    10 minutes ago, William12345 said:
    Hi Jan,
    I wanna create a rule that automatically sets devices(Lights) that are turned on between 07-09 to 99% what would be the simplest way to make this rule.
    I made this rule for example, but problem is it cant be dimmed as it automatically turns back to 99% is there a way to limit it to just do this rule once per day for example?
    rule("tv_rum_spottar:isOn & 10:00..11:00 => tv_rum_spottar:value=99"
    On another note, im also a bit confused on how to add a variabel/profile to this rule, i have made a profile called festivities and if that profile is activate i dont want the rules below to run.
    rule("@19:30 => kok_bankbelysning_ovre:dim = {03:30, 'down', 100, 'linear', 10, kok_bankbelysning_ovre:value}")
    rule("@19:30 => entre_spotlights:dim = {03:30, 'down', 100, 'linear', 10, entre_spotlights:value}")
    rule("@19:30 => passage_spottar:dim = {03:30, 'down', 100, 'linear', 10, passage_spottar:value}")
    rule("@19:30 => passage_spotlights:dim = {03:30, 'down', 100, 'linear', 10, passage_spotlights:value}")
    rule("@19:30 => trappa_trappbelysning:dim = {03:30, 'down', 100, 'linear', 10, trappa_trappbelysning:value}")
    All help is appreciated :-D
    rule("tv_rum_spottar:isOn & once(10:00..11:00) => tv_rum_spottar:value=99"
    profile handling is not so good yet. I would recommend
    Be careful of the spelling of festivities , e.g. if it starts with a capital letter.
    @jgab Jan, i am
    1. How to construct a custom property for defualt LightSensor of a room that a device is in ? simlarly to windowopened? roomID is part of ER5 so i can do somelight:roomID, and there i need to get the defualt light sensor for given room, like in the example somelight:roomID:defLightSensor
    41 minutes ago, Neo Andersson said:
    @jgab Jan, i am
    If you have :roomID defined
    Dear @jgab I am now testing eventRunner5 within vscode.
    I have currently an issue not solved by Fibaro support: none of my previously working scenes is now trigered by any event!
    So , as I did downloaded in 2021 AOQ (All-in-One) from @cag014 , I am using this QA for replacing all my dead scenes: All OK including what is explained below.
    I want to do the same using EventRunner5 but I have a very special request which locked me:
    One light of the staircase, that is not visible from room doors, can be toggled by 5 WALLI dual switches and one QA (id:388) (for switching the light from the Yubii application).
    The needed scenario is that when a user is pressing once any of the upper WALLI switches the staircase light is toggled and this needs also to change status of all other WALLIs in order that users know that the light is "on" or "off" looking at the LED ring -> meaning that all WALLI switches must reflect the status of the light after any change.
    I have found a way to switch the light on/off  and all other WALLIs using the following rules:
    LustreA={435,315,310,36,305}
        --rule("LustreA:isOn => if LustreA:isAnyOff then LustreA:on end").mode("killOthers") --works but impossible to switch OFF after
    ParamA={434,434,314,309,35,304} -- needed for centralSceneEvent trigger
        rule([[(310-1):central.keyAttribute == 'Pressed'  => if 310:isOff then LustreA:on end]]).mode("killOthers") --OK
        rule([[(310-1):central.keyAttribute == 'Pressed'  => if 310:isOn then LustreA:off end]]).mode("killOthers") --OK
        rule("LustreA:isAllOn => 388:on") --OK
        rule("LustreA:isOff => 388:off") --OK
        rule("388:isOn => if LustreA:isOff then LustreA:on end")--OK
        rule("388:isOff = if LustreA:isAllOn then LustreA:off end")
    Rules 3, 4, 5, 6 and 7 are perfectly working but not the last one :
    [23.03.2024] [13:26:54] [TRACE ] [ER5000 ]: Defined [Rule:3] (310-1):central.keyAttribute == 'Pressed'  => if 310:isOff then LustreA:on end
    [23.03.2024] [13:26:54] [TRACE ] [ER5000 ]: Defined [Rule:4] (310-1):central.keyAttribute == 'Pressed'  => if 310:isOn then LustreA:off end
    [23.03.2024] [13:26:54] [TRACE ] [ER5000 ]: Defined [Rule:5] LustreA:isAllOn => 388:on
    [23.03.2024] [13:26:54] [TRACE ] [ER5000 ]: Defined [Rule:6] LustreA:isOff => 388:off
    [23.03.2024] [13:26:54] [TRACE ] [ER5000 ]: Defined [Rule:7] 388:isOn => if LustreA:isOff then LustreA:on end
    [error] Expr Runtime: :isOff is not a valid device set property for device:388
    Why ":isOn" OK but not ":isOff"?
    Edited by Christb
    Because you use '=' instead of '=>'
    so it's complaining that :isOff is not a "valid device set property"
    @jgab Jan another really strange ghost effect
    /monthly_2024_03/image.png.73bd63717d8dcbf01d366704eaf41cfb.png" />
    This happened as i was clicking between file tabs in lua editor..
    Also noticed, that i have deleted a file from ER5, and closed the QA, and all the stuff from that file was still alive..All the event listeners, everything..
    Just in case you still collect all the cases with ghosts :-)
    I'm having a problem with defining a custom property for a dimmer. I want to set the default (forced) value in Parameter 19 to give time of day brightness value for the dimmer(s)
    This works:
     rule("@11:00 => fibaro.call(44,'setConfiguration',19,1,25)")
    However, if I define a custom (set) property (in main after er has been defined):
    function er.stdProp.setProp.defaultValue(obj,prop,event,value) return fibaro.call(obj.id,'setConfiguration',19,1,value) end
    and the rule:
    rule("@11:00 => 44:defaultValue=25")
    then I get an error when the rule is triggered:
    [Rule:13:1]>> [Rule:13:@11:00 => 44:defaultValue=25] Runtime: ./include/utils.lua:389: ./include/utils.lua:406: [string "do..."]:11: /usr/share/lua/5.3/json/encode.lua:88: Failed to encode value, encoders for function deny encoding putprop
    I'm clearly doing something wrong but this is my first attempt at a custom property and trying to understand what I have missed.
    This works:
    and the rule:
    ...but you came quite far with your attempt! :-)
    So, the arguments for setProp is slightly different - there is no event parameter.
    If you need 3 parameters you can make a table
    Thanks, that worked.
    What caught me out was following the link on page 1 of this topic which pointed to Custom properties (on page 10). This has event in the parameters for setProp so it might be worth a quick edit?
    So, that now gives me a time of day rule for some of my fibaro dimmers to allow them to be dimmer in the evening and night time when they are turned on.
    @jgab Jan is there anywhere a list of commands for ER5 so i can look up if i need the syntax for something?
    Now i can't find the syntax for setting a thermostat mode to OFF or ON..
    I grinded through the entire ER5 topic, but could not find.
    What is the syntax?  thermostat:mode = "Off"? thermostat:mode = "off" ?
    UPDATE
    Okay, i have found it, it is thermostat:thermostatMode = "Off"
    • 3 weeks later...
    @jgab Hello Jan, i am using this formula to create rules that makes a light turn on on a swtich action
    i need to change the rules that can handle when the light is a dimmer, or rgbw so rule will run an action setValue and not turnOn
    For this i need to somehow differentiane the action upon device type.
    How to determine using ER5 syntax, that a device is a dimmer, or RGBW that can accept setValue action, or is a single switch type that accpets ture or false actions.
    Isn't it easier to determine that in the Lua loop and create different rules for them?
    One way is to see if the device gas the setValue action
    Yes, i am using a similar approach at this moment, but it is tricky when lights are defined in a table like
    so i thing i need to change somehow the onIfOff function definition so that it will check the light type and act upon it..
    @jgab you helped me with once weekly to get temperature from some devices.
    I would like something similar for power, so I replaced temperatures with power but that was to easily, it did't work.
    Can you give the correct frase?
    Thanks in advance
    @jgab Jan, can you please assist a bit
    How to form a rule that takes a table as a trigger that contains {month,day} pairs and perform action on thise exact days (always at 7:00 and the action side is always the same)?
    Now i am writing rule for every single moth-day pair separately. Can i just define separately a kinda wastedatetable = {{'mar','7},{'apr','4'}, ...etc} and create rules dynamically..I have tried using fmt in a loop but never succeded..
    Edited by Neo Andersson
    Perhaps something like this:
    Every 4 weeks started at week 0
    Edited by Sjakie
    removed start
    should work?
    Alt. only one rule that checks every day at 7 - a bit more efficient.
    @jgab Hello Jan, I have been a happy ER4 user for years but now I wanted to switch to ER5.
    Unfortunately, I failed with my first attempt.
    I tried the rule from your last post, but I always get an error message. I added the rule in the main section exactly as in the example above.
    Can you please tell me what I'm doing wrong.
    [05/21/2024] [11:40:44] [ERROR] [QUICKAPP727]: Last err: ./include/utils.lua:208: ./include/engine.lua:116: Token error in string '@111:35 & wtable[osdate('%b%d')] => log('Its waste day')' ./include/tokenizer.lua:61: Bad time constant
