Main scene FTBE v 1.3.4
Hello everyone!
NEW version is OUT!
More about scene and download you can find here:
WHAT'S NEW:
  • Main scene FTBE 1.3.4 - changed function for time of day calculation and added use of SleepState global to set time of day to morning when Awake  regardless of current time
  • Main scene FTBE 1.3.0 - cleaned some bugs, added some more checks to prevent scene from stop running due to errors. Optimized and compacted code, removed unnecessary comments. DemoMode only stops changing timers while user code and scheduled events will continue to execute. Darkness can now be changed by measured lux level or global variable that is set to lux value measured by light measuring devices placed outside. Scene is now running on setTimeout function instead on sleep for better timing and also aligns to 0 seconds or exact minute.
  • Sunrise & Sunset VD v1.4.0 - Modified main loop code to better handle global variables. Variables are now automatically repaired and are not reset to default settings after HC2 reboot. Added variable SunriseIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically.
  • Home Status VD v1.1 - Added variable HomeStatIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
  • Home Timers VD v1.1 - Added variable HomeTimersIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
NOTE - This version is compatible with previous versions so need to do any changes in your current code of other scenes and VD's.
REQUEST - If you like my work and found it useful please give me support by rating and writing short review. Thank you! :-)
PS
Dear friends from Slovakia you can find this scene and VD translated to your language here:
Edited by Sankotronic
Updated to new version
  • Like 16
  • Thanks 6
On 8/1/2018 at 12:56 PM, Sankotronic said:
Maybe there are users or admins that know more about [ error] API: Host not found (authoritative) ??
Today:
Same error message here.
Installed a brand new HC2 with software 4.510, with no devices yet, just two scenes "Sunrise & Sunset v1.3" and "Main scene for time based events control v1.2.5".
When I start the scene everything looks good, but after some hours running good it stop/crashes with error:
/monthly_2018_08/MSFTBEC.PNG.e857b2e1fd19cfcba01ff078125e90b7.PNG" alt="MSFTBEC.PNG.e857b2e1fd19cfcba01ff078125e90b7.PNG" />
When I click on "start" button the scene start running again, but after some random time it stops again.
tried it three times, first time it was running for hours before it crashed, second time it stopped after some minutes, third time it was running good for hours until it crashed again.
I have the same. Scene stops.
I`m wondering if adding code like:
local mainLoopSceneID = XX
fibaro:startScene(mainLoopSceneID);
Added to reaction on one of motion sensors will help. Assuming this motion sensor is breached few times per hour it can be good "starter" just in case MainLoop fails.
I`m not expecting Fibaro to resovle this issue too fast :)
    Hi @drivex@Remi@domin12@Bezan ,
    Sorry for late answer but I was not at home for last five weeks. Since I don't have such problems on my HC2 with latest firmware can you please send me complete scene code as plain text document to private message so I can analyze and find out what is causing this errors?
    Thank you!
    3
    unplug jack RJ45 from WAN (!) interface where your ISP live :) just un-plug... and you will see....
    Edited by 10der
    Hello Sankotronic, in the introduction you describe a variable called "HolidayTime".
    Am I correct in assuming that you are using this variable but nowhere?
    Geetings and thanks for the answer
    thats true, when there is no WAN connection, script die
    I have tested Main scene FTBE and found following:
    If network cable is disconnected from HC2 or network connection is lost then in some cases all functions that depend on API Local Host calls fail. I'm not expert but I thought that all calls to API through local host (127.0.0.1) don't need network connection since those calls are local on the device check:
    For some reason HC2 local host calls sometimes don't work when network connection is lost. Or these call are then not done through local host? I tested the way I disconnected HC2 network cable from my network switch. With one of the cable disconnections I get this in debug window:
    /monthly_2018_09/207776950_APIHostnotfound.jpg.434cf6d16585e8b0d5b5643810878de9.jpg" alt="207776950_APIHostnotfound.jpg.434cf6d16585e8b0d5b5643810878de9.jpg" />
    I added some more debug lines just to better understand where is actual problem.
    So after debug line "Get actual time" there are two calls to get sunrise and sunset times and those fail. After that All functions that are getting values from global variable fails so ultimately function that calculate times fail since it can't calculate with NIL values.
    Interestingly this doesn't happen every time when network connection is lost and I did try to disconnect network cable several times and keep it disconnected for different time length.
    SOLUTION
    I'm really tired to change every bit of my code every time when Fibaro developer team introduce new bugs or "features" in their software. I have to do that every time when new "stable" firmware is released. I'm working on new solution anyway, but it is difficult to say when I will publish it due to the situation with new releases.
    It might be difficult to work around this. You can try to make it go into a "retry loop" so it continues when that error disappears.
    This error was mentioned a few times but unfortunately there are two "errors" which sound very similar and this causes confusion. Let me try to explain
    1) API: Not found - this one is *probably* quite harmless because code continues to run. It happens, for instance, if your script uses a non-existent global variable.
    2) API: Host not found (authoritative) - this one means name resolution failed. It is quite bad, because it crashes code if your code does not expect "nil".
    The bug exists on HC FW between 4.500 and FW 4.510 (the one available at the time of this post).
    Issue it was discussed here.
    I agree with @tinman's diagnosis and I can reproduce the issue (on one of my scenes, not @Sankotronic's scene, but that is not important):
    My scene crashes at line 106, because fibaro:getValue(10, 'value') returns nil, which is unexpected. You could argue, we should always check if this code returns nil but (1) it actually never happens as long as device 10 exists (on pre 4.5XX firmware) (2) I see no reason why the scene should depend on the availability of the LAN connection.
    Similar cases:
    TIP: Search for the word "authoritative" in the error message, to distinguish it from the totally different "API: Not found" error (which is less harmful).
    /monthly_2018_09/image.png.8d9f98d4c69ec742b4f3fdd80a7c3572.png" />
    Can someone please help me, my changes to "MarginBlinds", "MarginDay" and "MarginNight" always gets back to default after restarting the HC2, my question is how I can keep my changes permanent, I want the figures to be like this:
    Thanks in advance
    Edited by JEAU
    Hi @JEAU ,
    Whenever Sunrise & Sunset VD main loop is restarted it resets margin times to default. If you often reboot HC2 then you can change this defaults in main loop code.
    Open VD for editing and scroll in main loop code to line 146. You will see this code:
    Now you can enter your default settings and Save.
    4 hours ago, Sankotronic said:
    Hi @JEAU ,
    Hi Sankotronic,
    You are great thank you very much, that worked
    I have used this now for a while and runs great but now after a restart of the controler I get the following error:
    [DEBUG] 22:07:45: [1;31m2010-01-03 22:07:45.708449{fatal] Unknown exception:
    /opt/fibaro/scenes/20.lua:454: attempt to perform arithmetic on local 'diffMinute'(a nil value).
    Why is this happening, now all my automated scripts won't run correctly no more.
    Idem
    Looks like I have found out what the problem is.
    After a Power failure I had to restart/reset the HC2 controler and because of this the configuartion of "Set Date and Time" was set to manual.
    After setting this to "Download time from the Internet" everything working normally, even possible to make "Cloud backups" again and see which backup are there already.
    Everything for me is running smothely again.
    Sorry just checked again after making the changes yesterday and it ran fine.
    At the moment again get the same error.
    Sorry folks.
    Al the other is fine but all scripts depending on mainscene are not running fine because of this issue.
    Guest andyhud
    Sorry folks.
    I'm having the exact same problem.. changed my Set Date and Time back to "download from internet" and now my HC2 is rebooting, but its been "rebooting" now for 10 minutes or so! Its not going back to login prompt!
    Have you refreshed your browser?
    Guest andyhud
    Yes, I did everything and it didnt come back. I ended up pulling the power from HC2 and now its back and running again and the new "Download time from internet" seems to be working". The Scene now runs but I get a new error
    "[ error] API: Not Found"
