daviddomsodi 0
I have climate shcedule problems with hc3. Now I use HC3 (now 5.140, had the same issue before with previous firmwares too), Heatit z-temp2 thermostat, fibaro relay module.
My problem:
I can clearly see that the issue is caused by the virtual device Thermostat& Heating zone (plugin used for manual mode). We use the heating in schedule mode, at every temperature change has the same strange thing.
For example: From 4-6 pm we ask for 18 celsius, than 6-7pm we ask for 21 celsius, from 7pm again 18celsius. Now at 6pm every time the schedule mode sets the 21 celsius but immidiately after the manual mode turns on (without manually use, we do not touch the thermostat nor the application or anything for climate change) and gives again the 21 pm but with the plugin's parameter it stays for 4hours. So instead of 7pm 18 celsius the system stays on 21 for 3 more hours...
Btw... I have so much trouble with HC3. The lights, scenes, heating. It has so many problems... With HC2 everything works just fine and HC3 I have issues from the beginning. I use it since about 6 months and had no sollution for many problems.
Hope someone can help me, cause I need to solve this heating problem asap. Thank you!
5 answers to this question
