Nanoleaf Aurora light panels and api
AutoFrank
Hi
Has anybody worked with these devices
They seem interesting... Zigbee or Wi-Fi and also have an api and there also seems to be some git wrappers
JavaScript Nanoleaf Aurora API for node.js
Had anybody purchased and worked with the panels or the app
Hi @AutoFrank,
i have one set with 15 panels, but not yet integrated with HC2.
I must say the lights are beautiful, much better than for example Philips hue color bulb, because vibrancy and luminosity are apparantly better.
The app is ok (on android), but the API is not yet released as far as i'm aware..
  • Thanks @Bodyart
    I couldn't see if the api was online or documented as they require you to sign up for a SDK.
    Might be an interesting future project .
    @AutoFrank,
    the API is apparantly working, see the quote from the Nanoleaf develeper API documentation:
    Quote
    OpenAPI can be accessed by using the IP address given by "Location". Note that the port number is 16021 by default although we recommend getting this information dynamically from SSDP.
    If the m-search message provides a non-zero value in its "MX" or "MAX_COUNT" header (denoted by M), an Aurora will send a response after a delay of d seconds, where d is chosen uniformly at random from the set of integers {0, 1, ..., M}.
    No response will be sent if Aurora OpenAPI is unavailable.
    I wil try it soon. :-)
    there is also interesting info on
    Nice find. Thanks for sharing. SSDP is that related to upnp? I know, it is no longer upnp and it probably isn't "dlna" either, I'm getting old... ;-)
    @AutoFrank I talk to my wife. Let us assume she likes it. I order one. We try to make it work with Fibaro. I think I have a plan! :-)
     @petergebruers
    Positive WAF + Plan = Good Outcome ... sometimes ;)
    Edited by AutoFrank
    @petergebruers,
    I am confident, that you know how to "convince" your wife to like it, hhh It's not a high magic. :-D
    In case she's visual, show her nice youtube clips;
    If she's auditive, tel her beautiful story about Nanoleaf;  :-)
    etc, etc...
    But first of all set your voice kind a mellow, romantic mode on....
    You know how to do it.
    Hi @AutoFrank,
    there is also an other
    for Nanoleaf also explaining a bit...
  • 7 minutes ago, Bodyart said:
    Hi @AutoFrank,
    Thanks @Bodyart
    I must take a look at that
    @AutoFrank,
    i forgot to mention, that Nanoleaf has an Alexa skill for Aurora, which makes the integration with HA little bit easier.
    I use simple virtual devices at the moment for my aurora.
    On/Off Button
    Brightness Slider
    Color Slider
    Saturation
    Effect exampel color burst
    It  was inspired by @Sankotronic philips hue virtual device and can even work with very smart lights scene :) but main update loop is missing atm.
    I love to see other integreations :)
    Quote
     6. Authorization
    A user is authorized to access the OpenAPI if they can demonstrate physical access of the Aurora. This is achieved by:
    1. Holding the on-off button down for 5-7 seconds until the LED starts flashing in a pattern
    2. Sending a POST request to the authorization endpoint
    within 30 seconds of activating pairing.
    3. If 2 is achieved, the POST response will contain a randomly generated authorization token:
    The Link to the api documentation is:
    Edited by PreHack
    About the Nanoleaf Aurora as a product, I like it very much.
    They are great quality and bright with really saturated colors and nice effects. And If you have a flat wall or like I have some abrasion they stick to the wall really god. But at the moment there is no other solution than to stick them on the wall. I'm not yet confident to put them on the ceiling, but they are working on some mounts to screw on.
    There will soon be an add-on for music visualization that will be awesome.
    I got yesterday flexible links to connect the panels around corners.
    They are very open about their planning and have many customers surveys. And are working on the products their customer wants.
    Here are the ones I already have partially installed, I needed to put some screws in because the wall was not flat on the one with the wooden beam.
    Hi @AutoFrank @petergebruers
    I'm still a beginner in LUA and now strugling a bit with my code....
    I'm getting the list of effects from Nanoleaf:
    Debug is giving me an array:
    [DEBUG] 19:33:29: ["Flames","Forest","Pride Rainbow","Romantic","Sunset","Campfire Headphase","Ocean","Bedtime","Burst","Zen","Peace","Pride","Happy","Flag","Campfire","Aqua","Frost","Earth","Abyss","Pastel Fade","Magic","Chakra","Pastel","North","Sunrise","Dream","Roses","Sea"]
    Now i want to put the "response" into a table in order to use thouse effects. Any ideas to put me in the right direction?
