Hi @jgab, thanks for the tip about the ER<id> tag, I had missed that.
I tried your suggestions about the child device.
First, just changing to
doesn't work (I wouldn't say it has no effect - it probably did change something - but it doesn't make the device work as intended). Clicking the (for example) 'open' command on the device shows this in the logs:
However, the relevant rule above (which is defined as Rule 8 in this case)
is not triggered, or I would expect a trace with the ER293 tag similar to that Rule:1:1 trace above but for this rule.
If I also change UpdateProperty to :value, i.e.
then I get more activity in the logs, but it doesn't result in the blinds opening or closing.
(that's from one press of "open", I get similar for "close" except where "args":[1] it is instead "args":[0], which makes sense).
The corresponding rules to actually send the command to the blinds are still not triggered.
Any other suggestions I could try?
2 hours ago, jgab said:
So, in the later ER5's in the main file there is already a setup for loading modules from other files. You may not have updated the main file so you haven't seen it.
It's in the :onInit() setup part and looks like
The commented part is the instructions.
Ex.
create a QA file named u_myRules1
with the content
you also need to make sure that you have the module loading code in main
The prio thing is so that you can decide in what order the modules should load if they have dependencies on each other...
@jgab Jan, but there is no such code in my main file, and  i am on the latest versioni 1.0
    Yes, but main is not updated with QAUpdater (so your rules won't be overwritten) - so you probably don't have that code.
    In the main that comes with a clean install of ER5 the code is there.
    So either copy/paste from the main in GitHub or just copy the code in the previous post.
    Ahh okay , got it...so later on I dont even need to call  my other rules functions from other files. They will all become part of the global rules by their rule() function right?
    Okay, I separated the files according to the setup instructions
    Now i got this
    /monthly_2024_01/image.png.f819238f73b2c12a59ac4cc906fc9ed5.png" />
    i dont get it..
    12 hours ago, bonhomme said:
    @jgab your suggestion worked, thank you!
    Now, I'm trying to make that child device work - it is triggering OnAction events 'open' and 'closed' but the :isOpen and :isClosed rules are not getting triggered. What's the correct way to pick up those actions?
    gives
    Setting the last two rules to watch Blinds_Upstairs instead of Blinds_Upstairs_D doesn't generate any errors, but the open/close events don't trigger the rules.
    Ok, It turned out that there is some issues with child objects.
    This works
    The problem is that when we create a child object I inject code that intercepts all type defined actions to become #UI events that we can pick up in ER.
    Actions for rollerShutter are
    The problem is that <id>:value = x
    is translated to fibaro.call(id,"setValue",x)
    so it becomes an #UI event instead of actually setting the value/prop.
    So, in the code above we define a new method _updateProp(prop, val) that updates the property for the child and use that in the rule.
    I will add _updateProp to the next release but for now you can add it like I did in the example
    ...and rollerShutters want a value of 0 for closed and 99 for opened
    Now i got this
    i dont get it..
    So in the error message the ^^^ points at shs, so shs is not defined at the point when this module is loaded.
    You need to make sure that shs is defined.
    Put the shs definition in a module with prior < 3
    Jan, i am loading all shs functions right in the main function..should not this be enough? shs functions are custom functions and do not contain any rules..
    So that means MODULES are loaded earlier than main function?
    Edited by Neo Andersson
    Ok, that was a bug in the module loader so main (with prio 0)  was loaded after user modules.
    Change it to
    then it will load your main and setup shs before calling the modules.
    I will fix it in the next release
    @jgab you are amazing, that works beautifully.
    It turns out that I was overcomplicating it. updateProperty is not intercepted so this works
    As long as we use 0/99 as values
    Jan, how it it possible that this file prio order does not complain about anything...
    All_rgbws is defined in file1, becuase it should be defined there to be accessable in a rule in file2
    However, in file 1 the HT table is not initialized yet, and still seem to work, so i can assign Stairs_LED and Kitchen_LED to All_rgbw  / at least no error message..
    So regarding  the HT table definition, it is not needed to get it created prior to using its element?
    check if you are not setting up the HT in main too - main has priority 0 - runs before 1 and 2
    When module 2 is loaded it will define the global lua variable HT with Stairs_LED and Kitchen_LED but who is actually doing er.defvars(HT) ?
    If that is done in main() that is already done by then...
     er.defvars(HT) is done in MODULE2, but seems that even with this there is no error message,
    does not trigger whith this module order..
    Goal is, to somehow separate these groupings to a standalone mondule..I have a lot of them, so they kinda just keep up the places..on the othere hand they are nothing else just simple grouping some existing HT table or rule defined elements into some groups, and these groups are used in rules...
    Okay, i think there is only one way to get this working
    I need to define a complete standalone module just for HT table, or leave the HT table in the main functoin..
    Just to make it clear.
    In module 1 (that loads before module 2 because it has priority 1) you did
    this creates a ER variable All_rgbws that is {nil, nil} because Stairs_LED and Kitchen_LED is not defined yet (they are defined in module 2). It doesn't create an error because it's ok to assign a variable {nil, nil}
    In module 2 you did
    Which sets up the HT variables after module 1.
    All_rgbws is still {} and this creates an error (no trigger in rule).
    Solution. Setup HT in the module that runs before you use any HT variables in rules.
    In this example set it up in module 1 before you define All_rgbws
    or set up HT, as you suggest, in main() that is run first, before your modules.
    In module 2 you did
    @jgab Jan i need an urgent hellp..All the prioritirs of modules are set. HT table separated, and loaded as first. I am getting this error and i cant even identify it
    Last err: ./include/utils.lua:208: ./include/compiler.lua:140: attempt to index a nil value (local 'k')
    Can you share the rules you are creating (it's a rule that the compiler breaks on). Usually it's the next after the successful loaded rule.
    Seems to be some array assignment.
    Atteched the whoe fqa, this is very very urgent please. I am at customers house, where we used to have those problems with ER5
    This rule
    is missing commas after the R1 and R2 keys
    I will try to implement a better error message instead of crashing...
