Hello
Maybe a stupid question, but...
I have two motion sensors in my kitchen. Now, when one of them is triggered, I want the light to turn on and then turn off again after a defined time. They are an FGD-212 and FGMS-001.
Anyway. The following rule is not working properly.
What is not working? If the rule is triggered in the morning or at night, everything is fine. It does not turn off during the day or in the evening.
That's why I created this additional rule. It works and then turns the light off after the specified 4 minutes.
What am I doing wrong?? I'm starting to despair and my wife isn't really that happy either.
    7 hours ago, KaWi said:
    Hello
    Well, it becomes a bit complicated with the killOthers option. In this case every time the condition becomes true
    it will kill all waiting timers, so if you have triggered before and its waiting to turn off it will be cancelled.... which is normally what you want to do but the you have secondary conditions after || and if they are false nothing happens... and then it becomes complicated to understand what's going on.... especially as the rule can trigger positive several times in a row as
    can take turn triggering the rule positively...
    I think you should use the 2 rule example you have, like
    I can't fully grasp your secondary conditions like lux and :value<=41 but I assume you know what you do there....
    On 11/25/2024 at 8:01 PM, jgab said:
    Ok, it seems like the scene values are numbers and not strings which makes the test untrue.
    Add this in main()
    I will fix it in the next version but it may take some time...
    oki  tack så mycket  :)
    About the lux I want that the light is only turned on when it is no longer bright enough in the kitchen.
    When I turn on the light with the switch, a value of 45 is set. That's why I check with :Value<=41 whether the light was turned on manually via the switch (or with Alexa).
    Because, and this is the decisive factor, when my wife stands in the kitchen and reads in a book (and does not move) and then the light is turned off, that is very very bad for me.😉
    Thanks for your example. I will Test it.
    @jgab hello! This is my rule: Is there a simple way to use ’for in‘ while retaining the .mode ("killOthers") method
    2.and here killOthers is not useful:
    3.now i use this rule :
    Edited by lux
    @jgab Jan, a bit of help needed here.
    Goal is when cica_PIR is breached and cica_watch_active is true, we want to broadcast, but also we need to ensure that cica_watch_active is true 2 sec after the trigger, and broadcast only if its confirmed after 2 sec
    trhows
    trhows
    I tried the rule and it works without problem.
    The error message implies some unexpected character at the end of the rule. I guess it's those invisible unicode characters that can get in.
    When I'm using vscode to code the rules those characters are marked in the editor.
    Btw, I have updated vscode to generate .fqa files with he new uiView data structure so I may be able to create an EventRunner5.fqa where the UI elements don't disappear when re-saved....
    Thanks, that would be fantastic
    @jgab Jan hello. fibaroi.between should not be working in ER5? I need to test time on the action side of the rule.
    this doesnt work, or is there any equivalent to test time range on the action side? would the 18:00..22:00 format work?
    Hi all,
    I can confirm that the issue with the buttons disappearing and having 2 counters for ping is still present with 5.171.
    After rebooting there is only 1 ping report left but the buttons are still missing.
    I have also downgraded and upgraded to 1.05 but still the same.
    Waiting patiently;🫠
    Thanks for your work, @jgab☺️
    Ok, it turns out that the buttons are there but becoming invisible.
    I don't really understand why and what to do differently to avoid it.
    So a fix for the moment is to add some lines in QuickApp:onInit()
    I will soon release a new version with this "fix" incorporated...
    Perfect, it works !
    Thank you😉
    Topic: Enabling a rule does not seem to actually enable it.
    Dear all,
    My aim is to use a remote control to activate a "rule"  that turns on a heater at 22.00 to use the lower night electricty tariff. It seems to work, but it doesn't :-(
    When I press the button on the remote, output shows that " rule 21"  is enabled, but the rule doesn't actually do anything at 10:52.
    Where is my thinking wrong?
    Thanks for any suggestions. Code and log output below. As you can see in the example below, nothing actually happened at 10:52
    Dear all,
    The problem is that when you disable the rule the daily timer is canceled and it will not trigger until next day (daily timers are scheduled at midnight, and when defined).
    What you could do is force the rescheduling of the timer.
    Ex.
    Let me know if it works.
    Ex.
    Thanks @jgab, this works perfectly! Is there a downside of doing this, or not really? Reason for asking is that I want to program 5 (shoe) heaters like this.
    Copying the working output below for others on this forum:
    No, there should be no downside. In fact, I think that enable should run ._setupDailys per default. I add it next version.
    • 4 weeks later...
    @jgab, hello
    Jan, do you see any particular reason, why the closing of blinds doesnt trigger..or maybe it tirggered but blinds did not close?
    Goal is..to close all blinds (if any of them has value greater than 0) in group blind_group after wind sensor did not detect wind over 6 m/s for 12 hours..and the current profile is Away
    @jgab Jan i think the problem is that in case of blinds the blind_group:value > 0 comparison doesn't work. It says
    /monthly_2025_01/image.png.060a9be245c34224704492824488a10f.png" />
    Is that a bug? Shouldn't it be working as with other devices?
    Edited by Neo Andersson
    @jgab, I miss a digit in sunsert and dawn
    Rule:
    Rule:
    Yep, that's a bug, forgot to add a '0' prefix to the formatter function.
    Will be fixed in the next release.
    If you want to fix it now go into the file erlib and change to
    Thanks, missing digits found!
