Is there a way to associate a RGBW controller (FGRGB-101) as a master, with a Dimmer 2 module (FGD-212) as a slave, either as a Z-Wave direct association or with a LUA script on the main controller?
My goal is to dim LEDs connected to 110-240V AC, with a distant low voltage RGBW module. LEDs are connected to a Dimmer 2 module. 30 feet away, a 12V DC RGBW controller interprets the variable output of an analog sensor. I'd like to dim the distant LEDs accordingly to the level the RGBW module would set if it was directly connected to equivalent 12V DC LEDs. In other words, can the dimming level information of an RGBW controller be passed to a Dimmer 2?
flux_capacitor 1
I know that two RGBW modules can be synchronised, but I don't know if an RGBW module and a Dimmer 2 module can be synchronised.
Link to post
