This QuickApp monitors your Solax managed Solar Panels
The QuickApp has (child) devices for Solarpower/m², Today production, Total production, Total Power to Grid, Total Energy to Grid, Energy from Grid, Total Power/m², Battery Energy, AC Power R, AC Power S, AC Power T, Battery Power, Power DC1, Power DC2, Power DC3 and Power DC4
The rateType interface of child device Today Energy is automatically set to "production"
The readings from the child device Today Energy will be shown in the new energy panel
The readings from the child device Total Energy is automatically set to the right Wh unit (Wh, kWh, MWh or GWh)
See API documentation on
User can get a specific range of information through the granted tokenID. Please obtain your tokenID on the API page of Solaxcloud for free.
The tokenID can be used to obtain real-time data of your inverter system. The obtain frequency need to be lower than 10 times/min and 10,000 times/day.
Version 3.0 (19th February 2023)
  • Changed the descriptions of the Solax Cloud values
  • Converted the feedinpower value from positive to negative or from negative to positive
  • Added translation for English, Dutch and Portugese
  • Added child device for consumeenergy
Version 2.1 (4th December 2022)
  • Prevented almost empty responses like these: {"success":false,"exception":"Query success!","result":"this sn did not access!"}
  • Added log text to main device if no data from Solax Cloud
Version 2.0 (16th April 2022)
  • Added Child Devices for feedinpower, feedinenergy, consumeenergy, feedinpowerM2, soc, peps1, peps2, peps3, batPower, powerdc1, powerdc2, powerdc3, powerdc4
  • Added all values returned from the Solax Cloud to the labels
  • Changed all the device types to the most current ones
  • Changed the handling of bad responses from the Solax Cloud
  • Replaced null values in responses with 0.0
  • Optimized some code
Version 1.0 (17th November 2021)
  • Tested, ready for release
Version 0.2 (15th November 2021)
  • Changed json response
Version 0.1 (13th November 2021)
  • First (test) version
Variables (mandatory):
  • tokenId = token ID of your Solax Inverter, obtain your tokenID on the API page of Solaxcloud for free
  • inverterSN = Unique identifier (Serial No.) of your Solax inverter
  • solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m² (default = 0)
  • interval = The default is 300 seconds (5 minutes), the daily API limitation is maximum 10 times/min and 10,000 times/day
  • debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
/monthly_2021_11/solax_icon_transp.png.f9c734692fbdaca53d5e05ad76976073.png" />
API items: Description (Accuracy) (Unit)
  • inverterSN: Unique identifier of inverter (Serial No.)
  • sn: Unique identifier of communication module (Registration No.)
  • acpower: Inverter.AC.power.total (1) (W)
  • yieldtoday: Inverter.AC.energy.out.daily (0.1) (KWh)
  • yieldtotal: Inverter.AC.energy.out.total (0.1) (KWh)
  • feedinpower: Grid.power.total (1) (W)
  • feedinenergy: Grid.energy.toGrid.total (0.01) (KWh)
  • consumeenergy: Grid.energy.fromGrid.total (0.01) (KWh)
  • feedinpowerM2: Inverter.Meter2.AC.power.total (1) (W)
  • soc: inverter.DC.battery.energy.SOC (1) (%)
  • peps1: Inverter.AC.EPS.power.R (1) (W)
  • peps2: Inverter.AC.EPS.power.S (1) (W)
  • peps3: Inverter.AC.EPS.power.T (1) (W)
  • inverterType: Inverter type, details refer to Table 4 in appendix
  • inverterStatus: Inverter status, details refer to Table 5 in appendix
  • uploadTime: Update time (format 2016-10-26 17:33:01)
  • batPower: Inverter.DC.Battery.power.total (1) (W)
  • powerdc1: Inverter.DC.PV.power.MPPT1 (1) (W)
  • powerdc2: Inverter.DC.PV.power.MPPT2 (1) (W)
  • powerdc3: Inverter.DC.PV.power.MPPT3 (1) (W)
  • powerdc4: Inverter.DC.PV.power.MPPT4 (1) (W)
Download the QuickApp here (download the file and un-zip):
or from the Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
Edited by SmartHomeEddy
Very good news, I'm going to try it, I also have a solax.
which one is for concumption and which one is for production ? I have put this but i'm not sure :
/monthly_2023_02/image.png.cbda4fc6032317feb68bcadfa277c116.png" />
    Hi @esolma
    The child device "Today energy" is a production value (kWh) and can be used in your HC3 Energy Panel.
    For consumption, it depends on what other devices you have that can supply values to the Energy Panel. In the Solax QuickApp there are two child devices for consumption (kWh):
    - feedinenergy: Grid.energy.toGrid.total (0.01) (KWh)
    - consumeenergy: Grid.energy.fromGrid.total (0.01) (KWh)
    You could also insert Watt values voor instantaneous power, you can see the value on top of your Yubii app. For consumption:
    - acpower: Inverter.AC.power.total (1) (W)
    And for production:
    - powerdc1: Inverter.DC.PV.power.MPPT1 (1) (W)
    - powerdc2: Inverter.DC.PV.power.MPPT2 (1) (W)
    - powerdc3: Inverter.DC.PV.power.MPPT3 (1) (W)
    - powerdc4: Inverter.DC.PV.power.MPPT4 (1) (W)
    (I don't own a Solax inverter, so I can't see what values from the Solax cloud there actually are)
    You could compare the values for production and consumption with your Solax mobile app to get the right settings.
    Actually I have this :
    And in logs :
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: Response data: {"success":true,"exception":"Query success!","result":{"inverterSN":"*******","sn":"*******","acpower":4595.0,"yieldtoday":22.3,"yieldtotal":342.6,"feedinpower":0.0,"feedinenergy":0.0,"consumeenergy":0.0,"feedinpowerM2":null,"soc":null,"peps1":null,"peps2":null,"peps3":null,"inverterType":"16","inverterStatus":"102","uploadTime":"2023-02-20 14:15:12","batPower":null,"powerdc1":2418.0,"powerdc2":2470.0,"powerdc3":0.0,"powerdc4":null,"batStatus":null}}
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: getValues() - Get the values from json file
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: Start solarPower() - Calculate Solar Power per m²
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: Start unitCheckWh() - Set the measurement and unit to kWh, MWh or GWh
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: updateLabels() - Update the labels
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: Current Power: 4595 Watt Solar Power/m²: 117.82 Watt/m² (39 m²) Today Energy: 22.3 kWh Total Energy: 342.6 kWh Total Power/m²: 0 Watt/m² Total Power to Grid: 0.00 Watt Total Energy to Grid: 0.00 kWh Energy from Grid: 0.00 kWh Battery Energy: 0 % Battery Power: 0 Watt AC Power R: 0 Watt AC Power S: 0 Watt AC Power T: 0 Watt Power DC1: 2418 Watt Power DC2: 2470 Watt Power DC3: 0 Watt Power DC4: 0 Watt Inverter Type: unknown Inverter Status: Normal Mode Last update: 20-02-2023 14:15
    [20.02.2023] [14:17:21] [DEBUG] [SOLAX MONITOR ID:351]: updateProperties() - Update the properties
    Thank you for your help Eddy !
    Looks OK.
    You have some null values in the response. Those are for the battery values. You could hide some child devices, if that annoys you. (Don't delete them)
    The null value for feedinpowerM2 is replaced by the QuickApp calculation with the m2 solar power.
    If the sun goes down and you use energy, other values should appear in the child devices.
    Ok thank you very much !
    5 hours ago, SmartHomeEddy said:
    Se ve bien.
    Tiene algunos valores nulos en la respuesta. Esos son para los valores de la batería. Podrías ocultar algunos dispositivos infantiles, si eso te molesta. (No los elimines)
    El valor nulo para feedinpowerM2 se reemplaza por el cálculo de QuickApp con la energía solar m2.
    Si el sol se pone y usas energía, deberían aparecer otros valores en los dispositivos secundarios.
    It depends on which version of firmware the inverter has... if it's something old when it's not there, the inverter turns off and stops registering values, mine for example is like this, this year's you can view both day and night, I'm trying to make it work but I can't, I suppose I have to create the variables in the GENERAL tab of HC3, because putting my touch on the web responds to me.
    Eddy,
    If I put SolarMonitor as production and PowerDC* as production too... In Energie Panel on application the production is double (all powerdc and monitor are added).... And if I put one in consumption, this is not correct on consumtion panel.
    How can I correct ? Does I need to change SolarMonitor type to "other" for example ?
    But why use both for instantaneous production power? Using both will double the Watt value in you Yubii app. You should only use the main device OR powerdc1,2,3,4.
    Hello, since I updated and had to go back because half of the things didn't work, the last backup I had was not yet on the solax monitor, and I implemented it by completing the variables and creating them in the general tab of hc3, so I don't know It returns values, by url with the touch it does give me values, any idea what could be happening?
    Hi @PedroChacon
    I think, hope, I understand your situation.
    The tokenId should be something else, not an URL. Only the token should be there. I see something in your pictures, you can check your token on:
    Use the quickapp variables (not general variables).
    btw you can test your token and serial number with this URL:
    (replace token and serial with yours)
    Thank you very much, the error was that you only have to put the tokenid and in the serial number you have to put the eñ of the communications card...not the one of the inverter, but it is already working perfectly, thanks again.
    Ah, great to hear it works
    On 20. 2. 2023 at 14:21, esolma said:
    Vlastně mám toto :
    A v logu :
    [20.02.2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: Údaje o odpovědi: {"success":true,"exception":"Dotaz byl úspěšný!","result":{"inverterSN ":"*******","sn":"*******","acpower":4595.0,"yieldtoday":22.3,"yieldtotal":342.6,"feedinpower":0.0, "feedinenergy":0.0,"consumeenergy":0.0,"feedinpowerM2":null,"soc":null,"peps1":null,"peps2":null,"peps3":null,"inverterType":"16", "inverterStatus":"102","uploadTime":"2023-02-20 14:15:12","batPower":null,"powerdc1":2418.0,"powerdc2":2470.0,"powerdc3":0.0," powerdc4":null,"batStatus":null}}
    [20.02.2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: getValues() – Získejte hodnoty ze souboru json
    [20.02.2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: Spustit solarPower() – Vypočítat solární výkon na m²
    [20.02.2023] [14:17:21] [LADĚT] [SOLAX MONITOR ID:351] : Start unitCheckWh() - Nastavte měření a jednotku na kWh, MWh nebo GWh
    [20.02.2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: updateLabels() - Aktualizujte štítky
    [20.02. 2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: Aktuální výkon: 4595 Watt Solární výkon/m²: 117,82 Watt/m² (39 m²) Dnešní energie: 22,3 kWh Celková energie: 342,6 kWh Celkový výkon /m²: 0 Watt/m² Celkový výkon do sítě: 0,00 Watt Celková energie do sítě: 0,00 kWh Energie ze sítě: 0,00 kWh Energie baterie: 0 % Výkon baterie: 0 Watt AC výkon R: 0 Watt AC výkon S: 0 Watt AC Výkon T: 0 Watt Výkon DC1: 2418 Watt Výkon DC2: 2470 Watt Výkon DC3: 0 Watt Výkon DC4: 0 Watt Typ měniče: neznámý Stav měniče: Normální režim Poslední aktualizace: 20-02-2023 14:15
    [20.02.2023] [14:17:21] [LADĚNÍ] [SOLAX MONITOR ID:351]: updateProperties() – Aktualizujte vlastnosti
    Děkuji za pomoc Eddy!
    Hi, I have a question, does it show the current consumption of the house/load, i.e. what is consumed by the house solar + grid? I only found the one where the solar production is read. Thank you
    I don't quit understand your question, but I don't use the Solax Inverter myself, so I don't have any reference. Maybe other Solax users can give an answer?
    El 20/4/2024 a las 11:02, petro_cz dijo:
    Hola, tengo una pregunta, ¿muestra el consumo actual de la casa/carga, es decir, qué consume la casa solar + red? Solo encontré aquel en el que se lee la producción solar. Gracias
    You can only see if you are consuming from the network or exporting to the network, but in no case know the consumption of your home (lighting, appliances...etc) in general.
    I think you need a kWh meter to measure that. Unless all of your appliances measure consumption.
    On 22. 4. 2024 at 21:05, SmartHomeEddy said:
    Myslím, že k měření potřebujete měřák kWh. Pokud všechny vaše spotřebiče neměří spotřebu.
    The power plant has a wattmeter of course, here is the data with the cloud. Why aren't they in fibaro? Thank you
    I still have the issue with this QA.
    Anyone managed to get through?
    I have tokenID according the API in solaxcloud.com and in the SN field I have pocket LAN/WIFI ID.
    [SOLAX MONITOR ID:485]: Response data: {"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"XXXXXXXXX","success":false}[26.08.2024] [08:38:59] [WARNING] [SOLAX MONITOR ID:485]: Temporarily no production data from Solax Cloud
    Hi @Lucano99
    Sounds like an authorisation issue. You say LAN/WIFI ID in the serial number field?
    According to the documentation (
    ) the Serial number should be from here (registration number, communication module):
    /monthly_2024_08/image.png.716ace05541bf8ab1e36bcc4ee00ac21.png" />
    Next to the serial number, token there also should be the right inverterSN (Unique identifier of inverter (Serial No.))
    I think with the right serial number, it will work. Please let me know if that is the solution.
