AutoFrank 372
Hi Everyone
v 2.6 now available for users that have the SMsgH installed
Three offerings - Please read below to see which is right for you
1) WWWAPI Monitor {v1.0} - New (Mar8th) - vd that monitors only availability of the internet with option for sonos-api device. (leverages
{v1.0}2) Network Device Monitor VD {v2.5} - vd that can monitor several + devices and has built-in alert notification options (pushover/pc2popup/hc2email/allinone)
or
3) Network Device Monitor VD {v2.6} - vd that can monitor several + devices and deigned to be used with the recently released
{v1.0}Regards
[Autofrank]
LAN Monitor / Network Device Monitor {v2.6} ------ to be used with Smart Message Hub {v 1.0}
Modified to to be used with Smart Message Hub
- Label check removed to simplify virtual device
4 simple steps to upgrade from v2.5 to v2.6
LAN Monitor / Network Device Monitor {v2.5} ------ has built in Notification Services
The main difference between 2.0 and 2.5 are the following
The following features are still available
I use this to monitor Internet, Unifi Security Gateway, HC2, Sonos API (pi), TV's, Sat Box, Apple TV, Droid Box, Alarm Panel, Alarm Gateway, Syn NAS Global cache device, Cameras, Tablets, Sonos players, Access points and phones. Alerts setup for Internet, USG, Sonos API, Access points, cameras, Sonos players, Alarm panel, alarm gateway and NAS. There are some nuances with some devices such as TV's and Phones.
Open Ports of some devices that were shared by users
== INSTALLATION: Upgrading from 2.0 ==
- Import the LAN Monitor 2.5 VD and copy in device table from Update Network Table 2.0
- Run VD with updateData = "true" to update the Network table (default setting is false)
- Run VD with updateData = "false" to operate in normal mode
- Update notification and frequency of update options
== INSTALLATION: First Time Users ==
STEP 1 - Import the LAN Monitor 2.5 virtual device
- Populate the device table. Device, ip, port and enter alert = "1" for device notification
- alert is user configurible per device
- alert = 1 (enable alerts - alerts sent if it goes offline or comes back online )
- alert = 0 (disable alerts for this device)
- Select the notification options
- Run VD with updateData = "true" to populate the device table
Step 2 (optional) - create labels to display device status in VD
- Create one label for each device in the global variable table, use the default ID - Label1, Label2, etc.
- Enter Label Names (1, 2, 3, etc) to match order order of devices in Table (devices can be skipped but ID's must match)
- Select Main label to display one device when observing through Web UI
- If you want to use all labels you can use Set vdCheck = "true" to confirm correct quantity and format of labels.
== FILES ==
Use the version if you don't have Smart Message Hub installed
>> Network device Monitor VD {v2.5} ------------>
Use this version if you HAVE Smart Message Hub installed
>> Network Device Monitor VD {v 2.6} ----------->
Thanks to @jompa68 , @petergebruers , @sonnyboy and @boerremk for their input
Regards
-f
Edited by AutoFrankTop Posters For This Question
46
9
7
5
Jun 16
10
Apr 16
10
Mar 3
8
Feb 24
8
AutoFrank 46 posts
samuel 9 posts
Orgli 7 posts
FSE 5 posts
Jun 16 2017
Apr 16 2017
Mar 3 2017
Feb 24 2017
AutoFrank
Hi Everyone v 2.6 now available for users that have the SMsgH installed Three offerings - Please read below to see which is right for you 1) WWWAPI Monitor {v1.0} - New (M
AutoFrank
Released Network Monitor 2.5 Virtual Device ONLY - ( no need for separate scene, table updates are now done through VD) Global variable table is created automatically created for new users
Sankotronic
Hi @AutoFrank, Great VD!! Just installed and working fine! I added following devices and all working (tested): - Smarter coffee maker (port 2081) - Smarter iKittle (port 2
119 answers to this question
