  • 5
Netatmo Weatherstation in HC3
Hallo together,
I look for a Integration of the Netatmo Weatherstation in the HC3.
In my HC2 is a plugin but not in the HC3, is there any way to get the datas for Netatmo to the HC3??
Greetings Poldy 2000
6 hours ago, Lauri said:
Is it doable with HC3 now with limited Lua?
as QuickApp for sure, see attached very simple netatmo wind sensor QA
For other types take e.g. HC2 code from @boomx and change few lines.
Probably the best would be to create separate QAs for each every type of sensor.
Edited by tinman
  • Thanks 4
Quick App for the rain sensor... based on the code of @tinman and my old script for netatmo wind gauge :) Have fun...
  • Thanks 2
2 hours ago, Macschimmi said:
Well, that doesn't really get going with the new firmware ?
1 hour ago, Macschimmi said:
I thought or understood that you wanted to program something up ?
honestly, these examples are good enough to make any other Netatmo QuickApp, and btw. is it really that hard to convert km/h to m/s if you don't like it? You have only click 4 times, scroll, push some 5 keys on Keyboard and save.
sure,
download Netatmo Weather Station VD-scene standalone ->
- check the docs provided by Fibaro
- convert VD to QuickApp
- convert scenes
- add cusomer weather provider
- add your QuickApp into it
- enjoy working solution
Edited by Lauri
@tinman can you confirm from first-hand experience that this works? Currently it comes across like a snarky comment
Hi all,
I'm still busy with UHAS for HC2 trying to finish it as soon as humanly possible. After finishing UHAS for HC2 i will immediately start with porting UHAS to HC3. Of course, it takes time to do it right, so I can't write any deadline when it will be finished. I just can write that I will invest all my available free time to UHAS for HC2 and HC3 so will not do any work on standalone versions until both HC2 and HC3 UHAS version are in development.
Weather station with inside and outside would be great ?
Thanks for the tip! works fine.
Hi.
Can anyone in a few sentences describe how to use this file "netatmo_Rain_sensor.fqa" and what to change to make it work ???
TNX in advance.
29 minutes ago, interested said:
Hi.
TNX in advance.
You have to change the Varibales in the QuickApp. That's it... :)
 Can you also do this for the inside and outside sensor? Maybe you ?
In progress... ;)
You are my hero ?
tinman`s file shows wind speed  in the wrong unit (m/s). Netatmo app shows in km/h.
boomx`s file shows amount of rain in the correct unit mm /h, but the data are from wind speed.
Edited by interested
Actually i like m/s better for programming as it is base unit for speed. Also its more accurate than km/h to be honest as you work with higher numbers.
that's right, because i know that there will be change in the interface in next official firmware, so i leaved like that till the fw is available (m/s is what it should be, but km/h is human readable).
Nobody said that it works with the new firmware... @tinman mentioned changes to the interface... ☺️
