, but my physical alarm (z-wave) is not connected yet and doesn't respond.
    How do I connect my alarm to the motion sensor being breached?
    I've tried to add it in the alarm panel, but no luck.
    Any ideas?
    Thank you,
    Christoph
