2 hours ago, ChristianSogaard said:
I'm getting an error on RULE 10 - the user is missing , I tried adding a User into the HT - but I missed the syntax.
I did try to fin a description in the
There was a semicolon missing after the for-loop. No one seems to have tried it before... Fixed in original post too /thanks
    You are so fast. .Thank you ?
    Gettig some more ERRORS - when triggering the ARM Alarm
    [15.11.2020] [20:20:45] [ERROR] [QUICKAPP928]: in Rule:5[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed...]: {"err":".\/include\/EventRunner.lua:1824: bad deviceID 'nil' for '%setprop' '\"user\"?'","ERR":true,"src":"Rule:5[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'"}
    [15.11.2020] [20:20:45] [ERROR] [QUICKAPP928]: in Rule:10[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed...]: {"err":".\/include\/EventRunner.lua:1824: bad deviceID 'nil' for '%setprop' '\"user\"?'","ERR":true,"src":"Rule:10[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'"}
    [15.11.2020] [20:20:50] [ERROR] [QUICKAPP928]: in Rule:6[#alarm{id='$id',property='armed',value=true} =>...]: {"err":".\/include\/EventRunner.lua:1824: bad deviceID 'nil' for '%setprop' '\"user\"?'","ERR":true,"src":"Rule:6[#alarm{id='$id',property='armed',value=true} =>...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'"}
    and for RULE 7 when DeArming
    [15.11.2020] [20:24:38] [ERROR] [QUICKAPP928]: in Rule:7[#alarm{id='$id',property='armed',value=false} =>...]: {"err":".\/include\/EventRunner.lua:1824: bad deviceID 'nil' for '%setprop' '\"user\"?'","ERR":true,"src":"Rule:7[#alarm{id='$id',property='armed',value=false} =>...]","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'"}
    I don't recognise the rule numbers anymore - you have added rules? Can you post all your alarm rules?
    The user should be the ID if your HC3 user.
    Ex 2 is often the admin
    rule("user=2")
    rule("user=2")
    seems like your 'user' is nil
    matrix1 = 77 -- DeviceID of matrix device
    rule([[matrix1:central & keyPrim =>
         post({type=fmt('%s_%s_%s',keyPrim,matrix1:central.keyId,matrix1:central.keyAttribute)});
         keyPrim=nil
    rule([[matrix1:central & keyPrim==nil =>
        keyPrim=fmt('Key%s_%s_%s',matrix1,matrix1:central.keyId,matrix1:central.keyAttribute);
        wait(2);
        keyPrim=nil
    rule("#Key77_2_Pressed3_4_Pressed2 => post(#disArm)") -- Matrix iD 77, key 2 3-clicks, key 4 2-clicks
      rule([[keyfob:central.keyId==3 => -- Keyfob to enable/disable alarm zone
        || 1:alarm.armed >> 1:alarm=false; log('disarming 1');
        || !1:alarm.armed >> 1:alarm=true; log('arming 1')
       rule("1:alarm='watch'") -- Send us an event when user arms alarm (via app or GUI or rule)
      rule([[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed
            local alarm = id:alarm;
            if alarm.devices:safe then                            -- Check that devices are safe
              user:msg = log("Alarm partition '%s' is about to arm in %s seconds",alarm.name,secs)
            else
               user:msg = log("Alarm partition '%s' has breached devices, cancelling arming",alarm.name,secs)
      rule([[#alarm{id='$id',property='armed',value=true} =>
            user:msg = log("Alarm partition '%s' is now armed",id:alarm.name)
      rule([[#alarm{id='$id',property='armed',value=false} =>
            user:msg = log("Alarm partition '%s' is now disarmed",id:alarm.name)
      rule([[#alarm{id='$id',property='breached',value=true} =>       -- Alarm partition breached
            user:msg = log("Alarm partition '%s' breached!",id:alarm.name);
            for i=1,5 do log("Tuut!") end
      rule([[#alarm{property='homeBreached',value=false} =>  -- All alarm partitions safe
            user:msg = log("Alarm safe again")
            else
               local bd = {};
               for _,id in ipairs(alarm.devices) do if id:breached then add(bd,id:name) end end;
               user:msg = log("Alarm partition '%s' has breached devices %s, cancelling arming",alarm.name,bd)
    So you need to set the variable user to a userID in the beginning of the rules, like
    rule("user=2")
    yes - it was the user missing - looks better now
    rule("user=2")
    I'm running test on this Rule - I'm getting !"Alarm partition '%s' is about to arm in %s seconds" every time arming . even though - my door is opened, and is member of the Perimeter and the Whole House Zone.
    It should do "cancelling arming"
    15.11.2020] [21:04:11] [DEBUG] [QUICKAPP432]: update curDoors: x17:x Bagdør,355.0.1, , doors: Kontor Havedør x4:x,x17:x Bagdør,355.0.1,
    [15.11.2020] [21:04:29] [DEBUG] [QUICKAPP928]: Incoming trigger:{"value":true,"id":2,"type":"alarm","property":"armed"}
    [15.11.2020] [21:04:29] [DEBUG] [QUICKAPP928]: [{"type":"alarm","id":"$id","value":true,"property":"armed"}]>>'Rule:5[#alarm{id='$id',property='armed',value=true} =>...]'
    [15.11.2020] [21:04:29] [TRACE] [QUICKAPP928]: Alarm partition 'Whole House' is now armed
    [15.11.2020] [21:04:30] [DEBUG] [QUICKAPP928]: fibaro.call(2,"sendGlobalPushNotifications","Alarm partition 'Whole House' is now armed","false") => nil
    Edited by ChristianSogaard
    And the door is a member of the partition reported in the "Alarm partition '%s' is about to arm in %s seconds" log?
    Do you arm the whole house or a single partition?
    Can add some log to see what devices it thinks are safe
    This Line is showing the change. - so . "Kontor Havedør x4:x" just opened
    [15.11.2020] [21:23:22] [DEBUG] [QUICKAPP432]: update curDoors: x17:x Bagdør,355.0.1, , doors: Kontor Havedør x4:x,x17:x Bagdør,355.0.1,
    Its member of "Whole House"
    /monthly_2020_11/image.png.4a1202de3dfa0ad0c1e07392b24c6b9e.png" />
    The House is being Armed.
    [15.11.2020] [21:26:16] [DEBUG] [QUICKAPP928]: Incoming trigger:{"value":true,"id":2,"type":"alarm","property":"armed"}
    [15.11.2020] [21:26:16] [DEBUG] [QUICKAPP928]: [{"type":"alarm","id":"$id","value":true,"property":"armed"}]>>'Rule:5[#alarm{id='$id',property='armed',value=true} =>...]'
    [15.11.2020] [21:26:16] [TRACE] [QUICKAPP928]: Alarm partition 'Whole House' is now armed
    [15.11.2020] [21:26:16] [DEBUG] [QUICKAPP928]: fibaro.call(2,"sendGlobalPushNotifications","Alarm partition 'Whole House' is now armed","false") => nil
    Trying for ZONE - Perimeter. Then it works?
    - [15.11.2020] [21:28:30] [DEBUG] [QUICKAPP928]: [{"type":"alarm","id":"$id","value":"$secs","property":"willArm"}]>>'Rule:9[#alarm{id='$id',property='willArm',value='$secs'} => -- Notification that alarm is about to be armed...]'
    [15.11.2020] [21:28:30] [TRACE] [QUICKAPP928]: Alarm partition 'Perimeter Zone' has breached devices ["Kontor Havedør x4:x"], cancelling arming
    It seems like it's going directly from activating to armed. Is the delay close to 0s?
    It needs a delay for the activation check to have time to check the devices before the partition gets armed.
    I would say it needs a minimum of 4-5s delay in the alarm setting for the partition
    • 1 month later...
    For the variable user for the userID in the beginning of the rules, like
    rule("user=2")
    if family is 4 people - all using APP for ARM/DisArm
    Can I detect which user is arming from the APP - and only sendGlobalPushNotifications to the user that is arming?
    rule("user=2")
    rule("user=2")
    What if I have 4 users- can i check which user from the APP is arming the Alarm? - if not i need to PUSH to all users
    Can I do rule("user=2,3,4,5") ?
    4 minutes ago, ChristianSogaard said:
    rule("user=2")
    You can push to several users by giving a list to :msg
    Love that - but can i check which user i arming the Alarm , and only PUSH to that user?
    I haven't been able to detect any trigger value (or events panel) that tells who armed the alarm.
    You could have different buttons/scenes for your users to arm, and there set the user.
    Brilliant Idea ?
    Jan,
    can this be a temporary option?
    for each user a line?
    1 hour ago, Sjakie said:
    Jan,
    That's equal to
    2:msg = ...
