On 11/15/2020 at 4:05 PM, jgab said:
Examples in Lua if you don't want to use ER4 :-)
If you want to list all devices that can be part of a alarm partition/zone you can do
Guess fibaro uses that to populate the pop-up form when adding devices to partitions
Hi, This works great.
But what i don't understand is why can i arm an entire zone even when there is a single sensor in that zone breached?  I armed a zone with an breached sensor but the zone gets armed, no problem.
only when i run your code from above it says there is a sensor breached. Appearently if you arm a zone the sensors in that zone are not checked, that is something that you have to do yourself.  Strange!
  • 10 months later...
    On 11/15/2020 at 8:02 PM, jgab said:
    There was a semicolon missing after the for-loop. No one seems to have tried it before... Fixed in original post too /thanks
    Hi @jgab
    what is bda and alarm.name kind of types?
    I tried to call a Text to speech - my mu rule keeps failing.
    rule([[#alarm{id='$id',property='breached',value=true} =>       -- Alarm partition breached
    --    user:msg = log("Alarm partition '%s' breached!",id:alarm.name);
    --    for i=1,5 do log("Tuut!") end
    local alarm = id:alarm;
         local bda = {};
         for _,id in ipairs(alarm.devices) do if id:breached then add(bda,id:name); end end;
         353:msg = log("Alarm partition '%s' has breached devices %s, ",alarm.name,bda);
         fibaro.call(1295, "say","følgende er åbent " .. alarm.name .. bda,"Badeværelse",60)
    On 11/24/2021 at 6:10 PM, ChristianSogaard said:
    Hi @jgab
         local bda = {};
    Hi ?
    I could still need some help why
    in the above rule wont work?
    it work if its called in a scene
    Edited by ChristianSogaard
    P
    There is no '..' operator in rules to concatenate strings.
    Use fmt()
    fibaro.call(1295, "say",fmt("følgende er åbent %s %s",alarm.name,bda),"Badeværelse",60)
    Are you sending 4 arguments to 1295:say ?
    Use fmt()
    Yes - sending four arguments to 1295:say.
    fibaro.call(1295"say",fmt("HEJ følgende er åbent %s %s",alarm.name,table.unpack(bda)),"Badeværelse",60)
    P
    Hi @jgab
    it seems that this rule has stopped working.
    Do i remember correct that Fibaro changed some of the alarm commands recently  - could it be the reason that willArm dont trigger anymore?
    19 hours ago, ChristianSogaard said:
    Hi @jgab
    Hi @jgab
    Looking in
     you have a function called activatedPartitions, is this replacing the EV4 "willArm" trigger ?
    Above rule stopped triggering a little time ago. I could use a fix ?
    I tested it this morning and it still works for me.
    Have you called 'watch' on the alarm? otherwise you will not get events.
    Thank you Jan - It works now. I didnt know the Watch
    • 3 years later...
    This is a fantastic thread! Seeing all those ideas for the custom alarm system, especially the work on the ER4 and QuickApp logic, is exactly what the HC3 community needed.
    If the goal is a truly "generic" system that feels professional, I think the most important (and currently missing) feature is a clean way to handle Temporary Exclusions / Bypassing.
    We need an easy way to mark a window sensor (that we want to leave open at night) as ignored before arming the system, and have the interface visually confirm that bypass. Without that, it's LUA scenes all the way!
    You can also try this tool for free.
