Hi, can somebody explain me how the debug in scenes is working?
Meaning, how many records HC2 will store maximum (or characters), what's the rotation mechanism, .... ?
The reason I ask, In some scene's I can find a lot of history (with a lot of text). In others only some hours (where text is even very limited).
Thanks.
9 answers to this question
    All, Nobody that help me? Still not clear to me how many records are kept in the log information of a scene.
    For some, I can see a lot of history. For some scene's, only some hors. Is it row based, size based, time based?
    thanks.
    thanks.
    To be honest... I don't know, and I try to keep the debug log as clean as possible. I do understand your question. An I've wondered too, how the cleanup really works. If I want to debug a really nasty problem, then I resort to sending mails to myself. It would be nice if one could write a line to the event log (for durability) but as far as I know that isn't possible. Some users have suggested setting up a logging service, then using the http clients in VD and scene to log data.
    @petergebruers ok thanks. If you even don't know ! An event log or export should be welcome. But exporting through a VD and scene seems overkill.
    oh well, if the buffer is full, it will be overwritten, don't remember the size (number of lines) but you can check it easily.
    Regards overkill, well, make one scene which runs cyclic, reads all debug messages from all the other scenes and send it somewhere
    Thanks, I may have a use for this :-)
    @wpeeters
    As usual, Fibaro lacks information.
     I have implement log to syslog to make sure the logs are stores according to my rules and outside the HC2. Then there is no problem. You can see what I have done if you are interested to implement anything similar.
    Just a few functions and you can send like this:
    if DEBUG >=1 and SYSLOG == 1 then syslogserver('User closing - Partition: ' .. part .. ' User: ' .. user) end
    instead of this:
    if DEBUG >= 1 then fibaro:debug('User closing - Partition: ' .. part .. ' User: ' .. user) end
    It its easy. You only have to start up a syslog service in any reachable server in any OS.
    Peo
    @pos, thanks. I'll take a look at it. I already have a webserver running but nevertheless, this seems to take several evenings of work again to integrate this :-)
    @wpeeters
    Well. It is less than you think and not several evenings. 5 minutes work to test if you have a syslog service up and running on a remote server.
    (But *maybe* Net.FudpSocket only works in VD and the command have to be adjusted to work in a scene.)
    Here is a complete example...
    HOSTNAME = "TESTservice"
    SYSIP = "10.10.10.10"
    DEBUG = 1
    SYSLOG = 1
    function syslogserver(msg)
        udpsocket = Net.FUdpSocket();
        local sendmsg = (HOSTNAME .. ' ' .. msg)
        udpsocket:write(sendmsg, SYSIP, 514);
    -- with syslog
    if DEBUG >=1 and SYSLOG == 1 then syslogserver('User closing - Partition') end
    -- with fibaro:debug
    if DEBUG >= 2 then fibaro:debug('User closing - Partition') end
    Personally I log a lot to syslog
    /Peo
    Edited by pos
    Hi @tinman, do you know if there is an equivalent to this but for VD's. I have a look at the api, couldn't find one but did find what looks like a deprecated debugscene call which leads me to believe that the api documentation is not up to date
    Edited by AutoFrank
