Good morning Jan,
I just finished to convert my light QA into HUE V2 therefor I have ER QA and:
     add "To use this there is a small Hue client library that needs to be included in the QA"
    end the  part what starts with loal devices
Color setting done with x,y
Some questions:
Can I set or change color if HUE light is off?
Devices are local so I must remove all devices from Home Table?
Must I create  child devices or can I switch on, off change color without the child devices?
Error;
fibaro.call(uid,"turnOff"[,transition]) contain a typo fibaro.call(uid,"turnOff",[transition]) in your commands
Thanks in advance for your valuable advice!
Edited by Sjakie
error added
  • 3 weeks later...
Jan I layed my hand on some HUE lamps and bridge so now I can test your new HUE_Connector.
From HUE_Connector I see the list with devices
If I use in the client QA Fibaro.call I can see a light is switching on, hehe
How to control the Hue lights within ER?
How I create child devices, manually for each lamp?
Please advice
REMARK:
If name in HUE-App will be changed you don't get the new name in Hue-connector if click on list button>>only delete QA and reinstall
Edited by Sjakie
remark added
    Please advice
    REMARK:
    It's a bit on pause as I'm awaiting bug fixes/features in the Hue v2 API.
    Jan, I need end of December operational HUE lights in my appartement.
    How to do:
    1-can I stay on the old version HUE?
    2-or is it just as with my present bridge a forced update?
    3-if 1- is true no problem at all to wait till you are ready
    4-manual operating all lights at home
    Please advice
    How to do:
    Please advice
    As I understand it the hub supports both v1 and v2 until v1 is officially removed. So the old Hue QA should work too.
    Ok great thanks for your answer.
    Question (again)
    How I can restart my client QA Hue by ER rule?
    If this is possible then I can switch of all my lights temporary.
    I don't see my Syncbox, Huesensor is also activated and tells me connected to 2045
    Thanks for your  valuable advice.
    Edited by Sjakie
    found how to restart QA
    I don't have a sync box so I don't know what type that is. So I would assume it's not supported.
    I have pushed v0.15 of HueConnector with some minor fixes.
    Aha, thanks.
    error
    Also in latest version
    If I click print devices
    Bridge software1.53.1953188020 (last known version)
    Edited by Sjakie
    @jgab
    I did some testing with the following example code:
    I started this getEvents function and until now for at least 12 hours the hue events are still coming in.
    This GET method seems to me a very promising way of processing the Hue event queue.
    The hub seems to time out once in a while so it's good to retry if there is a timeout/wantread response from the server.
    Also, it makes little sense to do
    instead do a json.decode on the whole response.data. If there is more fields then data: you may get garbage at the end...
    I did it that way because the response.data part is a string, but not in json format.
    [16.11.2022] [13:34:19] [DEBUG] [QUICKAPP204]: HueEvent@Algemeen : httpSuccess: id: 1668602059:0 data: [{"creationtime":"2022-11-16T12:34:18Z","data":[{"button":{"last_event":"short_release"},"id":"85ac2939-40ec-42f9-9fac-5db45372b830","id_v1":"/sensors/17","owner":{"rid":"77d3f0c1-b18e-4f40-b4b0-641c83d74d52","rtype":"device"},"type":"button"}],"id":"3b365597-c24c-4d8f-a107-1d34c8cebc90","type":"update"}]
    It seems to me that just the data substring is in json format and according the hue v2 documentation every event has an id and data part.
    (By the way: the hue44 in the URL of my previous post is of course the hostname of my hue bridge)
    It's json format
    I don't agree.
    When I first skip the initial Hi response from the bridge then a json.decode(response.data) gives the following error:
    [16.11.2022] [15:26:01] [ERROR] [QUICKAPP204]: /usr/share/lua/5.3/json/decode/state.lua:175: Cannot set key on array.
    Sorry, I didn't see your http headers.
    Yes, if you put
    Accept = "text/event-stream"
    you will kind of get an http stream, the problem is that the intention is that you should keep the connection open and continuously read from it. Something we can't do with net.HTTPClient (could code our own http get using net.TCPClient though). It's also a stream protocol that is more than just the json data and that is what you try to skip.
    It becomes a bit messy if you repeatedly do GET requests. I'm a bit surprise that the hub sort of continue to send requests and doesn't restart with an "hi"
    If you debug the responses you get you will see that you get a lot of empty responses if you poll quickly.
    If you want to do this (will probably put a strain on the hub) you should match with balanced brackets to get the json part. Ex.
    What I thought you did was set Accept to the default application/json. Then you will get the pure json response and not the stream data.
    The advantage is that the requests will hang if there are no events (up to timeout) and return immediately when events are available. It's pretty efficient and close
    to what we get with /refreshStates on the HC3.
    You can see how I done it in HUEv2Engine.lua.
    Thanks for the reply.
    I don''t understand what you mean by multiple GET requests, quickly polling and empty responses.
    In my opninion I do just one single GET and the success function keeps processing (for many hours) all the incoming events. There are null empty responses.
    net.HTTPClient does keep the connection open, but I agree that some error control is necessary to restart in case the connection is broken.
    Dang, you are absolutely right. I made the mistake of running it in my emulator first (where net.HTTPClient doesn't handle streams) and then never correctly verified it on the HC3.
    I have never seen this behaviour net.HTTPClient ever before (calling the success handler repeatedly) and that's why I was so (wrongfully) sure of myself...
    ...but it seems there is support for "text/event-stream" to get this behaviour... (maybe it was added when they added websockets?)
    Anyway, this makes it even more efficient to poll for events from the hub. However, it may close once in a while (in the Hue forum there are complaints) so it may be worth restarting it from the error handler.
    Thanks!
    /J
    OK, i am  working on better error handling. My last started connection is now open for more than 24 hours, so it seems pretty stable. I let  it run in parallel with the curl command as stated in the event section of the core concepts chapter in the Hue V2 documentation .
    curl --insecure -N -H 'hue-application-key: <appkey>' -H 'Accept: text/event-stream' https://<ipaddress>/eventstream/clip/v2
    Hue documentation says this is the recommended method of getting the status updates.
    Learned from the differences that sometimes there are more events in a single event-message. Catching all events now.
    • 1 month later...
    Jan, the best wishes and good health for 2023.
    My HC3 is running in the new apartment.
    I face the error if if press print devices
    If I list all devices I get this as result:
    What you have listed as example I don't see in my HUEconnector
    Please advice
    Edited by Sjakie
    remark COH removed
    • 4 weeks later...
    Jan, I have added in our kitchen a Zigbee lamp added on the HUE bridge.
    I can not find it when I list HUE lights
    Can you add?
    Info from HUE app:
    Color temperature light
    Fab: Rexense
    Model:AG0002
    Software: 20220326
    Thanks in advance
    @jgabIs this posible or do you need more info?
