@jgab Hello Jab,
How to use anonymus functions in a rule, or how else to use a callback mechanism inside  a rule?
I have a simple function that makes http post and it should return a simple text.
Edited by Neo Andersson
    Btw, I'm almost done with my new
    , so I have started to develop EventRunner6 as a way to test the emulator.
    It's keeping the basic syntax and features of EventRunner5 but is half the size and twice the speed :-)
    (I moved away from compiling eventscript to my own virtual machine, and now compile to Lua functions using a
    It's coming along well, and has most features in place, but still need some tweaking...
    • Like 4
    I am looking forward to replace it in all of my installations, if the speed is doubled, the size is halfed..so maybe this will solve the ghost processes, that are caused probably by the large size of the QA
    Well, I have started to run EventRunner6 for my own automation (I don't have that much to automate these days...)
    But it's humming along. The autoupdates and some cosmetic in logs and error messages are still missing.
    It clocks in on 133kb now.
    Repo <
    > (if you want to test early versions). If you have a working ER5 there is no hurry.
    And documentation here:
    Repo <
    > (if you want to test early versions). If you have an working ER5 there is no hurry.
    ERť is running fine so far..so i will wait for the final version.
    Jan
    logs me this correclty
    { January = "16:45", February = "17:30", March = "18:15", April = "19:45", May = "20:30", June = "21:15", July = "21:00", August = "20:15", September = "19:15", October = "18:00", November = "16:30", December = "16:00" }
    but this
    logs me nil
    According to the documentaion it should work
    Another feature with GVs is that they auto-convert their results. Normally, we can only store strings in GVs
    but ER we can store any value that can be json.encoded.
    Ex.
    This will json.encode the table before storing it in the GV.
    The opposite, when we access a value in a GV it will convert it back to a table in this case
    Here myTable returns {a = 42, b = 17} and then we access the .a key from that table.
    This is also true for booleans and numbers.
    1 hour ago, Neo Andersson said:
    Jan
    I don't get your result. How do you store the table in the GV?
    Ah, it's EventRunner5.
    Well, the same code produces the right output for ER5 too
    How do you store the table in the first place?
    i stored the table like this in GV
    {January="16:45",February="17:30",March="18:15",April="19:45",May="20:30",June="21:15",July="21:00",August="20:15",September="19:15",October="18:00",November="16:30",December="16:00"}
    it logs the full table correctly, but $LIGHT_ON_TIMES.January is nil
    How stored? using eventScript? or as the string in your example?
    The syntax above is lua table syntax and that is not json.
    {"February":"17:30","January":"16:45","December":"16:00","March":"18:15","May":"20:30","July":"21:00","April":"19:45","November":"16:30","October":"18:00","September":"19:15","June":"21:15","August":"20:15"}
    needs to be stored in the GV for ER to recognize it as json.
    The lua table is automatically converted to json if you do
    rule("$LIGHT_ON_TIMES = { January = '16:45', February = '17:30', March = '18:15', April = '19:45', May = '20:30', June = '21:15', July = '21:00', August = '20:15', September = '19:15', October = '18:00', November = '16:30', December = '16:00' }")
    or
    var.myGV = { January = '16:45', February = '17:30', March = '18:15', April = '19:45', May = '20:30', June = '21:15', July = '21:00', August = '20:15', September = '19:15', October = '18:00', November = '16:30', December = '16:00' }
    rule("$LIGHT_ON_TIMES = myGV")
    Stored manually as i showd above. I thought ER5 handles it even if i store it as a LUA table format, but apparently i ned to store it as a JSON string using string keys : value syntax..
    Okay i will change it
    • 1 month later...
    Hello Jan
    I have a lua table type fibaro global variable. I store there some infos about speakers.
    I am using speaker's IPs in ER5 but for some reason, it fails to assign speaker ips to rule vars if i use it like this
    it works only like this
    the second approach is okay as far i dont change the fibaro global. I think it wont update in the second case.
    I want to initialize the rule speaker vars on startup and update them when the fibaro global changes.
    What am i missing??
    Hello Jan
    What am i missing??
    The reason is that rule(...) defines the rule, but .start() will run the rule asynchronously - like we had done a wait(0) before starting it.
    This means that rules never runs until we return from main().
    Expressions, rule(<expr>) where expression is not a rule (no '=>') are executed immediately.
    So,
    So, this will log nil as the first rule has not run yet when the second rule, that is an expression runs.
    .start() means, run me as soon as we exit from main()....
    If we do
    It will log the ip of terraceSpeaker, because it will also delay it until we return from main(), e.g. all rules defined.
    We can use terraceSpeaker in another rule, as other rules will not run either until we return from main().
    Jan, here is another puzzle, and my hair is dropping off already,
    At 9:00 in date range (oct-apr), the shutter should go to a number from a global variable $dadShutWint_I (and the light should be off)
    but shutter goes to 80% all the time at 09:00
    and global values are anything but 80%, they are correctly set to 20% for shutter and 40% for slats. Slats get to 40% but the shutter goes to 80%.
    /monthly_2025_10/image.png.fa76b224d858763669cf76d2fc0c6969.png" />
    I have tripple checked the ER5 code. Only here are shutters accessed.
    Double checked device IDs, double checked other codes...
    Nowhere are these shutters accessed.
    Why is this happening...
    Please check it and help if you can
    thanks
    thanks
    I don't think it's ER... X:value=Y is translated to fibaro.call(X,'setValue',Y)
    and nothing special is done with the argument...
    Have you tried to just make a fibaro call to set the value?
    Could it be that the 0-100 is reversed for the shutter so 80 is 20% open?
    well, as this is in customer's house i cant test it right now, he is 300 km from me..
    the 0-100 reversed thing is kinda logical, but i have no clue how can it happen...
    Anyway i will test it personally next week. I hope i will find the reason
    Hello jan
    is that rule triggered, (is the mail being sent ) if any of the sensos got back to safe, but the other is in breached state??? Because it should not, i think. It should trigger when any of the sensors got from safe to breached, but no trigger when one is in breached and the other gets from breached to safe. My colleagues told me that they have that behaviour.
    Hello jan
    Yes, it will. The {dev1,dev2,...devn}:breached is triggered whenever any device changes state, and then the "OR" or the states is calculated, meaning that if any device is breached, the test will be breached/true.
    Trying to remember every device previous state to calculate when they go from true to false would be too much work...
    Normally, this "double" trigger is harmless, like turning on lights, but you have a side-effect, sending an email, that is not so nice to have happening twice...
    One could argue that it should only trigger when the whole expression goes from false to true, and we can achieve that.
    The once(<expr>) function will only trigger when the expression goes from false to true. The expression has to become false and then go to true again for it to become true again.
    which is probably what you want in this case?
    fantastic, really thanks
