Somfy RTS & Danfoss Ally (Zigbee) Compatibility w/ Yubii Home
Federico_L
Hello everyone,
I just got in my new flat and decided to set-up my domotic apparatus starting from a Yubii Home hub.
No issues with dimmers, door/window and smoke sensors.
The problem is that my flat was pre-equipped with Somfy RTS shutters and a Danfoss Ally radiator hub (Zigbee protocol), which unfortuantely are not comatible with the Z-Wave protocol.
I have been looking around to understand what could be the easiest course of action to controll all devices from my Yubii Home box.
From my understanding, either a Jeedom or an Eedomus hub, along with a RFXCom module, should do the trick for both the shutters (hence the RFXCom module) and the radiator hub.
As I'm not an expert however, I was hoping that someone here could either confirm the above makes sense or propose an alternative course of action.
Thank you in advance for your help!
