  • 5
Netatmo Weatherstation in HC3
Hallo together,
I look for a Integration of the Netatmo Weatherstation in the HC3.
In my HC2 is a plugin but not in the HC3, is there any way to get the datas for Netatmo to the HC3??
Greetings Poldy 2000
I thought or understood that you wanted to program something up ?
Edited by Macschimmi
I myself have neither a wind sensor nor a rain sensor and the content of the LUA codes is for me Indian for advanced users.
Yes I have problems creating this myself
4 minutes ago, Macschimmi said:
I myself have neither a wind sensor nor a rain sensor and the content of the LUA codes is Indian for advanced users.
no problem, there is solution already available
/monthly_2020_03/image.png.ae759594917a516e628c2958339d2059.png" />
or just
I'm training myself for creating generators and Netatmo seems to be fun :D. I will do more Netatmo QA generators in near future (this week or weekend). For now i have only this one.
It just filling device variables :D now. For multilevel sensor i'm preparing checkboxes. Device generated by generator is based on what @tinman and @boomx shared, meaning rain and wind sensor. So, thanks for what you shared guys.
Do what you want with the code for generator :D.
Netatmo main (Weatherstation) temperature sensor generator:
  • Thanks 3
That's what I call a great implementation - thanks for the work ?
Guest Freddan67
Wow !!!. Thanks that was great. Well done.
jakob.jezek@
Thank you for the file and understanding that newcomers do not know this.
On the other hand, these are the things Fibaro promises ... but sorry the reality is different with the most expensive controller.
That is just side effect of those generators. ?
or just
No HC3 support yet and the list of available firmwares is not updated in a while ? ..
@M.Baranowski … something for you
File in the end of page will end up with some setup desc of what to do on
on Monday. I did not added generator for rain, wind and internal sensors and did not prep any Quick apps. I do not have those devices physically, so i cannot tell if they will work or not. I will not give generators for unntested devices.
So i have made generators for following.
  • Main weather station
    • Temperature
    • Humidity
    • CO2
    • Pressure
    • Noise
  • Outdoor sensor
    • Temperature
    • Humidity
CZ localization:
Edited by jakub.jezek
added place for CZ users.
  • Thanks 4
Great, I'll have work again ... thank you very much.
If you change your mind about Rain & Wind sensor, or you need some information, I will love to help.
You know how it is, the grass will start to grow & Rain gauge is good for robot mower outside :)
i'm ready to give something for a beer too
Regards ... & TNX again.
Guest Freddan67
    • Temperature
    • Humidity
    • CO2
    • Pressure
    • Noise
  • Outdoor sensor
    • Temperature
    • Humidity
CZ localization:
You are the best. Thanks
Guest rafal_ll
In my case, Importing an internal temperature device ends in an error.
I checked original and EN generators.
/monthly_2020_03/11.jpg.4d5015615fc8da2060fbd954a696717c.jpg" />
What to do if I have more internal sensors is shown only first
I can also buy you a beer
Edited by rafal_ll
For internal sensors you need to change sensor type in outdoor sensor. But I cannot tell what else you need to change. Probably few indexes.
i did use this first >
 from jakub.jezek @ for my indoor sensor & it works ...
This is for the Master Indoor Sensor (Station), not for the Slave
@rafal_ll, please try to generate another with fake credentials and if it reports error, then please send it to me. I'm interested in FQA composition as a file.
Also guys i'm not doing Internal sensor. Outdoor is easy. Its only one per meteostation. Internals can be up 3 per meteostation. I need atleast two to figure out indexing part as one sensor does not say anything.
And those FQAs do not support multiple weatherstations under one account, so they would need to be split to multiple accounts. Mail aliases works fine.
Uploaded on
. Once it becomes Approved it will be shown in list there.
JJ,  I hope you changed your mind and added also a wind & rain meter :)
wind meter works, but I'm disturbed by the unit (m/s).
