    10 hours ago, ChristianSogaard said:
    Hi Jan
    The whole MQTT receiver works fine
    The Child is created successful with
    But the Child dosent get updated., - The POST is there in the logs but this rule never triggers.
    [24.01.2024] [22:09:59] [DEBUG] [QUICKAPP2136]: message: {"qos":0,"topic":"\/watermeter\/mydatajson","retain":false,"payload":"{\"currentValue\":1029.261,\"monthStartValue\":2701306.683,\"WaterTemp\": 4,\"RoomTemp\":231,\"Dry\":\"false\",\"Reverse\":\"false\",\"Leak\":\"false\",\"Burst\":\"false\"}","dup":false}
    [24.01.2024] [22:09:59] [TRACE] [QUICKAPP2136]: Posting #watermeter{dup=false,payload="{"currentValue":1029.261,"monthStartValue":2701306.683,"WaterTemp": 4,"RoomTemp":231,"Dry":"false","Reverse":"false","Leak":"false","Burst":"false"}",qos=0,retain=false,topic="/watermeter/mydatajson"} at Wed Jan 24 22:09:59 2024
    This triggers but value is NIL
    This dosent triggers
    Yes, because the data was in the payload.
    Try this
    Try this
    I dont see the POST now
    So my posts always seems to have bugs, for you to find :-)
    Well, fibaro.post most have an argument, the data we should post
    fixed in the previous post
    Yes - the POST looks better, but the original issue are still there
    rule("#watermeter => Multical21_ID:value=value")
    rule("#watermeter{currentValue='value'} => Multical21_ID:value=value")
    what does it log if you do
    rule("#watermeter => log('Event: %s',env.event)")
    5 minutes ago, ChristianSogaard said:
    My bad, we want to use
    Without $ it only matches if currrentValue is the string 'value'. We want it to bind the value of the match to the ER variable 'value' and thus we use the pattern '$value'
    Now i think we are at the last error on this Class does not have setValue function defined - action ignored
    I also tried the => Multical21_ID:prop=value - but that creates another error
    :prop needs the name of the property and the value, try
    Multical21_ID:prop={'value',value}
    5 minutes ago, jgab said:
    :prop needs the name and the value, try
    Thank you Jan for you assistance - its working
    /monthly_2024_01/image.png.bafd1a70c40f72236d6f9cbdffe6272b.png" />
    Hi Jan
    Can i use the same section code to post value from my GAS Sensor to MQTT - like { "volume":value} to same MQTT but to hjem/gasmaaler
    i see you added the client:publish(....) but that would then be to /watermeter/ - sould i just create one more function handleConnect(event) ?
     from my GAS Sensor to MQTT...? Didn't your GAS Sensor come from MQTT? or is GAS Sensor a zwave device?
    Yes - My GAS sensor is a Zwave device - you can check the
    you need inspitation. ;-)
    My Water Sensor i this project
     - this is send to the MQTT direct from ESP32
    Edited by ChristianSogaard
    Typo
    You don't need to create any new handleConnect - I guess just publish it under the topic 'hjem/gasmaaler' ?
    like
    ...maybe?
    Im Getting
    [27.01.2024] [08:26:03] [ERROR] [QUICKAPP2136]: QuickApp crashed
    [27.01.2024] [08:26:03] [ERROR] [QUICKAPP2136]: main.lua:151: '}' expected near ':'  (
    Line 151 is var.ConfigGasSensor = ...
    i have counted the pairs of } , and it seems right . Should it be defined another way - and if yes - why?
    When you declare var.ConfigGasSensor = ... you are in Lua land, and you need to declare it as a string or a Lua table.
    I recommend Lua table as you get some syntax check from Lua when you do that (what's in a string it doesn't care about)
    You tried to declare a json table which Lua doesn't understand {"key":"value"} ...
    However publish wants it's value as a json encoded string so we call json.encode on it
    @jgab
    Jan, is there a way to set hetaing zone setpoint and zone mode to manual?
    I am not talkoing about the regular thermostat but the Zone thermostat
    1 hour ago, Neo Andersson said:
    @jgab
    These functions are available in ER5
    ...also part of the fibaroExtra library...
    Hi again
    I'm trying to set up some rules to synchronise state between devices. For context, these devices are roller blinds that are not directly connected to the Fibaro, they are Somfy so they are directly controlled by a Somfy bridge, which is linked to the HC3 via a Skaro Automation Bridge. Basically every device is a QA and the functions like "up", "down" etc are mapped to API calls against the Automation Bridge (which then somehow sends them over the Somfy cloud API in a way that is not transparent to me).
    In a room I have 7 blinds in total, and each of them have individual devices. When called as a group (e.g. {blind1, blind2}:up) the Somfy bridge will loop through them and send the commands with some delay between each blind. This is OK most of the time except when you are trying to precisely position them using timing. However, it's also possible to group blinds at the radio level by associating a group of blinds with one channel on the bridge (similar to how groups work on a standard Somfy multichannel remote) - in this case it's not that the remote or bridge knows anything about a group, it simply sends out a frame with a command and a channel number and controllers in radio range that are programmed to respond to that channel number will execute the command. This method always achieves near-perfect sync between multiple blinds.
    So in my case I have both the individual devices, and a group device which is exported by the bridge (the bridge doesn't know the difference - for it, that group is just another blind).
    (Aside: you can also create groups on the Somfy bridge but those still have the laggy loop behaviour so aren't helpful or relevant here).
    What I want to do is synchronise the status between the grouped device and individual device, so for example if all blinds are open, and I "close" the group device, the 3 individual devices in the group have their status changed to "closed" without sending another "close" command to them.
    I've tried
    This generates a runtime error:
    I have also tried using setValue(0) instead of updateProperty, with the same result, even if I go to the quickapps and add a definition for setValue
    Any ideas?
    @jgabIs this rule still retained?
    Edited by lux
