[MINI-TUTORIAL] - simple http-api vd and Alexa HA Bridge setup
AutoFrank
Hopefully this will be replaced in a few months with direct control of Sonos from Alexa through a native skill supplied by Sonos themselves
In the meantime if you are using the http-api and have the HA bridge running then this may provide a stop gap for you if you require one
This compilation builds on work from a number of people including @morpheus75, @lennypenny, @matt1981 and others.
This solution has two parts and both will be needed for each zone you have.
1 - A simple sonos VD to provide limited control over a player. (volume, mute, play, pause, favorites and playlist access) There is no main loop code (as we are not displaying status) and should be light enough on your system
2 - The commands for the VD that will need to be entered into the bridge
There are three files included below
  1. The sonos VD ( required for step 1 below)
  2. A summary of the commands that with a simple find/replace will work for you (required for step 2 below)
  3. A outline of how to structure the entries in the HA bridge and what the alexa verbal commands are for each function (required for step 3)
Lets get started....
Step 1
Import the VD and add a name (should match the name of player in sonos) IP address (of sonos-api) and Port (normally 5005)
You will need to customise the VD for your favorites and playlists.
Modify and confirm all is working, Make note of the VD id number
Screenshot of VD and a suggested icon
/monthly_2017_05/591c435741141_sonosalexa.png.e30a970ccfc2f4bfffe7f3918139178c.png" />
Step 2
Open Commands file attached in your preferred editor
  • Replace the text user with your email  (something like auto.frank%40gmail.com)
  • Replace the text password with your password, (something like JackBox$)
  • Replace the text hc2ipaddress with the ip of your HC2 (something like 192.168.1.45)
  • Replace the text VDid with the id of your VD created above (something like 245)
You will also need to modify the HA bridge entry names (#8 to # 13) to match the favorite and playlist changes you made in step 1
This will then give you the command strings that you will need for your system that need to be entered into your HA bridge
Step 3
Enter the commands into the HA bridge. @morpheus75 has an excellent video on how to add entries to the HA Bridge
I have added a link to the youtube video below - skip to timeslot 27:00 for the part that outlines how to add an entry to the bridge.
Files
Step 1 Virtual device :
Step 2 document:
Step 3 document:
Adding HA Entries:
Hope this will be of use to forum users
_f
Edited by AutoFrank
Hi Guys,
I have just noticed that the Amazon Fire 7" and 8" is due to be launched on June 7th with "Alexa" on board.  I am not particularly interested in buying yet another tablet but will the Fibaro App run on the Fire? or is the Fire OS so different to Android?
Also, for the record, at the moments Amazon has dropped the Price of the Echo Dot to £44.99 for those wishing to buy some.
L
Edited by lennypenny
added 8" device
Good workaround - Such a shame you cannot associate echo(s) to rooms .
 I  have a dot in some of my main rooms so it is frustrating that"location" isn't a property the echo can communicate ... "turn on Sonos" could default to Sonos in current room so a much more natural voice interface.  Look forward to some real echo software updates from Amazon that recognise often used as a network of dots... rather than lots of rather short lived crude skills!
good solution for now thanks for sharing!
