22 hours ago, Neo Andersson said:
This says that garageport device is either missing or has wrong id given in HT table
Tanx  i found the problem  .. speling mistake :)
Jan, sometimes I modify QA and make a mistake and not always I get error.So QA will stop without me notice it directly only when I discover some rules are not executing.
I created in each ER5 QA
In QA 1565
or is there a better way to do?
Thanks in advance
Awesome work Jan. ER5 prompted me to finally get to work on Fibaro automation.
Tried getting Terminal 5 working, getting this error:
[2024-08-31] [14:28:27] [TRACE] [QA_ER5_693]: onAction: {"deviceId":693,"manual":true,"args":["elog('%l',[_:isOn in devices])"],"actionName":"eval"}
[2024-08-31] [14:28:27] [DEBUG] [QA_ER5_693]: ./include/engine.lua:276: attempt to call a nil value (local 'e_pcall')
[2024-08-31] [14:28:27] [ERROR] [QUICKAPP693]: QuickApp crashed
[2024-08-31] [14:28:27] [ERROR] [QUICKAPP693]: Unknown error occurred: handleJsonRpc
    Terminal 5 probably needs an update as ER5 has evolved a bit since I last looked at it. Will see if I get some time next week to fix it…
    In QA 1565
    Thanks in advance
    Hi @Sjakie. I am using this little line for Error catching, and it is really helpful.. Using this you will always get en error message to you phone and email , if some error occours. I used to create a kinda installerUser user on all my customre's systems, so i have a user ID for myself everywhere, and so if some error come up, i get notification to my mobile, and i can quickly react.
    Edited by Neo Andersson
    @Neo Andersson, thank you very much!
    If I add your rule the result is:
    Excellent!
    Edited by Sjakie
    Excellent!
    @jgab Jan, i have a little complex question..
    I need to store values from a sensor into a table, and later in other rule use the average of these measurments. The problem is, i need only 10 measurements, so when there is already 10 values in the table, and a new is coming, i want the oldest one to be removed, and so i will get always the 10 last measurement's average..
    My approach was so far
    any idea please?
    any idea please?
    I did somthing like this once xD
    But I guess it is ineffective 😅
    function update_values()
    self.store.line10 = self.store.line9
    self.store.line9 = self.store.line8
    self.store.line8 = self.store.line7
    self.store.line7 = self.store.line6
    self.store.line6 = self.store.line5
    self.store.line5 = self.store.line4
    self.store.line4 = self.store.line3
    self.store.line3 = self.store.line2
    self.store.line2 = self.store.line1
    self.store.line1 = hub.getValue(Sensorid, "value")
    function QuickApp:setupStorage()
       local storage,qa = {},self
       function storage:__index(key) return qa:internalStorageGet(key) end
       function storage:__newindex(key,val)
          if val == nil then qa:internalStorageRemove(key)
          else qa:internalStorageSet(key,val) end
       return setmetatable({},storage)
    @Neo Andersson, the setupstorage is somthing jgab have made. It stores the data for restarts to :D
    Hi @Neo Andersson ,
    Since this is very small table array with only 10 values, you can use LUA functions table.insert and table.remove. For example, you have table:
    To add new value to the beginning of the table:
    and table will be:
    to remove last value:
    to get:
    Why I mention that this two functions are good for small table arrays, maybe up to few hundred values? Because this function needs to move other values in the array when adding or removing one value depending on its position in the array.
    8 minutes ago, Sankotronic said:
    Hi @Neo Andersson ,
    and table will be:
    to get:
    Yeah i know this, but thanks anyway..as you see i tried to use some Jgabs inbuilt table functions, but the  <adde> function doesnt seem to work for me...
    15 minutes ago, Sankotronic said:
    Hi @Neo Andersson ,
    and table will be:
    to get:
    This is what I should have used i Guess? 😅
    @jgabCan Eventrunner 5 be used in HC3L?
    Edited by lux
    JGAB is probably busy, but i can answer this...YES you can use it
    i user it in Hc3l,the wait(1) debug display :wait 00:00:00,but hc3 is OK
    [11.09.2024] [17:09:04] [TRACE] [QUICKAPP214]: [Rule:9:2]>> FALSE #device{id=110,val.. -> remote_xican_l:central.keyAttribute == ..
    [11.09.2024] [17:09:07] [TRACE] [QUICKAPP214]: [Rule:9:2]>> suspended triggered - wait 00:00:00
    [11.09.2024] [17:09:10] [TRACE] [QUICKAPP214]: [Rule:9:2]>> suspended triggered - wait 00:00:00
    [11.09.2024] [17:09:13] [TRACE] [QUICKAPP214]: [Rule:9:2]>> suspended triggered - wait 00:00:00
    [11.09.2024] [17:09:17] [TRACE] [QUICKAPP214]: [Rule:9:2]>> suspended triggered - wait 00:00:00
    Edited by lux
    Where is functiontime coming from?
    I think wait(1) is an incorrect format..What time do you want to wait? 1 second? 1 hour? or 1 minute?..
    Wait function needs to have the argument in format i think hh:mm:ss..So just reformat it, and it will work..thats my guess
        rule("functiontime = 1")
    or
    functiontime = 1
    or
        local HT = { -- Test Home Table with "fake" devices - create your own...
            functiontime = 1,
    or
    functiontime = 1
    or
            functiontime = 1,
    As i wrote you...you cant use wait(1)..at least i think you can't. What should the 1 mean? 1 sec or 1 hour or 1 minute????
    Use format hh:mm:ss
    1 second
    01:00 >> 1 hour
    01:10 >> 1 hour and 10 min
    00:00:01 1 sec
    wait(0); in a rule means all above this wait(0) will be executed first before we contimue
    Guys, switch 2 buttons on and off
    press, release, hold properties
    on and off no problem
    but
    how to write in a rule if 1:'Holddown' raise britness fa in steps with 10%
    3 hours ago, Sjakie said:
    01:00 >> 1 hour
    00:00:01 1 sec
    but
    this is the general pattern for the dim command
    <id>:dim = { time, direction, steps, curve, startValue, stopValue }
    example
    Ex.
    rule("@sunrise-00:30 => lamp:dim = {00:30, 'up', 5, 'Linear', 0, 99}")
