Hi
UPDATED 1.1
UPDATED THIS VD FROM A SCENE WATCHDOG TO A SCENE & VIRTUAL DEVICE WATCHDOG
Hopefully this will be a useful little VD to some users
It was inspired by a comment made by @tinman (I think)
This VD Enables a user to scan all scene and virtual device DEBUG MESSAGES and trigger on predefined key words in the debug messages.
This may be useful to see if a scene develops an error or perhaps you are just looking for a keyword for a different reason
  • All scenes and virtual devices are included by default
  • Specific scenes and virtual device id's can be flagged to exclusion
  • Separate watch lists for scenes and virtual devices
  • A watchdog report is sent for all matches identified.
  • Can be sent via email or smart message hub
  • You get one email or message per id flagged ( not per watch word)
  • It will send message if no match in either vd or scene is found (added in v 1.1)
  • Suggested icon included below
/monthly_2017_07/watchdog.png.053d2b2b2433c2a01bf526af79058585.png" alt="watchdog.png.053d2b2b2433c2a01bf526af79058585.png" />
Note: If you use the Smart Message Hub please add that scene ID into the exclusion list as that scene will be
flagged by the watchdog after the first use.
This can be run on demand or on a schedule using Main Scene by @Sankotronic or similar.
I run it on a schedule once per day
Installation
  • Import the VD
  • Configure the following as required
  • Place on a scheduler if required
The VD has a status label and when it was last run
 watch.PNG.3ba1125c1bf4c5cba0c2c5b4aa2036df.PNGwatch1.PNG.b31653c26fea066e89d95fea10dbf911.PNGwatch2.PNG.07ad9270adbd029e6bfb9fb4d6a46d4e.PNG
and this is what the report looks like on pushover
VD attached
Edited by AutoFrank
Hi @AutoFrank,
I was playing a lot with HTML flags and e-mails but never get it to work. It shows properly in debug window but in email on several different mail clients HTML tags are always shown as normal text with extra backslashes. I even manage to show picture in debug window but never get it in an e-mail! Maybe I ask stupid question but can that URL encode function be of any help?
9 minutes ago, Sankotronic said:
Hi @AutoFrank,
I see two complaints regarding somewhat related subjects on this forum. Encoding of international characters fails on pushing/mailing/displaying and e-mail message corrupt or failed on special characters.  I can't help but think that things got worse recently. I have a script that mails something like this:
"Window K & P open".
I'm pretty certain that arrived intact, until 4.130-ish. Now I get:
"Window K"
So, I guessed the "&" was the culprit and I tried some workarounds, including "urlencode". Regarding UTF-8 I've tried "NCR" (Numeric character reference) and while that seems to work in a browser, it doesn't help fixing e-mail messages, probably because... you may have guessed it... NCR use an ampersand to start encoding.
Edited by petergebruers
@AutoFrankYes, this version seems to solve the problem. Thanks. Don't apologize, I'm glad I could help :-)
Thanks again for the VD. I'll schedule execution soon and do some more testing as well integrating of the VD test.
@petergebruers
honestly, I noticed the formatting issue but I was not suprised to see it. I didn't expect to see correct html formatting while sending strings from a VD via SMsgH to a thunderbird e-mail client :-)
I'll think about your proposal but I'm used now to this debug in all my scene's that I probably will keep using it.
The code is a replacement for your code, it just adds replacement of invalid characters.
@petergebruers I replaced the code in that one scene. Still I have the same output in my mail client;
Thanks for trying! Much appreciated! I'll see if I can find an explanation for the number of backslashes. I forgot to mention one more element: whenever you do a copy paste from/to editor"/hc2 edit window"/application we get another conversion.... I've seen quite a few posts containing code that didn't run because it was copy/pasted via MS Word (if I recall correctly).
Hi guys, I dont know if this is the right place to ask, is it possible to press the "save" button on a plugin?
I know the french watch dog restarts scene's and vd's by pressing save but can this be done for plugins as well?
I found that pressing  save on the harmony plugin updates the correct state if you start an other activity by remote.
Thanks,
Jim
i guess "yes", UI is UI, so click save button should work.
For plugins, you can as well try to restart the plugin from any scene with:
Thanks @tinman will try and report back :)
Hi Frank,
Install last version, local jT in comment, run and get this error;
[DEBUG] 18:54:34: Checking Scene id: 18
[ERROR] 18:54:35: line 170: attempt to index global 'jT' (a nil value)
What I do wrong...?
Edited by twanve
    23 minutes ago, twanve said:
    Hi Frank,
    What I do wrong...?
    Hi @twanve
    Sorry, I don't have access to the code at the moment but it looks like you need to comment out the reference to  jT if you don't use a hometable
    Edited by AutoFrank
    22 hours ago, AutoFrank said:
    Hi @twanve
    Hi Frank,
    I have this line in comment, I don't use a home table.
    @twanve
    Is it working or do you still have errors ?
    53 minutes ago, AutoFrank said:
    @twanve
    Still the same error
    Thanks @twanve
    I don't have access to the code as I am away
    Would you mind posting the full code and I can take a look ...
    Thanks @twanve
      ** ScVD Dbg Watchdog v1.0d **
      Scene and VirtualDevice Debug Watchdog v 1.0c release (Autofrank - June 21st 2017).
      1.0d 0- fixed but in 1.0c where it missed one match
      Enables a user to scan all scenes and virtual devices and trigger on predefined key words in the debug messages
      Specific scenes can be flagged to exclusion
      A watchdog report is sent for all scenes identified. Can be sent via email or smart message hub
      Note: If you use the Smart Message Hub please add that scene ID into the exclusion list or you will get a
      circular reference as the reports get sent out.
      HomeTable is only used to run smart message hub.
      The scenes and the deug messages are retrieved via the api
      This can be run on demand or on a schedule using Main Scene by @sankotronic or similar.
    local device, localhost, port = fibaro:getSelfId(), '127.0.0.1', 11111
    local watchReport = ""
    local sendFlag    = ""
    local title       = ""
    local v1          = ""
    local scStatus    = ""
    local vdStatus    = ""
    local scCount     = "0"
    local vdCount     = "0"
    local scanType    = ""
    -- user configurable
    --local jT    = json.decode(fibaro:getGlobalValue("HomeTable")) -- comment out if HomeTable is not used
    watchListSC = {"CRITICAL", "error", "line334", "line74", "concatinate", "Assertion failed"} -- words that you want to watch in scenes
    watchListVD = {"expected", "unfinished"} -- words that you want to watch in virtual devices
    excludeList = {"15"}        -- scene and virtual device id's that you would like to exclude from watching
    SMsgH       = true          -- set to false if you don't use smart message hub
    SMsgHtarget = "pushover"    -- set to preferred medium if you use smart message hub
    deBug       = false         -- enable for greater debug verbosity
    -- end of user configuration section
    function checkScenes()
      sc = Net.FHttp(localhost, port)
      response, error = sc:GET("/api/scenes")
      if error == "200" or error == "201" then
        jS = json.decode(response)
        for k,v in pairs(jS) do
          Id, Name = v.id, v.name
          runStatus = "Starting to check Scenes..."
          fibaro:sleep(1000)
          runStatus = "Checking Scene id: "..Id..""
          fibaro:debug(runStatus)
          fibaro:call(device, "setProperty", "ui.lblstatusSC.value", runStatus)
          fibaro:call(device, "setProperty", "ui.lblstatusVD.value", "")
          sendFlag = "true"
          for k1,v1 in pairs(excludeList) do
            if string.match(v1, Id) ~= v1 and sendFlag == "true" then
              if deBug then fibaro:debug("no match found "..v1.."") end
            else
              if deBug then fibaro:debug("match FOUND so exclude: "..v1.."") end
              sendFlag = "false"
          if sendFlag == "true" then
            fibaro:sleep(500)
            --response, error = sc:GET("/api/scenes/DebugMessages?id="..Id.."")
            response, error = sc:GET("/api/scenes/"..Id.."/debugMessages")
              jW = json.decode(response)
              fibaro:debug(JW)
              for k2,v2 in pairs(jW) do
                for k3,v3 in pairs(v2) do
                  if v2.type == "DEBUG" and k3 == "txt" then
                    for k4,v4 in pairs(watchListSC) do
                      if string.match(v2.txt, v4) == v4 then
                        scCount = scCount + 1
                        if watchReport == "" then
                          watchReport = ""..watchReport.." \n Scene: "..Name..", ID: "..Id..". \nWatch Flags..\n"..v2.txt.."\n"
                        else
                          watchReport = ""..watchReport..""..v2.txt.."\n"
            scanType = "scene"
            sendReport()
    function checkVirtualDevices()
      response, error = sc:GET("/api/virtualDevices")
          runStatus = "Starting to check VD's..."
          fibaro:sleep(1000)
          runStatus = "Checking VD id: "..Id..""
          fibaro:call(device, "setProperty", "ui.lblstatusVD.value", runStatus)
          sendFlag = "true"
            else
              sendFlag = "false"
            fibaro:sleep(500)
            response, error = sc:GET("/api/virtualDevices/"..Id.."/debugMessages")
                    for k4,v4 in pairs(watchListVD) do
                        vdCount = vdCount + 1
                          watchReport = ""..watchReport.." \n VD: "..Name..", ID: "..Id..". \nWatch Flags..\n"..v2.txt.."\n"
                        else
            scanType = "VD"
            sendReport()
    function sendReport()
      -- compose title
      if watchReport ~= "" and scanType == "scene" then
        title = "Watchdog Report: Scene"
      if watchReport ~= "" and scanType == "VD" then
        title = "Watchdog Report. VD"
      -- send report
      if SMsgH then
        if SMsgHtarget == "hc2popup" then
          fibaro:startScene(jT.sc.SMsgH, {watchReport, SMsgHtarget, "", title, popType})
        else
          fibaro:startScene(jT.sc.SMsgH, {watchReport, SMsgHtarget, "", title})
      else
        fibaro:call(2, "sendEmail", title, watchReport)
      watchReport = ""
    function updateSClables()
      -- update labels
      if scanType == "scene" then
        if tonumber(scCount) > 0 then
          scStatus = ""..scCount.." matches were found"
        else
          scStatus = "No matches were found"
        fibaro:call(device, "setProperty", "ui.lblstatusSC.value", scStatus)
    function updateVDlables()
      if scanType == "VD" then
        if tonumber(vdCount) > 0 then
          vdStatus = ""..vdCount.." matches were found"
        else
          vdStatus = "No matches were found"
        fibaro:call(device, "setProperty", "ui.lblstatusVD.value", vdStatus)
      if deBug then fibaro:debug(watchReport) end
      -- notify that watchdog was run as schedule if no matches were found
      if tonumber(scCount) == 0 and tonumber(vdCount) == 0 then
        title = "Watchdog check complete"
        report = "No matches found in either virtual devices or scenes"
        if SMsgH then
            fibaro:startScene(jT.sc.SMsgH, {report, SMsgHtarget, "", title, popType})
          else
            fibaro:startScene(jT.sc.SMsgH, {report, SMsgHtarget, "", title})
        else
          fibaro:call(2, "sendEmail", title, report)
      fibaro:debug("Watchdog check complete - no reports sent..")
      else
      fibaro:debug("Watchdog reports sent..")
      local upt = ""..os.date("%d").." "..os.date("%B").." @ "..os.date("%H:%M")..""
      fibaro:log("Last update: "..upt)
      fibaro:call(device, "setProperty", "ui.lblupdate.value", "Last update: "..upt)
    function main()
      checkScenes()
      updateSClables()
      updateVDlables()
    main()
    Thanks @twanve
    Are you using the smart message hub ?
    Just now, AutoFrank said:
    Thanks @twanve
    no
    Okay .. Thanks @twanve
    So you need to set SMsgH = false
    This is about 4 lines down from the hometable reference
    Also 2 lines under that set deBug  = true
    This will give you a ittle more debug messages ...
    Make those two changes, save and see what happens..
    Tell me what you what you see in the debug window
    Edited by AutoFrank
    Yup, this is the solution, all works fine now.
    Thx for you support....!
