I do not know if somebody posted it here.
Fibaro, can you add label from virtual device to a condition into block scenes? It could save us many trouble with compare some desired values with label in VDs. I know, i can make it into Global variables, but they are unreliable (mine opinion only), because i think parameter "invokeScenes" is set to false by default. Many times happened to me that scene did not run, even if Global variable had desired value.
