    2 hours ago, ChristianSogaard said:
    Hi Jan
    I started playing with you new project, it looks great.
    Would it support the hierarchy as EV4 ?
    QuickApp:main gets an argument 'er' that is a table with the functions. You need to pass that to the modules. Look how it's done in the beginning of QuickApp:main(er)...
    When i press the "list rules" button , i dont see any of my rules (i copied a few from my EV4) and the same when saving the rules.
    [11.11.2023] [12:08:07] [TRACE] [QUICKAPP1961]: UIEvent:  {"values":[],"eventType":"onReleased","deviceId":1961,"elementName":"listRules"}
    [11.11.2023] [12:08:07] [TRACE] [QUICKAPP1961]: Posting {"type":"UI","cmd":"listRules"} at Sat Nov 11 12:08:07 2023
    [11.11.2023] [12:08:08] [TRACE] [QUICKAPP1961]: UIEvent:  {"values":[],"eventType":"onLongPressReleased","deviceId":1961,"elementName":"listRules"}
    [11.11.2023] [12:08:08] [TRACE] [QUICKAPP1961]: Posting {"type":"UI","cmd":"listRules"} at Sat Nov 11 12:08:08 2023
    Should rules have the log added like     rule("log('Wind is %sms',weather:wind)",msgOpts)
    What's new with ER5 is that it logs system messages under ER<ID>, so look at console tag ER1961...
    (it is configurable to have all under the same tag)
    Hi Jan
    Thank you
    I created the "import" in the main section
    Reused a working rule from main in a new section, DaySchedule
    I dont this there is any typos, but getting a Rule setup error(s) - fix & restart...
    17 hours ago, ChristianSogaard said:
    Thank you
    Yes, there is no evalScript function anymore. There is 'eval' and 'rule' that are synonyms with 'evalScript'.
    If you have many rules with evalScript you can just do
    local evalScript = rule
    in the beginning of main
    I dont think i use evalScript - my goal was to make the different sections to work as i have in EV4, reusing the old syntax seems to give some issues
    Edited by ChristianSogaard
    Typo
    Change this
    to
    and then in the for loop when you call the modules
    This seems to be working, thank you Jan
    and
    Jan, on restart Qa I used this but in ER5 it does't work anymore.
    Do you get an error message? Can you see in QA 267 log if it gets an ‘onAction’ ?
    Nothing in debug it. Debug start with rules much further on
    Jan does't work in ER5
    I don't think it is working at all if I create a scene with push it does't generate message either.
    Edited by Sjakie
    added info push msg
    Both fibaro.call and fibaro.alert you can help debug yourself by trying them out in Lua outside the rules.
    Check if
    and
    works in Lua. If it works outside but not inside rule() then its a bug.
    However, for me in ER5 it works both inside and outside rules - so check your user id's and that you can receive push messages at all from Fibaro...
    ...and why do fibaro.alert?
    It's the same as
    user:msg = '1061 - Let Op; Voordeur - OPENNNNNNNNN -'
    Hi Jan
    i have some issue for migrating this start up rule
    Rule are compiled, but i dont get the trigger after reboot. to be honest, im not sure at it ever worked,
    How can i post the the result of this line or ?
        if os.time() - (api.get("/settings/info").serverStatus or 0) < 60 then self:post({type='se-start'}) end
    i tried
    rule("log(os.time() - (api.get("/settings/info").serverStatus or 0))")
    rule("log(api.get('/settings/info').serverStatus")
    and a few more versions, but no cigar
    Or did you come up with an alternative way to verify a reboot ?
    Typo
    Jan, shoot me!
    On my wifes phone she receives push messages (as default switched off)
    You are right its me. I reverted back to ER4 and there the same problem. In my phone it's enabled.
    Telegram I receive but only one scene if HC3 restarts.
    Jan, push messages does't work on my phone anymore.
    I checked my wifes phone and she receive them without any problem.
    Telegram at re-start I fixed with test3 followed by a message
    Settings and options
    The structure of the main file in ER5 is like
    Our QuickApp's :onInit() function will create the EventRunner "engine" that knows how to define and run rules.
    When the engine is setup and ready it calls our provided callback function and hands it a variable 'er'.
    The 'er' variable is important because it's a Lua table with important functions and variables we will need when
    setting up our rules.
    In the callback we can then setup general/global settings and debug preferences and other stuff.
    ...and then finish by calling self:main(er)
    So, the simple approach is to have all our rule definitions in QuickApp:main(er), but we can put rule definitions them in other QA files to.
    Ex. if we define a QA file 'u_myrules' (name is not important but u_ prefix is required)
    we can then define our "module" like this
    and the rule(seller) function will be called in the priority order we specified (lower priority called first)
    Per default, the QuickApp:main(er) function has priority 0 so we can load modules before by giving them priority < 0.
    We can also leave out QuickApp:main(er) and only load rules from our own modules. In this way we can keep the main QA file untouched and make it easier to upgrade the main file (it needs to be upgraded "manually" as the QAUpdater don't touch the main file)
    So, there are a lot of settings and debug flags we can set
    Global debug flags that can be overridden by individual rules using ruleOptions
    er.debug.ruleTrigger = false -- log rules being triggered
    er.debug.ruleTrue = true -- log rules with condition succeeding
    er.debug.ruleFalse = true -- log rules with condition failing
    er.debug.ruleResult = false -- log results of rules running
    er.debug.evalResult = true -- log results of evaluations
    er.debug.post = true -- log events being posted
    er.debug.sourceTrigger = false -- log incoming sourceTriggers
    er.debug.refreshEvents = false -- log incoming refreshEvents
    Global settings - affects EventRunner behaviour in general
    er.settings.marshall = true -- autoconvert globalVariables values to numbers, booleans, tables when accessed
    er.settings.systemLogTag = "ER"..self.id -- log tag for ER system messages, defaults to __TAG
    er.settings.ignoreInvisibleChars = false -- Check code for invisible characters (xC2xA0) before evaluating
    er.settings.truncLog = 100 -- truncation of log output
    er.settings.truncStr = 80 -- truncation of log strings
    er.settings.logFibaro = true -- log to fibaro.call, fibero.setVariable, etc.
    er.settings.logApi = true -- log all api.* calls
    er.settings.bannerColor = "orange" -- color of banner in log, defaults to "orange"
    er.settings.listColor = "purple" -- color of list log (list rules etc), defaults to "purple"
    er.settings.statsColor = "green" -- color of statistics log, defaults to "green"
    er.settings.userLogFunction = function(rule,tag,str) return fibaro.debug(tag,str) end -- function to use for user log(), defaults to fibaro.debug if nil
    The er.settings are global and affect all rules, and so is er.debug.
    However, debug info can also be passed to individual rules together with some other options that can be useful to tailor the behaviour of the rule.
    Ex, if we want a rule/expression to always log in green we can define
    The 'silent' option makes the output of rules/expression less noisy. Especially it doesn't log the result of an rule/expression.
    So, ex. typically we may want to run expressions that just output messages in the console when the rules are created.
    Options allow us to silent the extra result logs of these expressions and also give them a distinct color
    In fact, we can easily define our own expressions function that just evaluates an expression without noise...
    and use that to evaluate expression and log messages in the console.
    v0.05 pushed....
    - Lots of bugfixes
    - Alarm handling in place
    - Support for "speed running" ER to debug scheduled rules
    Alarm rules
    Alarm in the HC3 is implemented by Fibaro using the concept of partitions.
    Partitions are armed and disarmed. Individual devices (typically sensors) belongs to partitions
    and if a devices is breached that belongs to a partition, the partition is breached and we have an alarm.
    In ER5 we have properties to query partitions for their state
    <partition>:armed - returns true if the partition is armed - 0 means the house
    <partition>:tryArm - will try to arm the partitions - 0 means the house
    <partition>:isArmed - returns true if the partition is armed - 0 means the house
    <partition list>:isAllArmed - returns true if all partitions are armed
    <partition>:isDisarmed
    <partition list>:isAnyDisarmed - returns true if all partitions is disarmed
    <partition>:isAlarmBreached
    <partition>:isAlarmSafe
    <partition list>:isAllAlarmBreached - returns true if all partitions are breached
    <partition list>:isAnyAlarmSafe - returns true if any partitions is safe
    and properties to change the alarm states
    <partition>:armed=true - arms the partition - 0 means the house
    <partition>:armed=false - disarms the partition - 0 means the house
    <partition>:tryArm is special as it will try to arm the partition/partitions and if it doesn't succeed because their
    is a breached device in any of the partitions it will post an event that list the partitions and devices that are breached.
    Note that the arming will continue and if not cancelled, the partition will be armed and at the same time breached because of
    the breached devices.
    To handle that, one can make a rule that trigger on the posted event,
    Ex:
    To trigger a rule if there is a breached partition/home, it's easiest to trigger on the events generated (in the future there may be properties)
    Unfortunately, if a partition is armed using the web UI/Yubii app, we don't get any warning from the fibaro api before the partition is armed - maybe in the future...
    Jan, much better (and more) errors are discovered!
    Jan, a lot of errors
    Edited by Sjakie
    Yes, need to implement postRemote...
    Do you use 'subscribe' too?
