4 hours ago, lux said:
1 second
So it should be in form 00:00:01
Thats it
18 hours ago, Sjakie said:
01:00 >> 1 hour
01:10 >> 1 hour and 10 min
00:00:01 1 sec
wait(0); in a rule means all above this wait(0) will be executed first before we contimue
Guys, switch 2 buttons on and off
press, release, hold properties
on and off no problem
but
how to write in a rule if 1:'Holddown' raise britness fa in steps with 10%
@Sjakie
This is the general pattern for the dim command
<id>:dim = { time, direction, steps, curve, startValue, stopValue }
example
Ex.
rule("@sunrise-00:30 => lamp:dim = {00:30, 'up', 5, 'Linear', 0, 99}")
    Sorry, I'm a bit busy these days. However, ER most likely have problems on the HC3L as it (used to?) have a Lua compiled for 32 bit integers.
    The problem with that is that epoch time (os.time()) is close the the 32bit limit and as soon as we start doing arithmetics with os.time() in our code
    there is a good chance for overflow.
    @lux asked for ER3 and it's true for ER5 too... (and many other QAs doing os.time() arithmetics)
    One could probably recode the arithmetic to cater for overflow but it would in general be to cumbersome...
    On 9/5/2024 at 10:01 PM, Sankotronic said:
    Hi @Neo Andersson ,
    Since this is very small table array with only 10 values, you can use LUA functions table.insert and table.remove. For example, you have table:
    To add new value to the beginning of the table:
    and table will be:
    to remove last value:
    to get:
    Why I mention that this two functions are good for small table arrays, maybe up to few hundred values? Because this function needs to move other values in the array when adding or removing one value depending on its position in the array.
    Yes, if its sequential integer values as keys it's normally stored as an array and values need to be shuffled up which takes increasingly longer.
    However, it's still very efficient.
    shifting up and down 100000 values takes 0.038339 seconds on my HC3.
    What you probably want is a fixed size queue, that is easy to implement
    ...and use it like
    This one has a fixed insert and remove time as the table is treated as a hashtable
    Hi Jan
    I'm using a Fibaro blind controller to control a venetian blind.
    If I look at the Device editing tab on EventRunner, I can see that the device has a property (-value) which sets the height of the blind, and another (-value2) which sets the slats.
    /monthly_2024_09/Screenshot2024-09-19114126.jpg.e5ef930b743419d5617d663fd36b68e4.jpg" />
    This works in the Fibaro UI, which if you translate a simple block scene into lua gives this:
    hub.call(71, 'setValue2', 30)
    hub.call(71, 'setValue', 50)
    However, if I write a simple script in EventRunner
            rule("Test", "$testDayMode == 'On' => study.southVenetians:value = 100 ; study.southVenetians:value2 = 100  ")
            rule("Test2", "$testDayMode == 'Off' => study.southVenetians:value = 0 ; study.southVenetians:value2 = 0")
    I get the following error - EventRunner doesn't recognise value2, whilst recognising value.
    [Rule:Test2:2]>> [Rule:Test2:$testDayMode == 'Off' => study.southVenetians:value = 0 ; study.southVenetians..] Runtime: :value2 is not a valid device set property for device:71
    Any idea what's happening?
    (this is a great product, by the way - many thanks for it)
    Paul
    28 minutes ago, Paul Ruskin said:
    Hi Jan
    Paul
    I think the value2 is not defined in ER5, but JGAB can comment on it. If so, either you need to create your own custom preoperty for value2, or you can just use simple LUA command to control the value2.  So you can always use the regular LUA command. hub.call(ID, setValue2, 50).
    thats my guess.
    Edited by Neo Andersson
    That does seem to work, thank you.  Though like this:
            rule("Test", "$testDayMode == 'On' => study.southVenetians:value = 100 ; fibaro.call(study.southVenetians, 'setValue2', 100) ")
            rule("Test2", "$testDayMode == 'Off' => study.southVenetians:value = 0 ; fibaro.call(study.southVenetians, 'setValue2', 0)")
    Interestingly, hub.call and fibaro.call seem to be synonomous.
    Paul
    Paul
    Yes they do the same job
    I have tried to handle an alarm breach occurring on exit from home but I am unable to get it to work even using the jgab supplied delayed event. Can anyone supply a working version for ER5? My idea was to disarm then retry arming (not tryArm). Logging follows:-
    [24.09.2024] [12:36:11] [DEBUG] [QUICKAPP128]: Time:2024-09-24T12:36:11.872061+10:00
    [24.09.2024] [12:36:11] [TRACE] [QUICKAPP128]: 'log('Time:%s',http.get('http://worldtimeapi.org/api/timezone/Australia/Sydney').datetime)' > Time:2024-09-24T12:36:11.872061+10:00 [done]
    [24.09.2024] [12:38:18] [TRACE] [QUICKAPP128]: [Rule:10:1]>> TRUE #device{id=96,valu.. -> redbutton:central.keyId==1 & redbutton..
    [24.09.2024] [12:38:18] [DEBUG] [QUICKAPP128]: ER5 redbutton was clicked 2X
    [24.09.2024] [12:38:18] [DEBUG] [QUICKAPP128]: Current profile:Home
    [24.09.2024] [12:38:18] [DEBUG] [QUICKAPP128]: ER5 The Away profile will be activated
    [24.09.2024] [12:38:22] [DEBUG] [QUICKAPP128]: ER5 About to execute tryArm
    [24.09.2024] [12:38:22] [TRACE] [QUICKAPP128]: Posting #alarm{id=0,value={11=[28]},action="tryArm",property="delayed"} at Tue Sep 24 12:38:22 2024
    [24.09.2024] [12:38:27] [TRACE] [QUICKAPP128]: [Rule:3:1]>> TRUE #alarm{id=0,value=.. -> #alarm{id='$id', property='delayed'} =..
    [24.09.2024] [12:38:27] [WARNING] [QUICKAPP128]: ER5 Partition 11 breached, devices 28
    [24.09.2024] [12:38:27] [WARNING] [QUICKAPP128]: ER5 Disarming
    [24.09.2024] [12:38:32] [WARNING] [QUICKAPP128]: ER5 Rearming
    [24.09.2024] [12:39:32] [TRACE] [QUICKAPP128]: [Rule:1:1]>> TRUE #alarm{id=11,value.. -> #alarm{id='$id', property='breached'} ..
    [24.09.2024] [12:39:32] [WARNING] [QUICKAPP128]: ER5 BREACHED partition:11
    [24.09.2024] [12:39:32] [TRACE] [QUICKAPP128]: [Rule:2:1]>> TRUE #alarm{value=true,.. -> #alarm{property='homeBreached'} => -..
    [24.09.2024] [12:39:32] [WARNING] [QUICKAPP128]: ER5 BREACHED home
    [24.09.2024] [12:39:42] [TRACE] [QUICKAPP128]: [Rule:1:2]>> TRUE #alarm{id=11,value.. -> #alarm{id='$id', property='breached'} ..
    [24.09.2024] [12:39:42] [WARNING] [QUICKAPP128]: ER5 BREACHED partition:11
    [24.09.2024] [12:39:42] [TRACE] [QUICKAPP128]: [Rule:2:2]>> TRUE #alarm{value=false.. -> #alarm{property='homeBreached'} => -..
    [24.09.2024] [12:39:42] [WARNING] [QUICKAPP128]: ER5 BREACHED home
    What cause alarm, device 28 is that a pir or radar?
    if yes should use delay to re-arm till time pir:breached change into pi:safe.
    Split arming in parts take pir's separate?
    I don't use "profile", create it by myself with Iphone.
    rule([[{room1_pir, room2:pir, room3:pir}:safe & $location == 'Away' =>
    4:armed;
    log('Away, pir safe >> partition 4 armed')
    I also have different partitions fa when we leave home sometimes certain windows are open. They will be armed at the same way as written above
    Edited by Sjakie
    Can you post your rules for the arming?
    Hi @Sjakie thanks for your reply:
    What cause alarm, device 28 is that a pir or radar? It is a motion sensor
    4:armed;
    Hi @jgab thanks for your reply:
    Cheers
    JagarMan
    rules follow:
     rule([[#alarm{id='$id', property='breached'} =>  -- Log when a partition is breached
            fibaro.warning(__TAG,efmt('ER5 BREACHED partition:%s',env.event.id))
        rule([[#alarm{property='homeBreached'} =>   -- Log when home is breached
            fibaro.warning(__TAG,efmt('ER5 BREACHED home'))
        -- catch an arming request and breach occurred
        rule([[#alarm{id='$id', property='delayed'} =>
            for p,d in pairs(env.event.value) do
            fibaro.warning(__TAG,efmt('ER5 Partition %s breached, devices %l',p,d))
            end;
            fibaro.warning(__TAG,efmt('ER5 Disarming'));
            0:armed=false; -- we disarm so we don't trigger an alarm...
            fibaro.sleep(5000);
            fibaro.warning(__TAG,efmt('ER5 Rearming'));
            0:armed=true
        -- Trevor's rules start here
        -- Turn on facade light at sunset; off at 15 min before sunrise
        rule("facade:value => log('Facade:%s',facade:value)")
        rule("@sunset => facade:on")
        rule("@sunrise-00:15 => facade:off")
        -- Turn on family room lamp at 5 pm; off at 11 pm --15 min before sunrise
        rule("psocket1:value => log('Smart socket 1:%s',psocket1:value)")
        rule("@17:00 => psocket1:on")
        rule("@23:00 => psocket1:off")
        -- rule("@sunrise-00:15 => psocket1:off")
        -- The following is used to trigger the Advanced Presence Simulation (and the next Pressed2 will reset profile to Home thus stopping the processing)
        -- Now incorporate alarm enablement with the profile change
        rule("user=2") -- Admin user
        rule([[redbutton:central.keyId==1 & redbutton:central.keyAttribute=='Pressed2' => -- redbutton clicked twice
           local pid = fibaro.activeProfile(); -- return active profile name. Was >> QA:profileName(QA:activeProfile())
           local pName =fibaro.profileIdtoName(pid);
           local sOFF = {44};
           local sON = {45};
           log('ER5 redbutton was clicked 2X');log('Current profile:%s',pName);
           if pName == 'Home' then
             log('ER5 The Away profile will be activated');
             fibaro.activeProfile("Away");
             fibaro.sleep(3000);    --wait 3 secs
             -- execute TRYARM
             log('ER5 About to execute tryArm');
             0:tryArm;
             fibaro.sleep(5000);    --wait 5 secs
             if 0:isDisarmed == true then
             -- run ON Alarm scene after breach captured causing disarming
                log('ER5 About to execute ON Alarm');
                fibaro.scene("execute", sON)
           else -- set val to 1 (Home)
            log('ER5 The Home profile will be activated');
            fibaro.activeProfile("Home");
            -- run OFF Alarm scene
            log('ER5 About to execute OFF Alarm');
            fibaro.scene("execute", sOFF)
        -- log change of profile  see JGAB Tutorial entry on Posted August 12, 2022
        rule("#profile{property='activeProfile', value='$p'} => log('ER5 Profile changed to %s',QA:profileName(p))")
        -- Trevor's rules end here  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
            end;
            fibaro.sleep(5000);
            0:armed=true
    Ok, I looked at your rules and the general mechanism seems to work.
    You get a "delayed" event when you arm and it report the partition/device - 11/28 in your example.
    However, the 0:armed=false just disable the alarm partitions. Device 28 is still probably breached (if it's a door or window or a motion sensor with longer breach period)
    When you then after 5s do 0:armed=true you will get a breached alarm immediately.
    You could try to do a 0:tryArm again and it would loop with "delayed" events until the breached devices are fixed.
    To jgab
    How can I clear any/all delayed breaches programmatically? I thought a disarm might do that. This is a pure motion detection not an open switch (door/window)
    Also how do I get the neat reply post@jgab layout that you do?
    Cheers
    JagarMan
    52 minutes ago, JagarMan said:
    To jgab
    Cheers
    JagarMan
    On the HC3 we arm and disarm (alarm)partitions.
    Alarm partitions are pure logic constructs that contains one or more physical devices (or QAs).
    Alarm partitions can share devices.
    Devices (sensors) can be breached or safe - there is no command we can send to breach them or make them safe. That is controlled physically by opening/closing doors or the sensor sensing motion. (we could have a simulated sensor with a QA that we could breach but that's not the case here...)
    So, arming/disarming the partition does not affect the state of the device - and when you arm the partition after 5s the device/sensor is most likely still in the breached state and the partition will trigger.
    If you instead do a 0:tryArm and the sensor is not safe you will get a new "delayed" event if the sensor is not safe. Btw, don't use fibaro.sleep(5000) in a rule, use wait(5) instead.
    I assume the sensor turns safe after x seconds and the tryArm will eventually work without sending a "delayed" event...
    @jgab Hi jgab,
    Alarm is arming properly now, thank you.
    I notice an action trace in ALARMSTATUSUPDATE on console when house is armed:
    onAction: {"deviceId":118,"manual":false,"args":["status","text","Alarm set to full"],"actionName":"updateView"}
    How may I code a rule in ER5 to log this as a message?
    Cheers
    JagarMan
    @jgab Hello Jan..Is there a way to create ER5 rule variables from a Global variable automatically? Example
    I have a global fibaro variable TTSDATA = {"192.168.1.225": {"name": "Business", "mac": ""},"192.168.1.239": {"name": "Kitchen", "mac": ""}}
    and i want to create ER5 rule variables (when ER5 starts or when the fibaro global TTSDATA changes) and have the following format
    rule ("Business = '192.168.1.225'"}
    rule ("Kitchen = '192.168.1.239'}
    So it kinda creates name-IP pairs, where name will be the ER5 variable name, and IP will be its value..
    Later on, whenever the TTSDATA fibaro global changes, these varibles should also get updated..
    Too complex to achieve?
    rule([[$TTSDATA =>
        for ip, data in pairs($TTSDATA) do
           if data.name == 'Business' then Business = ip else Kitchen = ip end
    ]]).start()
    9 minutes ago, jgab said:
    rule([[$TTSDATA =>
    ]]).start()
    Oh you misundesrstood me...I want to get created these rule for every data int TTSDATA global.
    rule(name = ip)
    where name is coming from he global, an ip is the corresponding global. So we dont know the names, we cant compare them like if data.name == "Business"...
    the data is there, but inside ER5 i cant do the comparison, as these names are always different in different installations.
    This process should initialize for me all the rule(speakername = IP) rules automatically.
    First we always create that global table when installing and later i would install ER5,so my goal is in ER5 all these name=ip deinifitions would be defined automatically accordint to the TTSDATA global table.
    This is an exaple from one installations
     rule("business_speaker = '192.168.1.225'")
        rule("meeting_speaker = '192.168.1.238'")
        rule("kitchen_speaker = '192.168.1.239'")
        rule("ceo_speaker = '192.168.1.244'")
        rule("corridor_speaker1 = '192.168.1.217'")
        rule("corridor_speaker2 = '192.168.1.235'")
        rule("dining_speaker = '192.168.1.220'")
        rule("corridor_all_speakers = {'192.168.1.217','192.168.1.235'}")
        rule("wellness_speaker = '192.168.1.241'")
        rule("wellness_speaker2 = '192.168.1.216'")
    I would like to have these rules to be created according to the global TTSDATA variable.
