  • 5
Netatmo Weatherstation in HC3
Hallo together,
I look for a Integration of the Netatmo Weatherstation in the HC3.
In my HC2 is a plugin but not in the HC3, is there any way to get the datas for Netatmo to the HC3??
Greetings Poldy 2000
1 hour ago, marekneo said:
The log looks ok. What is it that is not working properly? To me it looks like you get data.
I already solved the problem, it was about the weather module.
Hello, I have now added a wind module to my previous Netatmo with rain module. The Netatmo website also shows me this correctly. Only not on my HC2. Das HC2 habe ich auch schon neu gestartet und auch auf der Entwicklerseite
den Reset durchgeführt und die neuen Daten I have already restarted the HC2 and also reset it on the developer site
and the new data in the HC2, which then reconnected with my Netatmo account. Nevertheless, the wind module is not displayed in the HC2. What could be the problem?
Update: I was able to solve the problem. The wind module must be created with a VD. I have now done this with a VD from another forum and the VD from here.
Edited by Microby
Hi there,
I've just Insalled NETATMO Weather Provider On HC3 and it looks like it doesn't work. A part of the script get some errors and no data loaded on HC3
Here is the log :
I've just added fr language in i18n file that was missing
Could you help me please. Thank you
No data loaded
/monthly_2022_08/image.png.9dec7c24a44cb6be830fc6a6c4984d64.png" />
Hi all,
Just for your info, if you are looking for integration of Netatmo Weather station and Netatmo air quality (coach) with HC3, HC3L, Yubii home, then you can find them here on forum download section:
and also on Fibaro marketplace:
and
Hope you like it and give it a 5 vote :-)
