@jgab this trigger does't work
used  58%
buffer 6%
Cache 26%
free 10%
present in use 89 %
With those numbers it should restart?
Edited by Sjakie
add %
    used  58%
    buffer 6%
    Cache 26%
    free 10%
    present in use 89 %
    No, .used is 58
    Cache and buffer should not be counted as the system at any time can release it if it needs more memory.
    The gauge in the web UI shows used+buffer+cache but clearly marks out what part of that is actually used (58)
    Hello jgab,
    I transferred my rules from ER4 to ER5. In ER4 I had
    to calculate the average outside temperature of my 3 sensors. This rule no longer works in ER5.
    What am I doing wrong?
    Thanks for help 😀
    3 hours ago, KaWi said:
    Hello jgab,
    Thanks for help 😀
    Hi, thanks for finding this out. In ER5 '@' and '@@' has higher priority than '+' (and other arithmetic operators) so you need to put it in parentheses , like this
    I have to think about it, if I'm changing it... However, the error message we got was bad so that I will improve to next release.
    Sorry, this is not the problem and it works like before...
    @KaWi
    So, I can't see the problem.
    In what way doesn't it work?
    crash or calculating the wrong value or ?
    I tested it a long time ago in a early version of ER5. At that time the rule was not initialized and I continued to run it in ER4.
    Now it seems to be running in ER5 too. Why? I have no idea.
    But it works. That's what counts.
    Thanks for testing anyway
    On 12/14/2023 at 3:26 PM, jgab said:
    @jgab Jan is this "ask" function built in already?
    On 11/17/2023 at 7:23 AM, jgab said:
    @jgab Jan please, help
    me out..How to formulate a HTTP post in ER5? I cant find what syntax should be used for data. How to form this http call below please?
    how to understand this part
    Edited by Neo Andersson
    net.post(<url>,<options>,<data>)
    and data is the Lua table - resquestStr in your case.
    Ex.
    rule("local res, stat = http.post('http://192.168.100.178:1880/cast',{},{text = message_to_sent, targetip = tostring(value),volume = local_volume,language = local_language})
    Ex.
    Ahh okay you had a typo in description, btw i got still an error
    7 minutes ago, jgab said:
    Still errors, now in Nodered..
    "SyntaxError: Unexpected token o in JSON at position 1"
    Outside of ER5 i always use the json encoded requeststring, so I though that can be the problem..I tried with the encoded string, but then nodered does not even get the call
    Unsure were the problem is -
    in the file builtins at line 583
    put some debug statements before to see what the json encoded data looks like. See if it looks strange.
    What status do you get back from
    stat is the status value.
    debug on Nodered's side to see what the payload is before decoding.
    This is the encoded requeststring
    stat is 400 when using the encoded string and 200 if using the single requestString..but even with 200 i am getting the error from nodered. I am using the same data when posting simply with fibaro net.HTTPClient
    @jgab Jan can it be that mp3name=nil is not posted in ER5 because its nil?
    UDATE: i tested it with not nil mp3name, still the same
    Show me the whole code including the definition of requestStr. What do you mean by "encoded string" vs "single requestString" ?
     there is a variable
    it is just the encoded requestString. This is how it needs to be called. And it is working.
    For some reason, in ER5 it gets some strange Json formatted output. This is my guess, becuase regularly its working
     there is a variable
    mp3name = nil will just remove that entry from the table.
    http.post is equivalent to the lua code you show me.
    Can you post the rule you call too?
    I have tried with mp3Name not nil version, but still the same, here is my test call
    I've been running this to other servers and identical code is used in the ER5 Nodered integration.
    I'm just testing it against another server and it works well - I think the problem is on the Nodered side - how do you decode the data?
    I cant get it..I am using this code years, without a problem..How is this possible
