    7 minutes ago, Neo Andersson said:
    @jgab
    Jan, after several hours of hair tearing, i have found, why the brightness control doesnt work.
    I am showing here a simplified version of my rule, but the logic is the same
    This rule is intended to check after LED turn on, if its value is not by accident on 0, and if so, it should set some brightness to it.
    However, this will always run..because when led1 gets ON in the rule right side its value will be still 0, no matter what i do...I could add there a wait statement, jsut to give it some time, but it doesn't matter. led1 value is always 0 after its turned on. So this is impossible.
    I have checked in other QA with a simple hub.getValue(led1, "value") and it returned the correct non zero value.
    So this evetually crosses all my efforts to somehow check on the leds value when it gets turned on.
    There is something else going on here...
    rule("led1:isOn => || led1:value == 0 >> led1:value = 30 ")
    led1:isOn only triggers (and is true) when the led1's value property is > 0
    So this could not trigger and also have  led1:value == 0
    Is this an fibaro rgb puck?
    How does the device struct look like for it?
    29 minutes ago, Neo Andersson said:
    @jgab Jan, forget about it, i need to find some other way, to check on brightness..I know where is this issue coming now.
    Elemenst in table, switches and LEds are back and forth switching on each other, and it happens probably so quickly that my rule gets the false values always..
    And all this stuff i need to control just because fibaros RGBW modul sometimes randomly drops brightness, and user tries to turn on the led but it doesnt react, so they need to manually set back the brightness..
    Ohh man...thanks for all the helps, i will think further about it..
    Edited by Neo Andersson
    @jgab Jan, if a rule contains non-existing device, the error will trigger only when that rule triggers, or will it trigger after QA start?
    Depends.
    rule("lamp=8888") -- non existing device
    rule("lamp:isOn => log('ok')") -- Will not generate an error and never trigger
    rule("lamp=nil") -- undefined variable
    rule("lamp:isOn => => log('ok')") -- Will generate error at startup as lamp is nil
    @jgab Jan, well this is not completely true.. That is the reason i am hunting a solution..
    RGBW modules can send you a TRUE state while their value is 0...Exaclty this is the reason why i need to find some solution.
    Sometimes user turn on the rgbw, it show on its icon that it is ON, however the LED does not light up, because its brightness is on 0..
    I think this is some bug in fibaro, but we cant wait until they fix it, so thats why i need the solution.
    So after hub.call(led,"turnOn") i need to check if its value gets to >0 otehrwise i have to set some value..However, if I do
    this always shows 0, but if a put there a seTtimeout
    this shows the led's value
    See the test on picture
    /monthly_2024_01/image.png.a322ba715d484e524d50a38b214a7896.png" />
    This goes for your rules too.
    Yes the rule commands, like led:isOn etc always fetch latest value with fibaro.getValue.
    There can be a delay between calling turnOn and the value being reported back correctly with fibaro.getValue I guess...
    But
    is translated to
    and it makes no sense that you would get to the inner setValue.
    could it be that RGB modules use the 'state' property (boolean) to signal on/off and 'value' property for the brightness?
    So it can be 0 brightness ('value'=0) but still on ('state' = true)
    Setup time looks good
    11 seconds is high! Have seen also 7 seconds
    fw 5.150.18
    mem 86% in use 14% free
    CPU 4-50%
    ER5 v1.0
    But
    is translated to
    Haven't checked the state so far..good idea
    @jgab Jan how to catch device state.
    This doesn't work for me
    does the device have a boolean state property?
    If so it's returned with <ID>:state
    to use as a trigger the device needs to emit the property state changed event. If you look at /refresh console logs do you see it?
    Yes, it is working with id:state, but doesnt work with id:state == true...this is not a correct trigger?
    But
    is translated to
    @jgab Jan, i was able to reproduce the situation, when LED is turned on, state is true, value is 99 but the LED still does not glow. !!!!!!!!!!!!!!!!!!!!!!!!
    /monthly_2024_01/image.png.68a2dbd6907b8de17946e2bbe8814123.png" />
    It turned out / as i thought / that it is due to the warmwhite color component.
    Doesnt matter if the device supports warm white or not, if it is on 0 the bulb is dead.
    Doesn't matter what color user selects, the led is not turning on.
    So, please, can you help me to check if colorComponent "warWhite" is not 0 in a rule?
    EDIT
    Okay, it is happening only with LEDs that are not colored but connected to RGBW modul..So a little too early celebrations...
    @jgab Jan how to do the ELSE statement in || >> ? How would the example below look like?
    Please elaborate.
    id:state retturn a boolean?
    ...but it doesn't trigger the rule?
    Do you see a refresh log with when property 'state' change?
    Can you post the whole device struct? Is the device a FGRGBW-442 ?
    Hei Jan
    I would like to add consumption per week and per month in the Gascounter list.
    So my thoughts would be to ADD
        || wday('sun') >> today.weekly = today.total - gc[7].total end;
        || day('last') >> today.monthly = today.total - gc[30].total end;
    in the Rule.
    Im not sure how to test it ? - can you tell if its the right path?
    Also this one "gc[30].total end;" should be dynamic days count per month and not hardcoded 30 days.
    Edited by ChristianSogaard
    Typo
    1 hour ago, ChristianSogaard said:
    Hei Jan
    in the Rule.
    Hei Jan
    Can i use wday at the action side ?
    else i am working on this
    Typo
    Well, it's not sure you have 7 entries in the table for the weekly (not when you start up)
    Secondly,
    || sunday >> ... || lastDayofMonth >> ...
    will choose one of them so you can't have Sunday on the last day of month...
    To get the week you want to subtract last weeks Sunday from today's Sunday's total, so an offset of 8.
    I don't think you need the variables sunday and lastDayofmonth (can be problematic if you restart the QA)
    I think this will work.
    dayNum is the day number, like 31.
    If it's the last day in month and there are more than dayNum entries  in the gc table the first day of the month should be in gc[dayNum], and the last day of the month before should be in gc[dayNum+1]
    Secondly,
    Is something missing like if wday('last)??
    and a attempt to index a nil value (local 'sub')
    [03.01.2024] [14:47:10] [ERROR] [QUICKAPP2136]: Rule setup error(s) - fix & restart...
    [03.01.2024] [14:47:10] [ERROR] [QUICKAPP2136]: Last err: [Rule:5:@23:59:55 => local gc = $GasCounter; local today = {date=osdate("%Y-%m-%d"), total=GAS_ID:value}; local dayNum = osdate('*t').day; table.insert(gc,1,today); if gc[2] then today.daily = today.total -..] Parser: ./include/parser.lua:201: attempt to index a nil value (local 'sub') if wday('sun') & gc[] then today.weekly = today.total - gc[].total & gc[dayNum+1] today.monthly = today.total - gc[dayNum+1].total end; ^
    Typo
