Jan I want to have the value off:
to refresh every 5 min if possible to have or use in ER5 as Global Variable
Edited by Sjakie
GV add
    First time, if global LiveWeer doesn't exists, ut will log "nil", but then it will get the right weather....
    Jan, thank you very much!
    The result is a big difference
    Jan, is it possible to have a daily report from history fa $LiveWeer_Temp? Or are Global Variables not stored in history?
    This is a way to save all changes for global variable $foop and log the changes at 23:59 each evening.
    Jan sorry get error also in the by you give rule
    osdate -> os.date
    @jgab, I have on all my rules at the end a number with letter.
    I notice in my QA who regularly crashes that it crash after a rule with .start()
    this morning I modified this QA >>> crashed
    I saw the rule had .start()  >>> removed . start()
    QA crashed again on a rule with .start() >>> removed .start()
    add 3 times enter save QA QA run
    Can this be a cause or is it???
    Can you post the rule that crashes with .start() ?
    On this rules the QA crated a crash
    Edited by Sjakie
    removed all .start() in this QA
    Jan, I get error even if I copy yours again and I hav e no idea what's wrong.
    Quote
    Dagelijkse limiet van 300 verzoeken overstegen. Meer nodig? Neem een pro-abonnement voor 500.000 dataverzoeken (€45 per maand) bij
    Exceeded daily limit of 300 requests. Need more? Take out a pro subscription for 500,000 data requests (€45 per month) at
    Edited by SmartHomeEddy
    Oh yee, thanks.
    Will it work again tomorrow?
    Refresh need change from 5 into 10 minutes.
    That depends on how many people use your APIkey by now 😉
    Thanks, no problem there aren't so much Fibaro users in my town, it was my mistake by copying it also in test QA so I requested to many times.
    btw according my api its "licht bewolkt" on te site it show "zwaar bewolkt".
    The temperatuur give the same value.
    ZZZZ and YYYY I fill in names as above, Temp, Samenv, Lv, Windr etcetera.
    YYYY >>>> exact the same as in values
    Jan the given example by you is working for two values but if I extend it will not refresh the actual data
    If I copy your example in a new QA it show the recent data.
    No error is shown and I  am not at the limit of 300 requestst
    So I guess I need to do some more??
    Please advice
    Maybe a stupid question, but how to invoke a custom QuickApp method (attached to custom UI button) from a rule?
    I've prepared QuickApp to work with
    (RGB bulb) and I use it as dim light but also for noticications. You can invoke custom RGB sequence, i.e. create "blink notification" - what I exposed in the UI as custom button QuickApp:onButtonNotification(event).
    How could I create a EventRunner rule to invoke onButtonNotification? Let's suppose I have motionSensor and the QuickApp device is mapped as rgbBulb. I would expect something like that (which obviously doesn't work)
    or maybe like that:
    TL;DR
    Question: Is there any way to call QuickApps method from EventRunner? Am I even approaching this topic correctly?
    or maybe like that:
    TL;DR
    Just call it as you would call from other quickapp. hub.call(<QAid>,<functionName>,<params>)
    @jgab, I see this  error a few times but with different debug before and after so I  have no clue where to find what is wrong. Can you extend error message what or why?
    Timeout of your weerlive.nl quickapp
