@jgabJan i need an urgent help please
I am getting this error, however, this was working so far,,,
Edited by Neo Andersson
Jan after updgrading to latest ER5 the error seems to dissapier, however, this rule never triggers on button release, and this was definitelly working so far.
This i use at all my customers houses for blind management.
    21 hours ago, ChristianSogaard said:
    Hi Jan
    Shoulde'nt there be something in global Variable by now ?
    its still empty - no restart of EV5 and o deleted the rule as described .-)
    You only get a 'Released' if you hold down the key and release after a while. Single press don't generate 'Released'
    Works fine for me.
    Works fine for me.
    Jan the relased event is not triggered at all for me
    Bu this was working so far, and i did not change the code..i dont understand
    Did you try it in a way that i use? So to catch the released event for any button
    I have checked it at my house too..
    12 hours ago, ChristianSogaard said:
    Hi Jan - i tried trigger the rule to check the logs :-)
    Im getting
    Runtime: calling 'false' - wrong number of arguments to 'insert'
    [29.12.2023] [22:41:55] [TRACE] [ER2059]: [Rule:2:1]>> TRUE #daily{2} -> @22:41:55 => local gc = $GasCounte..
    [29.12.2023] [22:41:55] [ERROR] [ER2059]: [Rule:2:1]>> [Rule:2:@22:41:55 => local gc = $GasCounter; local today = {date=osdate("%Y-%m-%d"), total=GAS_ID:value}; table.insert(gc,1,today); if size(gc) > 1 then today[1].daily = today.total - gc[2].total end; if si..] Runtime: calling 'false' - wrong number of arguments to 'insert'
    Ok, there were some errors in the rule and in ER5 itself. Pushed v0.96 where this should work
    18 hours ago, Neo Andersson said:
    @jgabHelloo Jan
    I am looking for some functions, abbreviations in ER5
    1.  getting gateway name (master)
    2. sending email / probably only to admin's email
    3. getting device parentID/parentName (if device has any)
    I have created custom functions for them, but if they are in ER5,i will use them rather,.
    Pushed v0.96 with some fixes.
    The variable GW is now api.get("/home")
    so
    rule("log('Name is %s',GW.hcName)")
    works
    works with fibaro keyfob.
    When clicked just generates Pressed
    when held down for a while generates HeldDown and then Released
    ...and any key
    19 hours ago, Neo Andersson said:
    @jgabHelloo Jan
    1. v0.96 GW.hcName works
    2. rule("2:email = 'This is an email to user 2'  ")
    3. v0.96. <ID>:parent returns parent id of <ID> or nil
    ...and any key
    Jan, evereything is meesed up . Button 3 press invokes button 1 functions etc..
    Now i commented out all the rules and the rules are still triggered..,.
    Ehh,
    Ehh,
    OKaym i need to restart HC3 again.. everything is upside down..Probably some ghosts in the beckround??
    Just saw this 😕
    Jan, for your information
    my button gives released after pressing
    Hold the button a moment gives me pressed
    HUE software 1.61.1961135030  >> notification uptodate
    Single press
    To get pressed in debug I need to "hold" a moment the button and I also get released.
    Single press
    Yes, childrenOfHue will always give Pressed because it has to guess if it's a short press or a long pressed. Hue maps they events different than fibaro....
    7 minutes ago, jgab said:
    Just saw this 😕
    After restart, pressed, and heldDowns are okay, but this
    still deosnt work. And as i said, we were using this for weeks now, and it was working i swear
    @jgab
    Jan, i have tried it this way, just for testing if it works with separate button
    and this works
    50 minutes ago, Neo Andersson said:
    @jgab
    and this works
    That doesn't make sense.
    What does it log if you do
    53 minutes ago, Neo Andersson said:
    @jgab
    and this works
    i have fiund a solution, that seems to work, however still don't know why the other rule stopped working..
    This seems to work for every button released event
    That's like office_remote_controller:key == '1:Released'
    but with a Lua string pattern match using ===
    /monthly_2023_12/image.png.e65353a236bf01d2779c54b15156f60e.png" />
    but this
    still doesnt
    Yes, but only this way i got it back working. As i have this rule in customer's houses, it is quite crucial for me. They have dozens of remotes,and around 26 blinds..so quite essential to have it working
    Hi Jan
    I have a feature request / integration.
    I would be great with InfluxDB 2.0 integration (this is the one new HA installation uses).  - I searched the forum er there are already some examples for InfluxDB 1.8.
    unfortunately it seems that InfluxDB 2.0 has an different authentication mechanism.
    One more test please
    because you are not getting the id and attr logging which is strange....
    Remote event: #device{id=2452,value={keyAttribute="Pressed",keyId=1},property="centralSceneEvent"}
