9 minutes ago, Neo Andersson said:
Okay, this is what i get from sepcialLed table
evidently, dasyParts are replaced with some numbers
Okay, Jan
If i use the led table definition with ["morning"] key, then i get the proper special led table
also the ledValues returns the proper table
However, it doesn't find the specialLed[id].dayPart element
    if color is a table like [255,255,255,255]
    the call top setColor needs to unpack the table to separate arguments
    that is what. <ID>:color = {255,255,255,255}
    does...
    Strange. I don't think it matters but change pair to pairs in
    Jan, If I copy MY QA's all in one QA
    It saved with no problem and it is running parallel on my "Older" QA's
    The number of rules does't have a limit>>>hahahaa
    Edited by Sjakie
    Why some rules reports twice and other just one time.
    Rules to be execute will run  twice if I proper remember
    Jan, it is not finidng the dayPart key
    It goes until ledValues needs to be defined in getProp function
    shouldn't it be set like
    ledValues = ledValues.[dayPart] ?
    Okay changed it to ledValues = ledValues[dayPart], and now it doesn't complaint about No daypart morning for led 2778
    But led doesn't turn on with selected color and value
    Edited by Neo Andersson
    I use it like
    is that the way to call it?
    On 12/28/2023 at 8:29 AM, jgab said:
    Oops, this rule
    will set GasCounter to {} every time you restart ER... ;-)
    Well, just remove the rule...
    Hi Jan
    I still have issues with GasCounter - i got the first entry in global variable, but fails after that
    [01.01.2024] [14:13:56] [ERROR] [ER2136]: [Rule:5:1]>> [Rule:5:@14:13:55 => local gc = $GasCounter; local today = {date=osdate("%Y-%m-%d"), total=GAS_ID:value}; table.insert(gc,1,today); if size(gc) > 1 then today[1].daily = today.total - gc[2].total end; if si..] Runtime: table is 'nil' for array reference
    Edited by ChristianSogaard
    Typo
    3 hours ago, jgab said:
    One could also patch the standard :on prop function, but then :on for a special led will always go through the table values.
    (same mapSpecialLed etc)
    @jgab
    Jan i trtied this, to patch, so i can use the regular:on for leds that are not in special group
    But throws an error
    Expr Runtime: ./include/engine.lua:37: attempt to index a number value (local 'id') prop
    White_led.id:on
    31 minutes ago, Neo Andersson said:
    I use it like
    Okay, all the problems was coming from missing table unpack for colors. / i was so used to that ER5 does this job for me
    Also, it seems that dayPart keys needs to be defined as ['morning'] = {color = etc...
    and not like morning = {color = etc..
    becuase calling them later in getProp function like ledValues.dayPart doesnt work..only when ledValues[dayPart] is used
    @jgab
    But throws an error
    White_led.id:on
    OKay, i found the error in your function
    It should not use the same id for oldOn, we need to store the old, regular id of a device, that is not in a specialLed group..and use it when oldOn is called
    @jgab Jan, so far so good, but here is the essential problem..
    This works perfectly if i turn on the LED from a rule but if user turns on the LED manually, it doesnt follow the data apparently, because it is not linked to any event...
    I know, probably i can do
    rule("led.id:isOn => led:on") - (ofcourse with the patch , so ledOn is not needed )
    but this doesn't seem to make a sense..
    what is the workaround for this?
    Happy Newyear great work jgab
    2 hours ago, ChristianSogaard said:
    Hi Jan
    Should be
    @jgabJan, why is my AllHeltunButtons table nil, if i ceate it on the fly?
    I want to populate my AllHeltunButtons table with all keys from BTD table.
    It's not nil when I try it. What does your keys and values look like in the table?
    Is it a (physical) switch that directly turns on the leds?
    Then the only thing you can do is to adjust the color/value after it is turned on I guess...
    So, you need to trigger a rule when the leds comes on and then adjust the values.
    Be careful not to create a loop....
    38 minutes ago, jgab said:
    Well i deleted the whole line, and rewrited again, now it works..probably somethin that i missed there. Just to be sure. Rule are run from topp to bottom right? So BTD table must be created before i use it in other rule right?
    Well ofcourse ther is a switch and they have the Yubii app too. So they can turn on LEDs from various sources.
    Tirggering a rule, and checking the value is the only solution i think..and not using your getProp function, becuase it is eventually calling the led turn on again.
    I think there is no risk to create a loop, at least i dont see where would I...
    @jgab Jan i am having still some troubles withing for each loops in rules
     Expr Runtime: table is 'number' for array reference for k,v in pairs(RGBW_data) do k:color = k.$dayPart.color end ^
    Yes, rules are evaluated top to bottom.
    There is the :manual property that returns the number of seconds since the device was last changed from outside ER5.
    It can be used to tell the difference if a device is turned on by the
    $dayPart is a key so you use index [$dayPart], and you need the value part 'v'
    $dayPart is a key so you use index [$dayPart], and you indeed the value part 'v'
    @jgab
    Jan, after several hours of hair tearing, i have found, why the brightness control doesnt work.
    I am showing here a simplified version of my rule, but the logic is the same
    This rule is intended to check after LED turn on, if its value is not by accident on 0, and if so, it should set some brightness to it.
    However, this will always run..because when led1 gets ON in the rule right side its value will be still 0, no matter what i do...I could add there a wait statement, jsut to give it some time, but it doesn't matter. led1 value is always 0 after its turned on. So this is impossible.
    I have checked in other QA with a simple hub.getValue(led1, "value") and it returned the correct non zero value.
    So this evetually crosses all my efforts to somehow check on the leds value when it gets turned on.
