Hi there!
After latest update (or may be one before) my scene not triggered on motion state.
I have Fibaro motion sensor and Fibaro wall plug.
Only magic scene works. My own - no.
Yes, it has Automatic flag and work when I press Run.
I try to create new scene but the same.
All the scenes and devices assigned to same room.
What the problem?
6 answers to this question
1 hour ago, fishMD said:
Hi there!
What the problem?
What firmware version are you on?
    4.530
    4.530
    Ok. My advice is to make a backup and then restart the homecenter. Then downgrade to the previously firmware. Then run it for a couple of hours and re-upgrade to the newest firmware. Finally, restore to the backup you made in the first place. It worked for me.....
    Edited by Thomasn
    No chance. Any firmware (patch.tar.gz from
    ) erroring "image corrupted". 2 different browsers.
    Why do you not use Fibaro's restore from within the browser? I am not sure that your manual handling process works.
    But you says "downgrade to the previously firmware". It's possible only with custom firmware file.  Because here is only three options:
    1. Repair your system automatically to latest software version.
    2. Repair system from local file.
    3. Recover your system to latest software version. All user data will be erased.
    What option should I select?
