okay, thanks.
@jgab Hello Jan,
When I use a table as a trugger for centralScenes it doesnt work..but i swear it was working
THIS DOESNT WORK
But when i just use one device from the table, it works...
1 hour ago, Neo Andersson said:
@jgab Hello Jan,
THIS DOESNT WORK
UPDATE
Okay, i have found the problem, there is one device in the table {nano_Zbetu,nano_nikol,nano_rob,nano_zoli,zooz_remote_zoli}, that doesnt exist, but i did not get any warnings about it, that was a bit misleading, but now its okay
Thanks anyway
@jgab Jan, hello
The QAupdater is crashing..Throwing errors, and doesnt work at all
Some more errors
/monthly_2024_07/image.png.5aefebc175018c8852524b32916e16f8.png" />
and all the buttons dissapiered. I am running on latest beta, but i am not sure if this is related to it. So far it was working without errors.
/monthly_2024_07/image.png.d38bf063ed91ae4f63d8119f632d1819.png" />
After update FW Updater is showing all info.
Sorry I can't show picture getting error by upload
Edited by Sjakie
dear @jgab,
I just upload eventRunnuer5 from vscode using "run task upload" and I got a running EventRnner5 QA in my HC3, processing correctly all my rules located in 3 "--%%files=...".
The only issue I got was that in the view of the QA none of the buttons were visible and the "stats" label seemed to have not been created (not visible).
In the HC3 QA editor I clicked on visible fore eacj of the 6 buttons and then all buttons were shown but still label "stats" was not shown.
Trying to create it, gives me an error message of duplicated ids for label.
To solve the issue, I have created a new label with ID "Stats" and change your updateView line with this new label id and now all views (pc, old and new mobile applications) are complete and working.
It is not the first time that buttons created from vscode QA are not visible: Is there something starnge in my button declaration that caused this?
Also missing label is not new but it was because I tried to create 2 labels on the same row which work in fibemu but HC3 does not accept this type of configuration. With EventRunner5 it is not the case .
Below my --%% declarations:
--%%root=<automatic>
--%%include=Include.lua
--%%name=EventRunner5
--%%remote=alarms/v1/partitions:1
--%%remote=devices:*
--%%debug=refresh:false
--%%u1={label='title',text='EventRunner5'}
--%%u2={{button='listRules',text='List rules', onReleased='listRules'},{button='listRulesExt',text='List rules ext.', onReleased='listRulesExt'}}
--%%u3={{button='listTimers',text='List timers', onReleased='listTimers'},{button='listVars',text='List variables', onReleased='listVariables'}}
--%%u4={{button='listRuleStats',text='List stats', onReleased='listRuleStats'},{button='Restart',text='Restart', onReleased='restart'}}
--%%u5={label='stats',text=''}
--%%file=/test/u_lumVestibule.lua,lumVestibule
--%%file=/test/u_lumPalier.lua,lumPalier
--%%file=/test/u_lumOther.lua,lumOther
function QuickApp:main(er) -- Main function, place to define rules
@jgab Yes, Jan all the UI controls dissapiered after FW update. (maybe even earlier, but i noticed it just now)
/monthly_2024_08/image.png.c2a2e9adaf7c11393c444700b5ceaddf.png" />
5.160 >>> No problem here looks good!
Edited by Sjakie
Last beta version 5.161 seems to have introduced a lot of view changes including the pc web view to make it more similar to the new mobile application view: I dont like this change and I think there are also some new bugs on which Fibaro will have to work.
I am running on 5.1.61.15 beta
    Yes, 5.161.15 seems to have broken some (undocumented) APIs for updating the QA.
    I believe it's solvable with the new way of doing things... however, would like to have a stable fw before doing any changes...
    • Thanks 3
    @jgab this rule should not be executed but since yesterday, I re-included the lights, it will be executed. I can't find why.
    but as you can see the GV $Verl_Dagdeel == 'Slapen'
    Any idea?
    Any idea?
    If GV $Verl_Dagdeel == 'Slapen'
    then $Verl_Dagdeel ~= 'Opstaan_Sjaak' will be true and the test (OR expression) will be true.
    Hello gays  i have uesd er 4  for som time .  And i have all my ruels  in the moduels  like  this  and now i will tray too go to Er5  but  i get errror  trying to use  moduels
    And know in Er 5 this  wont  work any more   get this   error
    [2024-08-17] [13:17:41] [DEBUG] [QUICKAPP1143]: Loading rule module 'u_Ytterbelysning'[2024-08-17] [13:17:41]
    [ERROR] [QUICKAPP1143]: Rule setup error(s) - fix & restart...[2024-08-17] [13:17:41]
    [ERROR] [QUICKAPP1143]: Last err: ./include/u_Ytterbelysning.lua:25: attempt to call a nil value (global 'rule')
    I solvd it  my mistake  :)
    I don't have the problem. Installed ER5 v1.03 fresh, and then an update to v1.05 and the UI buttons are there.
    Hi All  :)
    I have a problem  this rule  have workd in er 4 but know in er 5 i dosent work  i am jumping to er 5 :)
    i hop  you can help me  :)
    Edited by systemfel
    31 minutes ago, systemfel said:
    Hi All  :)
    This says that garageport device is either missing or has wrong id given in HT table
    Edited by Neo Andersson
