14 hours ago, KaWi said:
Good morning,
I have been using ER5 v.1.050 for a long time. Since the last update of the HC3 to v.5.200.8, I have had problems sending a SimplePush. Now I get the following error message:
(There ist a ^ under the colon)
Does anyone have the same problem, or can someone please help me figure out what I am doing wrong?
Man, its answered right above your post.
I had searched for 'simplePush' and therefore overlooked the post. Still, thanks for your tip.
On 1/5/2026 at 8:17 AM, KaWi said:
Good morning,
Yes i have  its from the update
ER5 has been running for a long time very successfully on different HC3's.
On one of my systems, something bizarre happens. A set of rules work fine for a 6 - 7 days, and then stop working completely. IF I restart the ER5 QA, it seems to be ok again for a couple of days.
Note: Originally the rules were more complex, but even going down to a more simple phrase the issue remains.
Also
works, but has the same issue after a while.
When it happens, the whole rule does not seem to be evaluated. Looking at the log:
Where to look? Anyone else experienced this?
kind regards, Jeroen
8< - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
UPDATE MARCH 7th - 2026
With the Fibaro update  5.201 BETA the above errors do not occur anymore, beats me why.
rgds Jeroen
Edited by JeroenL
  • 4 weeks later...
@jgab Hello Jan, can we somehow postpone (delay) the startup of ER5 after system reboot??
we have several systems with ghost effects and with some other problems with boot configurations of zwvave devices, especially in systems that are big. So we want to delay the ER startup and monitor if it helps. Idea is the give zwave devices enough room and time to finish their boot config process and only then start ER5. Is it possible??
