Hi Everyone
v 2.6 now available for users that have the SMsgH installed
Three offerings - Please read below to see which is right for you
1) WWWAPI Monitor {v1.0} - New (Mar8th) - vd that monitors only availability of the internet with option for sonos-api device. (leverages
 {v1.0}
2) Network Device Monitor VD {v2.5} - vd that can monitor several + devices and has built-in alert notification options (pushover/pc2popup/hc2email/allinone)
         or
3) Network Device Monitor VD {v2.6}  - vd that can monitor several + devices and deigned to be used with the recently released
 {v1.0}
Regards
[Autofrank]
LAN Monitor / Network Device  Monitor {v2.6} ------ to be used with Smart Message Hub {v 1.0}
Modified to to be used with Smart Message Hub
- Label check removed to simplify virtual device
4 simple steps to upgrade from v2.5 to v2.6
  1. Import the new virtual device
  2. Configure your SendMsg preferences
  3. Copy your v2.5 jsonNetwork table to v 2.6 and set UpdateData to 'true'
  4. Set UpdateData to 'false' and that's it !!
LAN Monitor / Network Device  Monitor {v2.5} ------ has built in Notification Services
The main difference between 2.0 and 2.5 are the following
  • Virtual Device ONLY - ( no need for separate scene, table updates are now done through VD)
  • Global variable table is created automatically created for new users
  • Added HC2 Popup service as an extra notification option
The following features are still available
  • Individual LAN devices can be marked for Alert
  • Alert Notification options configurable for HC2 email (default), pushover, or ALLINONE (@jompa68)
  • One Alert will be received when device goes offline and another when it comes back online
  • Online/Offline status is captured in global table that can be used to trigger other events
  • Debug routine called vdCheck will verify that correct quantity of vd labels and format was setup
  • Status/Error/Check feedback through the virtual device log console as visible through the Web UI
I use this to monitor Internet, Unifi Security Gateway, HC2, Sonos API (pi), TV's, Sat Box, Apple TV, Droid Box, Alarm Panel, Alarm Gateway, Syn NAS Global cache device, Cameras, Tablets, Sonos players, Access points and phones. Alerts setup for Internet, USG, Sonos API, Access points, cameras, Sonos players, Alarm panel, alarm gateway and NAS. There are some nuances with some devices such as TV's and Phones.
Open Ports of some devices that were shared by users
  • Internet google (port 80)
  • Sonos players/zone (port 1400)
  • Sonos API (port 5005 or 5006)
  • Raspberry Pi Hosting API (port 22)
  • iPhone Port (port 62078)
  • Smarter coffee maker (port 2081)
  • Smarter iKittle (port 2081)
  • Philips TV 47PFL5000 (port 1925)
  • Foscam cameras (port 88)
  • NAS Netgear U6 (port 80)
  • Global cache GC100-12 (port 21)
  • Humax FoxSat satellite receiver(port 80)
  • Apple TV Gen 3 (port 5000)
  • NPET MXQ Pro TV Box - Android 5.1 (port 7002)
  • Sony TV’s (port 80)
  • Samsung TV (port 8080)
  • Synology NAs DS415Play (port 80)
  • SPC Gateway (port 80)
  • Siemens Alarm Panel (port 443)
  • HKVision IP Camera (port 80)
  • Unifi security Gateway (port 80)
  • Unifi UniFi AC LR Access Point (port 22)
  • Samsung Galaxy S6 / S7 (port 5060)
  • Samsung Tablet (port 5060)
  • Generic Android Tablets (port 5060)
  • Airport Express and Airport Extreme (port 5009)
  • Amazon Echo Dot and Fullsize Echo (port 4070)
== INSTALLATION: Upgrading from 2.0 ==
    - Import the LAN Monitor 2.5 VD and copy in device table from Update Network Table 2.0
    - Run VD with updateData  = "true" to update the Network table (default setting is false)
    - Run VD with updateData  = "false" to operate in normal mode
    - Update notification and frequency of update options
== INSTALLATION: First Time Users ==
STEP 1  - Import the LAN Monitor 2.5 virtual device
        - Populate the device table. Device, ip, port and enter alert = "1" for device notification
               - alert is user configurible per device
               - alert = 1 (enable alerts - alerts sent if it goes offline or comes back online )
               - alert = 0 (disable alerts for this device)
        - Select the notification options
        - Run VD with updateData  = "true" to populate the device table
Step 2 (optional) - create labels to display device status in VD
        - Create one label for each device in the global variable table, use the default ID - Label1, Label2, etc.
        - Enter Label Names (1, 2, 3, etc) to match order order of devices in Table (devices can be skipped but ID's must match)
        - Select Main  label to display one device when observing through Web UI
        - If you want to use all labels you can use Set vdCheck = "true" to confirm correct quantity and format of labels.
== FILES ==
Use the version if you don't have Smart Message Hub installed
>> Network device Monitor VD {v2.5} ------------>
Use this version if you HAVE Smart Message Hub installed
>> Network Device Monitor VD {v 2.6} ----------->
Thanks to @jompa68 , @petergebruers , @sonnyboy and @boerremk for their input
Regards
-f
Edited by AutoFrank
@Bodyart I will try! the basic change is I put most of the main program under function so it runs according to _maxRetryProcess variable
Here is the code with colors
-- Local variable declaration
thisId            = fibaro:getSelfId();
-- ** USER CONFIGUATION - NOTIFICATION & UPDATE OPTIONS **
local updateFreq  = "3000"      -- Set the frequency (milliseconds) that you want to vd to poll the LAN per device
local updateData  = "false"     -- Set to true to update the data in the table. ** SET BACK TO FALSE ONCE COMPLETE **
local _maxRetryProcess = 5         --how many times will rerty
local _setReadTimeout = 250     --Timeout time for socket
local SMsgHID = 66
-- ** USER CONFIGUATION - NETWORK TABLE DEVICES **
function popTable()
  jsonNetwork = {
    {device = "Internet",            ip="8.8.8.8",     port="53",        online = "0", alert = "1", alertTrack = "0"},
    {device = "Google Home",           ip="192.168.15.28",        port="8008",    online = "0", alert = "1", alertTrack = "0"}
  local jNetTable = json.encode(jsonNetwork)
  fibaro:setGlobal("NetworkTable", jNetTable)
  local jN = json.decode(fibaro:getGlobalValue("NetworkTable"))
  if jN[1].device == "" then
    fibaro:debug("Network table did NOT get created successfully. Please debug")
  else
    fibaro:debug("Network table successfully updated")
  fibaro:debug("The following devices have been setup for alerts:")
  for i = 1, #jN do
    if jN.alert == "1" then
      fibaro:debug(jN.device)
function SendMsg(mstr, mtarget, mvol, mtitle, msubtitle)
  local msgStr = { message= mstr, target = mtarget, volume = mvol, title = mtitle, subtitle = subtitle }
  fibaro:setGlobal("messageHub", json.encode(msgStr))
  fibaro:startScene(SMsgHID, {json.encode(msgStr)})
function updateTable()
  if fibaro:getGlobalValue("NetworkTable") == nil then
    local HC2 = Net.FHttp("127.0.0.1",11111);
    local response ,status, err = HC2:POST('/api/globalVariables','{"name":"NetworkTable","value":""}');
    if (tonumber(status) == 200 and tonumber(err)==0) then
      fibaro:log("Global variable NetworkTable created");
  else
  popTable()
local function _ping(retry, devid)
retry = retry or 1; -- rerty initialise/count
  devid = devid or 1 -- keep jN.device
    fibaro:debug("Network Table not populated")
  else
    for i = devid, #jN do
      tcpSocket         = Net.FTcpSocket(jN.ip, jN.port)
      tcpSocket:setReadTimeout(_setReadTimeout);
      bytes, errorCode  = tcpSocket:write("test")
      tcpSocket:disconnect()
      if errorCode == 0 then
        jN.online = 1
        fibaro:call(thisId, "setProperty", "ui.Label"..i..".value","Online")
        if jN.alert == "1" and jN.alertTrack == "1" then
          message = ("Notify Alert! "..jN.device.." is back online")
      -- Configure your Send Message Parameters as you require
          SendMsg(message)
          jN.alertTrack = "0"
      else
        fibaro:debug(""..jN.device.." seems disconnected")
        if retry < _maxRetryProcess then
        fibaro:log("Retry process...")
        fibaro:sleep(1000 * retry) -- increase time between retries
        return _ping(retry + 1, i)
        else
        jN.online = 0
        fibaro:call(thisId, "setProperty", "ui.Label"..i..".value","*OFFLINE*")
        if jN.alert == "1" and jN.alertTrack == "0" then
          fibaro:log(""..jN.device.." is offline")
          message = ("️Notify Alert! "..jN.device.." is offline")
         SendMsg(message)
          jN.alertTrack = "1"
      jNetTable = json.encode(jN)
      fibaro:sleep(updateFreq)
-- MAIN CODE
if updateData == "true" then
  updateTable()
  return
else
_ping()
Edited by korniza
Thank you @korniza,
that makes it readable and understandable much more faster :-)
Efcharisto poli :-)
Edited by Bodyart
You are welcome! hope you find it usefull
    Fantastic addition  @korniza - thanks
    @AutoFrank hope to include it on new version ;)
    On 2/14/2017 at 3:27 PM, AutoFrank said:
    Hi Everyone
     {v1.0}
             or
     {v1.0}
    Regards
    [Autofrank]
    == FILES ==
    Regards
    -f
    can you please show the detailed procedure to implement the VD (Network Monitor V2.5) with pics as I am new for lua.
    thanks.
    Edited by bpkurmi
    Hi @bpkurmi
    The detailed instructions are above. There is no more that can be added ...
    What specifically extra were you looking for ?
    I use it almost a week and false alarms are gone! Next step is to find a way and manipulate the case of internet is offline...no message will arrive on that state. I suppose SMsgH will do the job but it also has limitations when internet is down and nobody is home
    Hi Everyone
     {v1.0}
             or
     {v1.0}
    Regards
    [Autofrank]
    == FILES ==
    Regards
    -f
    Sir,
    What is the port for oneplus 5t and Vivo V9 Phone
    thanks
    Not sure, I use Fing or another similar app to find open ports
    Phones are notorious for shutting down ports whne the screen or phone goes to sleep
    How can I now use the status "Online/Offline" to start a scene?
    I was wondering about the same thing. I would like to run a scene, if the Samsung TV is ON (online), turn Sonos OFF.  Could it be added somewhere in the main loop?
    @AutoFrank  I checked port for Samsung S9+. Discovered open port 6100/tcp.  Work in Lan Monitor 2.5.
    Just add two more ports:
    - Logitech HarmonyHub: Port = 8088
    - Vorwerk Kobold VR200: Port = 8081 Do not use as the Kobold stops working as soon as it gets pinged :(
    Cheers,
    Lodi
    Edited by Lodi
    Motorola moto G6
    I have try to find a open port on my daughter cell phone, I have try to port scan ports 1-65000 without results, I have also try 5060 without results.
    Grateful for help :)
    //Tigger
    @AutoFrank I love your VD. I've connected 40-odd devices now and it's a relief to have a way to keep track of them all.
    I did some hacking to your code to:
    1. add an "*" against the device being refreshed. I set sleep to 15000, as don't need instant notice of devices being offline, but I do want to see which device is currently being checked when I'm looking at the VD
    2. I also added some code to make sure the notification e.g. email only gets sent after two loops of being "offline", this way where i have devices that are rebooted I don't get spammed with unwanted emails.
    It all works perfectly so far!
    I'm thinking about adding code to check the status of devices connected to wall plugs, so I can have one place to check on all devices. I'm not sure if you've ever wanted to do this, but the VD you created is a great place to keep track of all devices in one place.
    I can send you my code hacks for 1 & 2 above, however I'm sure you could write something much better.
    @amilanov
    Glad you like it and hack away.. :-)
    It doesn't work for all devices as some go to sleep (phones, amazon echo devices, etc) and with some the ethernet adapter stays 'awake' for a while after the device powers down/goes to standby
    I use Unifi network equipment and use@10der Unifi checker and presence checker for them to automatically turn off my security system when we open the front door
    The LAN checker wouldn't work reliably in the situation
    .. enjoy
    I only use it for devices that are online all the time ie I wouldn't use it for a device that goes to sleep like a phone.
    I setup all my unifi access points on it, but now it looks like I need to find this unifi checker you speak of.
