@jgab, Normaly if open ER5 QA it will show main.
After changing in erlib some QA's by edit opens with a blanc page and I need to click on main to modify a rule.
how to correct?
All ER5 QA's open and clicked on main changed >> saved >>no fix.
Question: can I use fa wall plug = not reachable or disconnect in a rule? if yes how?
Edited by Sjakie
Dear all.
I am using a similar rule "enable / disable"  elsewhere, and there it works as expected. However I try to trigger the rule enable / disable based on a GlobalVariable, but the few lines below do not work, and I do not spot my mistake.
Any thoughts?
The error I get:
Thanks for any insights...
Jeroen
    There is a bug where chaining of .enable() at the end of the rule definition don't return the rule,
    so 'Kitchen_rule' becomes nil, and it crashes later.
    It will work if you split it up and do a separate .enable().
    Dear all,
    Another question, trying to randomize my lights, it sort of works, but it doesn't in the sense that every day timer random_time_1 is scheduled for exactly the same random time. Do I have to (re)init something somewhere?
    Thanks again for any thoughts!  Jeroen
    Example of what I tried:
    @jgab if I install a new ER5 QA how to get rid of the every 5 min ping?
    This does't work
    --[[var.i = 0 -- initialize ER variable
    rule("@@00:00:05 => i=i+1; log('ping: %s seconds',i*5)",{ruleTrue=false}) -- test rule, ping every 5 seconds
    This does't work
    yes
    13 hours ago, JeroenL said:
    Dear all,
    You shouldn't need to call _setupDailys here....
    The problem is that when the QA starts/restarts the number generator is initialized with the same starting values.
    If you would let it run, without restarting the QA, for several days you would see different values.
    However, you can initialize the random generator with a "random" seed when the QA is started
    On 1/29/2025 at 7:23 PM, JeroenL said:
    Dear all,
    Thanks again for any thoughts!  Gerona
    So, the rnd function takes either 1 argument or 2 arguments. With 2 arguments it returns a random value between the arguments/values.
    So, if you want a random time around 22:45, ex +/- 15 minutes you can write
    The @ rules will be scheduled every midnight (00:00) for the day to come. In this case it will compute
    and schedule a timer for that time. Next midnight it will compute a new time.
    • Like 3
    • 1 month later...
    @jgab, goodmorning,
    Jan I am still a happy camper with ER it's doing what is should do!
    What's the difference between doing a restart HC3 by the menu at the top and
    Since the last fw I notice a big difference
    Restart by menu brings used memory back to 44%-45%
    Restart by hc3api...... lowers memory with around 4%-5%
    Never has seen this before, okay it is the fw but what can you change in the hc3ap?
    Thanks in advance!
    Edited by Sjakie
    typo
    • 1 month later...
    @jgab I notice a strange thing in debug.
    @06:33:49 No occupation in kitchen
    @ 07:01:14 >> occupation in kitchen (radar detect)
    @ 07:01:16 >> kitchen door open
    Remark to have occupation in the kitchen I should first open the kitchen door to get in and make the radar to detects me.
    It's a 2 second difference. ER looks at the system events in the order they arrive. Could it be that the door sensor was a bit slow to report in?
    How does rule 91 and 93 look like?
    rule 91:
    rule 93:
    In general, you have to be careful to write rules like this
    Because, A can happen (ex. sensor breached), then later B happens, but A is still true (still breached), so you will run || A >> ...
    even though it was B that triggered the event.
    Rules with a lot of "OR" tests in the guard is generally very tricky to get right, unless you don't care what OR condition is true. But here you do as you do different logs depending on which OR condition is true...
    I have just switched to Eventrunner5.
    1. Previously, when a certain rule was completed, I received app notifications using the msg command.
    However, since the app has been changed to Yubii Home, I no longer receive any notifications.
    Is there a way to make it work?
    2. I want to display a message like "Status" under the icon.
    In ER4, I used the command:
    rule("$PresentState=='Home' => QA:setIconMessage('Status:Home')")
    However, this no longer works in ER5.
    Is there a way to achieve the same functionality?
    • 1 month later...
    @jgab I have a new seperate installation  with 2 ER QA's and both have this error;
    Hi Jan,
    Quick question, I may have overlooked this topic, but I do not find the possibility to create rules based on "custom events"...
    Like the below example.
    Basically I would like to do some action when the Custome event "DBBell" is triggered.
    With trial and error, it seems I've found the syntax:
    Thanks.
    Edited by ClaudeH
    You should be able to trigger on it like a sourceTrigger event
    Just make sure that the customEvent DBBell is defined.
    Can't figure out what's wrong with a trueFor rule (excuse the liberal debug logging):
    rule([[
            @{sunset+01:00, 23:00, 00:00, 01:00, 02:00, 03:00}
            log("*** Shutters_Sunset_Terrace_Close ***");
            log("   Last: %s ***", HM(Terrace.Door:last));
            if Terrace.Shutter:isOpen then
                log("       Shutter Open");
                if trueFor(03:00, Terrace.Door:safe) then
                    log("       Closing Shutter (3h)");
                    764:msg={title='Fibaro', message='Terrace closing in 5 mins (3h)'};
                    wait(00:05);
                    Terrace.Shutter:close
                else
                    log("       Conditions Not Met")
            else
                log("       Shutter Closed")
        , {ruleTrue=true, ruleFalse=true}
        ).name("Shutters_Sunset_Terrace_Close")
    It is closing the shutter when door has been "safe" for less than 3h:
    [2025-08-09] [21:30:00] [DEBUG] [QA_ER5_693]: *** Shutters_Sunset_Terrace_Close ***
    [2025-08-09] [21:30:00] [DEBUG] [QA_ER5_693]: Last: 02:19 ***
    [2025-08-09] [21:30:00] [DEBUG] [QA_ER5_693]: Shutter Open
    [2025-08-09] [21:30:00] [DEBUG] [QA_ER5_693]: Closing Shutter (3h)
    [2025-08-09] [21:30:00] [TRACE] [QA_ER5_693]: [Rule:Shutters_Sunset_Terrace_Close:9]>> suspended action - wait 00:05:00
    trueFor needs to be on the left side of the =>, it's a condition test.
    I would split it up like this:
    However, at sunset+01:00, 23:00, 00:00, 01:00, 02:00, 03:00, it starts a watch that if the shutter is open and the door is safe for 3 hour it will close the shutter.
    If we run it at 01:00 and shutter is open and door is safe it will continue to "watch" until 04:00 when the condition will be true and it will close the shutter...
    So why run it 02:00, 03:00 etc?
    Maybe you want to not check for certain periods during the day? Then make a test that you are in the right time period?
    Is it what you want to do?
    Thanks @jgab. I hadn't understood that conditions can't be tested outside the conditions block, nor the way time triggers work. I'd worked around it by testing Terrace.Door:last instead.
    Purpose it to close the shutter if I've forgotten, but not if I'm potentially sat outside without my phone to repopen it 🫣
