I did it, but doesn't working. I will lose the mine.
    I don't understand, do you connected?
    What doesn't work?
    Any user (which is defined in HC2) can be connected locally.
    Edited by cag014
    Now I got a push notification from the app that in the past 37 times use my location. But not send this to the HC2.?
    I don't understand. The another iPhone is this the situation too.
    Are you able to see rooms and devices while connected locally?
    What do you mean by that?
    Do you see any location updates in /api/devices/2
    Edited by cag014
    Are you able to see rooms and devices while connected locally? - Of course, i see everything in the app.
    What do you mean by that? - The app uses my location. But don't send to the HC2.
    Do you see any location updates in /api/devices/2 - I can't see now, because i'am working. This page,i can see only in the local network. I will see tomorrow.
    Now I'm confused... you're not at home (I mean you're not in your home local network area) and you able to see everything in the app while connected to local IP Address?
    Since you should be connected to local area, no location updates could be sent to HC2.
    As a first step to verify GPS is working, we trying to verify if you receive location while inside you LAN.
    Edited by cag014
    This is what i can see now.
    It's OK, if you're outside of LAN, no updates should happen...
    The another iPhone is on the local network now. I did the settings while i am home.
    Edited by SmartLifeSystems
    Not working. I don't understand what did i wrong.?
    I believe location permission on your iPhone set correctly for the app.
    Now let's try to connect through WAN.
    Forward some port for app on router.
    Go to port  forwarding:
    Enter external port: (let's say 8080)
    Select protocol: if you have option to select BOTH, if not select TCP-IP
    Internal port 80
    IP-Address: HC2 local IP-address
    Save configuration.
    Now go to browser and type MY IP. You shold receieve your Public IP address. (Hope it doesn't change frequently or may be you have fixed IP)
    Now go to mobile app and configure new HC address (<public IP>:8080)
    On iPhone turn off WiFi.
    Verify that everything works on app.
    Now go to outside (to change location) to check if new location has received.
    Edited by cag014
    Hi cag014!
    I did your instructions. But  nothing. I have no idea. I am very angry.
    So when you set HC IP in app. to 192.168.0.101:8080 it doesn't work?
    No. but I am set my public ip:8080. That’s wrong? Now I change the 192.168.0.101:8080 and wait.
    Ooops... sorry my mistake, yes you need to set public IP:8080
    it should be redirected to 192.168.0.101:80
    Edited by cag014
    Works? I mean is app connected to HC2?
    Now i see myip, and another, than yesterday. The app work with the 192.168.0.101:8080. Yesterday worked with the public IP:8080, but this IP today another than yesterday.
    Yes, if you don't have fixed IP option it changes quite frequently...
    But we just need to verify that GPS works on local connection, that's all.
    If it works then we can ask fibaro support to help with Fibaro ID connection
