Main scene FTBE v 1.3.4
Hello everyone!
NEW version is OUT!
More about scene and download you can find here:
WHAT'S NEW:
  • Main scene FTBE 1.3.4 - changed function for time of day calculation and added use of SleepState global to set time of day to morning when Awake  regardless of current time
  • Main scene FTBE 1.3.0 - cleaned some bugs, added some more checks to prevent scene from stop running due to errors. Optimized and compacted code, removed unnecessary comments. DemoMode only stops changing timers while user code and scheduled events will continue to execute. Darkness can now be changed by measured lux level or global variable that is set to lux value measured by light measuring devices placed outside. Scene is now running on setTimeout function instead on sleep for better timing and also aligns to 0 seconds or exact minute.
  • Sunrise & Sunset VD v1.4.0 - Modified main loop code to better handle global variables. Variables are now automatically repaired and are not reset to default settings after HC2 reboot. Added variable SunriseIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically.
  • Home Status VD v1.1 - Added variable HomeStatIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
  • Home Timers VD v1.1 - Added variable HomeTimersIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
NOTE - This version is compatible with previous versions so need to do any changes in your current code of other scenes and VD's.
REQUEST - If you like my work and found it useful please give me support by rating and writing short review. Thank you! :-)
PS
Dear friends from Slovakia you can find this scene and VD translated to your language here:
Edited by Sankotronic
Updated to new version
  • Like 16
  • Thanks 6
Hi @Sankotronic
FTBE scene (scheduled global variable) is not updating sunset time. Nevertheless the log contains the correct sunset time, the trigger time is wrong.
After stop and start of the scene (and / or reboot of the HC2) the sunset time is correct again.
Initiallity, I thought I made too many changes to the scene so I deleted the scene and created a new one. This is not solving the problem. Any idea what can be wrong?
Triggered scene. Sunset time is the time from a few days ago.
Hi @Sankotronic
i need your help, i already spent few hours trying to solve what is going on, but have no idea what is happening..  so, i do have a button in kitchen that changes global variable CookingState value so the light will be turned on when cooking.. so i set up your scene as follows:
local cookingState        = "CookingState"
local cookingStateMapping = {Yes="Yes", No="No"}
local useCookingState     = "Yes"
local dimRGBCooking   = {100}
extraGlobalName       = {"CookingState", "CinemaState"}
extraGlobalValue      = {"Yes", "Yes"}
So once the CookingState is set to Yes the light should be always on at 100, right? but when i change the CookingState by button lights does not turn on... this happens in the debug:
/monthly_2019_04/image.png.dd889952f050641ef06e2ef4bc809f19.png" />
once motion is detected, light is turned on with cooking level etc.
when i turn the CookingState to No, light changes to Day time, turns off etc. so everything good.
the only thing i am not able to figure out, why the light does not turn on when the CookingState is Yes without motion. and the same happens if my current lux is higher then luxMin, light does not turn on. Shouldn't the CookingState value force the light to turn on? thanks for help
EIDT: i am sorry this post is here in topic for main scene FTBE, i am not sure why i was redirected here when i click on support for Very smart light scene :(
Edited by tomasko
@Sankotronic
How can I swap the two Icons for "Sunrise is at" and "Day starts at" in the "Sunrise & Set VD"?
In my VD (and the picture from Andyhud) the clock symbol is next to the "Sunrise is at", and sun at "day start at".
Br,
Frank
Guest andyhud
Question:
When we are using the Main FTBE Timer to trigger a "scene", obviously by default the scene itself needs a trigger, but in this case, we want the scene to "just run" when the Main FTBE triggers it.
To do this, I'm just setting a trigger in a scene to look like below (simple Block scene as an example) where I'm saying this scene can run any day of the week at any time. However the scene itself is set to "manual" so it doesnt run by itself, just runs when the Main FTBE triggers it.
Is this the right approach?
Andy
    Hi @wpeeters,
    Sunrise and sunset times FTBE gets from HC2 location settings so if not correct then you should check your HC2 location settings.
    If sunrise and sunset trigger times are not correct then you should check your settings in Sunrise & Sunset VD and compare them since FTBE uses those settings from VD.
    I can't give you any further help if you changed FTBE scene code since I don't know what changes did you make. I can help only if we are talking about original FTBE scene code.
    Hi @tomasko,
    You question is related to VSL scene and not FTBE scene so please can you ask your question in proper thread. This can be a bit confusing for other users. THANK YOU!
    @Frasev,
    Yes of course you can change icons on VD to your liking.
    34 minutes ago, Sankotronic said:
    @Frasev,
    @Sankotronic,
    I'm sorry, my question were unclear. How can I change it?
    Br,
    Frank
    17 minutes ago, Frasev said:
    @Sankotronic,
    Br,
    Frank
    And it is still unclear on what icons do you refer? Maybe a screenshot will make it easier for me to give proper answer.
    Its a minor detail, but I like things correct, neat and clean (my wife even more ;) )
    Edited by Frasev
    To change the icons, you need to edit the main loop. In my set-up the values are around line 203.
    In your script, there are probably decimalvalues? for the icons, but you can write emojis directly.
    Regarding the order of icons, I have also changed the set-up. In my opinion the intention with the setup is to display a wake-up time for the house and then the sunrise-time. I do not use the wake-up time myself and therefore I sort of agree with you, even if the intention of the maker makes the display order correct.
    ...had to remove the emojis before posting here (symbol)
    My version: approx line 203 in the main loop
       logbug(evc,string.format(rgv,marginBlindsName))end
                                --MAIN LABEL
        hc:call(selfId,"setProperty","ui.Label1.value",'symbol'..sunrisetime..'symbol'..sunrise.. --hc:getGlobalValue(dayTimeName)
          'symbol'..sunset..'symbol'..sunsettime)--hc:getGlobalValue(nightTimeName))
        hc:call(selfId,"setProperty","ui.lblMarginBlinds.value",hc:getGlobalValue(marginBlindsName))
    You see that first time is not really time of the sunrise but it is time when morning will start. In your case since difference is 0 min it happens that morning starts at same time of sunrise.
    So for you morning starts at the same time when sunrise is. Also, you set that day starts 45 minutes after morning starts so day starts at 6:24, so that is not time for morning but for day and sun represents that correctly.
    You have a bit mixed up times so you are thinking that icons are set incorrect, but actually icons are correct, only your times are a bit strange for when day starts. Usually morning last a bit longer than 45 minutes, but then again it is entirely up to you when you want to start morning, day, evening and night.
    Just to make it clear, sunrise and sunset times are not shown on that label, but times when morning, day, evening and night starts.
    Ahaa!!! :)
    Now it makes sence. I have read this before, somewere, but finally understood now!
    Thank you for all the great work, and taking the time to reply a newb :)
    22 hours ago, Sankotronic said:
    Hi @wpeeters,
    @Sankotronic
    hi, the problem is that all settings are correct. Sunset time is correctly set and visible in VD, debug of FTBE scene and in global variable section.
    Sorry for the confusion but FTBE is original scene. I only changed the user part.
    So everything seems to be ok. Except not the trigger. FTBE scene is triggering the global always on the initial time of the first run of the scene (after reboot or manually stop and start).
    On 4/30/2019 at 9:09 AM, Sankotronic said:
    Hi @wpeeters,
    @Sankotronic
    I did another test and the result is confirming my thought something might be wrong with 'SCHEDULED GLOBAL VARIABLE CHANGE SETUP' in relation with sunsettime.
    Offcourse, it's still possible I'm doing something wrong but everything is working and no errors appear.
    Just to summarize :
    - log of FTBE is showing correct sunsettime
    - VD Sunrise & set (version 1.4.0) is showing correct sunsettime
    - no errors in VD neither scene
    - no changes made in code (only in user part)
    I'm triggering my scene now by both 'SCHEDULED GLOBAL VARIABLE CHANGE SETUP' and 'SCHEDULED SCENES SETUP'.
    In the log of my scene you can see that the scene is triggered at two different times.
    At correct sunsettime by FTBE 'SCHEDULED SCENES SETUP' ==> type is 'other source'
    At old sunsettime by  'SCHEDULED GLOBAL VARIABLE CHANGE SETUP' ==> type is 'global variable'
    My log file :
    Hi @wpeeters ,
    for scheduled scene setup since you are using local variable sunsettime then you must add this line:
    in function function extraUserCodeFirst() so that local variable is updated.
    Same is for scheduled global variable. You have to add this line:
    in function  extraUserCodeFirst() so that local variable is updated.
    hi @Sankotronic,
    Thanks. I'll test it asap. I noticed this missing part in scheduled global variable.
    Maybe add it to documentation as well?
    Hi @wpeeters
    This is how I did it for some roller shutters. Maybe this example can help you.
    SCHEDULED DEVICE SETUP
    -- Available commands: "turnOn", "turnOff", "open", "close", XX where
    -- XX is numerical value or level which for example turns on or dim dimmer
    -- at that level (0 to 100)
    local run_device_sched={
      {_id=168,command={"open"},hour={"08:50"},week={1,0,0,0,0,0,1},_global="",_value=""},
      {_id=168,command={"open"},hour={"07:30"},week={0,1,1,1,1,1,0},_global="",_value=""},
      {_id=168,command={"close"},hour={sunset},week={1,1,1,1,1,1,1},_global="",_value=""},
      {_id=171,command={"open"},hour={"08:51"},week={1,0,0,0,0,0,1},_global="",_value=""},
      {_id=171,command={"open"},hour={"07:30"},week={0,1,1,1,1,1,0},_global="",_value=""},
      {_id=171,command={"close"},hour={sunset},week={1,1,1,1,1,1,1},_global="",_value=""},
      {_id=175,command={"open"},hour={"08:51"},week={1,0,0,0,0,0,1},_global="",_value=""},
      {_id=175,command={"open"},hour={"07:30"},week={0,1,1,1,1,1,0},_global="",_value=""},
      {_id=175,command={"close"},hour={sunset},week={1,1,1,1,1,1,1},_global="",_value=""},
    -- DEVICES CONTROL BY TIMER OR SENSOR/GLOBAL VALUE CHANGE
    local device_control={
      {_id=0,command="",vditem={""},value="",delay_min="",color={r_bri="",g_hue="",b_sat="",w_ct=""},sensor={_id=0,value="",compare="<="},global={name="",value="",compare="="},flag=false},
    -- EXTRA FUNCTION WHERE YOU CAN ADD YOUR CODE
    -- use this function to add code that will be executed before all other
    -- code in the loop
      run_device_sched[3].hour[1] = sunset
      run_device_sched[6].hour[1] = sunset
      run_device_sched[9].hour[1] = sunset
    Edited by Sjekke
    Hi @Sjekke ,
    Example that you provided is from UHAS compatible FTBE scene which is much more advanced than current version of FTBE scene standalone version.
    I just have to point that out to avoid confusion. :-)
    Just now, Sankotronic said:
    Hi @Sjekke ,
    Oh sorry ... my mistake ... I was to fast. (When I see the name @Sankotronic I automatically think UHAS ;D)
    @Sjekke thanks anyway. But I can confirm it is working now.
