jgab 2,656
Here is a link to a set of QAs to control Shelly devices.
There are a lot of devices that are potentially supported but not all have been tested. Please give us feedback here or in
so we can come out with an 1.1 update...The suite contains 5+1 different QAs that each support different Shelly devices.
The devices tested, and devices not tested but we expect they could work are:
ShellyMultiDevice v1.0
com.fibaro.deviceController + child devices
Supported Shelly devices:
- Shelly 3EM (Gen1). Note: untested
Children:
- com.fibaro.binarySwitch
- com.fibaro.energyMeter
- Shelly EM (Gen1). Note: tested
Children:
- Shelly Plus 2PM (Switch) (Gen2). Note: tested
Children:
- Shelly Pro 2 (Gen2). Note: untested
Children:
- Shelly Pro 2M (Switch) (Gen2). Note: tested
Children:
- Shelly Pro 3 (Gen2). Note: tested
Children:
- Shelly Pro 4PM (Gen2). Note: tested
Children:
Supported HC3 QuickAppMethods:
- <com.fibaro.binarySwitch>:turnOn()
- <com.fibaro.binarySwitch>:turnOff()
- <com.fibaro.binarySwitch>:toggle()
ShellySingleColor v1.0
com.fibaro.colorController
- Shelly Color Bulb (Gen1). Note: tested, only color mode for now
- Shelly RGBW2 Color (Gen1). Note: tested
- QuickApp:turnOn()
- QuickApp:turnOff()
- QuickApp:setValue(val)
- QuickApp:setColor(r,g,b,w)
- QuickApp:startLevelIncrease()
- QuickApp:startLevelDecrease()
- QuickApp:stopLevelChange()
ShellySingleCover v1.0
com.fibaro.rollerShutter
- Shelly Plus 2PM (Cover) (Gen2). Note: tested
- Shelly Pro 2M (Cover) (Gen2). Note: tested
- QuickApp:open()
- QuickApp:close()
- QuickApp:stop()
- QuickApp:setValue(value)
ShellySingleDimmer v1.0
com.fibaro.multilevelSwitch
- Shelly Dimmer 1 (Gen1). Note: tested
- Shelly Dimmer 2 (Gen1). Note: tested
- Shelly Vintage (Gen1). Note: tested
- QuickApp:turnOn()
ShellySingleSwitch v1.0
- Shelly 1 (Gen1). Note: untested
- Shelly 1L (Gen1). Note: untested
- Shelly 1PM (Gen1). Note: tested, not working yet...TBD
- Shelly Plus 1 (Gen2). Note: tested
- Shelly Plus 1 PM (Gen2). Note: tested
- Shelly Plus Plug IT (Gen2). Note: untested
- Shelly Plus Plug S (Gen2). Note: tested
- Shelly Plus Plug UK (Gen2). Note: untested
- Shelly Plus Plug US (Gen2). Note: untested
- Shelly Pro 1 (Gen2). Note: tested
- Shelly Pro 1 PM (Gen2). Note: tested
- QuickApp:turnOn()
- QuickApp:toggle()
ShellyPlusHT v1.0
com.fibaro.temperatureSensor + com.fibaro.humiditySensor child
Edited by jgabSupported Shelly devices:
- Shelly Plus H&T (Gen2). Note: tested, experimental, only wakes up when new data is available
Children:
- com.fibaro.temperatureSensor
- com.fibaro.humiditySensor
6
5
4
Aug 2
12
Nov 28
3
Aug 3
3
Aug 12
2
jgab 10 posts
jakub.jezek 6 posts
calza 5 posts
Lukasz U 4 posts
Aug 2 2023
Nov 28 2024
Aug 3 2023
Aug 12 2025
jgab
Here is a link to a set of QAs to control Shelly devices. Please login or register to see this link. It's both gen 1 and gen 2 devices. Gen 2 devices are easier to integrate with the web s
jakub.jezek
Cool. @jgab is in plan creating QA for getting sensor data, for example energy data from Shelly Pro 3 EM or from SHelly plus H&T? BTW, playing with Energy data from Shelly Pro 3 EM via
jgab
It keeps its value but the state of the device is 'off' or false. That is indicated by the black ring. When turned on it will use the current values.... Could have been done otherwise but I didn'
44 answers to this question
