    1 hour ago, Neo Andersson said:
    Jan, this error catcher is absolutelly a game changer for me. It is brilliant. Having so many installations, now i can follow the problems, and identify them quickly. However, the catcher logs out the text in incomprehensible format. All the &nbsp and \n stuff is written out and everything is melted together. Sorry i forgot to snap a picture, but i think you know what does this mean.
    I am using it like this to get msg to my phone
    3 hours ago, minsad79 said:
    hi jgab
    Operating in ER4
      TimeOfDayQA = 2108
       rule([[states = {
         {label="Morning", name='morning'},
         {label="Day", name='day'},
         {label="Evening", name='evening'},
         {label="Night", name='night'},
         {label="Dawn", name='dawn'},
       --rule("TimeOfDayQA:positions=states; if TimeOfDayQA:position=='' then TimeOfDayQA:position='day' end")
       rule("@sunrise+00:30 => TimeOfDayQA:position='morning'")
       rule("@12:00 => TimeOfDayQA:position='day'")
       rule("@sunset-01:00 => TimeOfDayQA:position='evening'")
       rule("@22:00 => TimeOfDayQA:position='night'")
       rule("@05:00 => TimeOfDayQA:position='dawn'")
       rule("TimeOfDayQA:position=='morning' => log('morning')")
       rule("TimeOfDayQA:position=='day' => log('day')")
       rule("TimeOfDayQA:position=='evening' => log('evening')")
       rule("TimeOfDayQA:position=='night' => log('night')")
       rule("TimeOfDayQA:position=='dawn' => log('dawn')")
    It doesn't run
    Have the rules changed?
    thank you always
    Does it crash?
    Doesn't it trigger?
    I tested and it worked for me.
    Are you sure about the deviceId?
    1 hour ago, ChristianSogaard said:
    Hi Jan
    It seems there still is a bug on this one
    If I select YES - 1:tryArm runs and works
    If I select No - i get a QA Crash, BUT only the first time the rule runs. Second time no problem, and then again the first time after QA restart
    [21.12.2023] [13:14:07] [ERROR] [QUICKAPP2059]: QuickApp crashed
    [21.12.2023] [13:14:07] [ERROR] [QUICKAPP2059]: Unknown error occurred:
    I managed to reproduce it and made a change that made the error go away...
    The problem is that I don't understand why - next release (tomorrow morning)  will have the fix and you can also try if it works for you...
    Hi Jan
    Best as I thought I was close to done, I can see that my initialization of LastPerson with a person value is causing lots of problems.
    What i did was ...
    because if its empty - im getting errors in
    But its seems that initialization like above is hardcoding LarstPerson to 2120
    [21.12.2023] [15:59:58] [ERROR] [ER2059]: [Rule:5:4]>> [Rule:5:People:value:bin:sum == 1 & HouseIsEmpty => LastPerson = [_:isOn in People][1]; log('First person arrived at Home %s', [_:isOn in People]) ; HouseIsEmpty = false; PeopleMap[LastPerson].id:msg=fmt('%..] Runtime: No devices found for :msg
    But also here...
    [Rule:2:1]>> [Rule:2:HouseIsEmpty & ask(PeopleMap[LastPerson].phone,'Vil du aktivere alarm?', 'Tryk yes at aktivere alarm?', 10) => 1:tryArm] Runtime: table is 'nil' for array reference
    My People map looks like this, why do i only have "id =" at 2120 section ?
    There is something Basale i misses ?!
    I have aQA who crashes today 2 times same QA as earlier this week.
    Change QA>> crash >>> cut modified  save >>> ok >>> add modified part >>> ok
    jan, what can we do with this? Do you have any idea? Should we keep using ER5? Is this something that can ruin the system?
    Ok, my working assumption for now is that if you have a large QA (not necessarily rules, but lines of code) and you update it with QAUpdater, something can go wrong (a bug in the unsupported file-update api)  and you end up with a doppelganger process for the QA.
    I think I know how to verify that and will do some tests today.
    If that is the case, there may be some way to work around it - including the new QAUpdater I'm working on.
    So, in your case, that seems to be hit by this all the time, I would recommend and not use QAUpdater until I have a fix..
    When the system gets this "doppelganger" it seems like only a reboot of the HC3 helps.
    Jan . Your skills are impressive. Big respect 🫡
    Ok,
    I managed to create a doppelganger using the 'SHS ER 5 (v 0.90)' fqa from @Neo Andersson and doing several updates with QAUpdater until I got a doublet.
    It's kind of interesting as the old QA continues to run in the background but there is no way to stop it. Updating or even removing the new QA version, the old version continues to run in the background...
    The only way to get rid of it was to restart the HC3.
    I'm not sure why it happens to  'SHS ER 5 (v 0.90)' and not to other ER5 fqas I tried, I don't know but it could have to do with the file size (> 400kb). It could also be a combination of the file size and the "condition" of the specific HC3 system... or just the HC3 system.
    Anyway, I have released a new version of QAUpdater (v0.72) that disables the QA to be updated, then updates, and then enables the QA again. For me it seems to work as I have not been able to create another zombie process of 'SHS ER 5 (v 0.90)'
    So, @Neo Andersson, try the new updater. It can be updated with QAUpdater.
    If this doesn't work, we have to wait for the new updaterQA with the new update strategy....
    • Thanks 2
    Jan some info
    System resources 6% mem free used 58% after 3 hours uptime time seems to high.
    Perhaps some stuff does't give memory back as it was a time ago?
    QA Livingroom crashes no indication why
    I toke a fresh QA from Updater copied my rules into it
    Changed some optical issues saved about 20 times and no crash at all, I hope it will stay
    Restart HC3 sytem resource 21% free used 51% after 15 min uptime
    Hi Jan - a small update...
    im still getting Crash for the ASK function, if nothing is answered at the Phone
    rule([[HouseIsEmpty & ask(PeopleMap[LastPerson].phone,'Vil du aktivere alarm?', 'Tryk yes at aktivere alarm?', 10) =>
        log('Ask Lastperson to ARM '++LastPerson);
        log('PeopleMap[LastPerson]. '++PeopleMap[LastPerson].phone);
        1:tryArm
    @ChristianSogaard I also have QA crash with unknown error> I don't use ask function.
    In my case remove your rule, save, paste rule, save and I hope as by y QA your error QA crash will be gone.
    I am curious.
    I am curious.
    Ill test, but re-create the Crash, buy following a specific procedure, and if I delete my ASK rule, its gone.
    Thank you for sharing @Sjakie
    @jgab Jan, is it something normal, to have 10 000 invocations /day for a system with 102 rules? Just for curiosity. It doesnt have ghost processes, as i have restarted the HC3.
    On the other hand, after a longer period of time these numbers will get to really high values, as it goes to inifinity by time. Will that be okay in system to handle these numbers?
    Like having millions and millions of fails, invocationis, successes etc..and all that will be written out to UI..
    @ChristianSogaard not delete >>ctrl_X and copy it in some other .TXT file
    Jan, it's okay, that we will have a better QAupdater for avoiding ghost processes. But how should I work on those systems? What is your recommendation? Because every time i edit the code, or add something new into it / ex customer called that he needs something ?
    Every time  i change the code, and save the QA the ghost processes arrive. Every new save of the QA creates a paralell running process. So this way i am not able to maintain the code,manage it, or fix some issues. Am i? If so, how to do it?
    Edited by Neo Andersson
    How do i create my own trigger ??
    I have a GAS meter im reading consumption from a pulse counter
    Using Swagger i see my Data is stored in properties.parameters.value
    How do a get the properties.value into a variable ?
    I also tried this
    But here, i never gets a trigger
    Here I get the trigger, but no Value
    rule("#device{id=2046, value='$value'} =>  log('Gasmåling .... trigger fra ',value) ")
    Edited by ChristianSogaard
    Typo
    Well, it's a lua math.maxinteger (9223372036854775807) so with 10000 invocations / day it will last for 2526951242973 years.
    However, 10000 invocations seems high - but as long as fails + successes ~= invocations it's probably right.
    Ok, that's interesting because if I edit your qa and save it, it will not generate a ghost for me. I had to really abuse it with QAUpdater before I got a ghost.
    I actually suspected that saving the QA from the editor could also causes ghosts because I assume the editor and QAUpdater use the same APIs to save the QA files.
    That would also explain issues that people had in the past with other QAs.
    So, there could be a couple of reason (and maybe combined)
    So, a QA that has a lot of active timers and outstanding http requests could have issues if code is replaced and being forced to restart.
    That's why I'm now disabling the QA before updating because then no timers or http requests are active when the files are updated.
    I'm not sure what to do in your case. Try to slim down the QA by removing unnecessary QA files (I saw that some of them only had commented code lines)
    May disable the QA before editing it and then enable it using the web ui?
    So, by editing the QA in the web UI causes a ghost than it's really a bug for Fibaro to fix...
    ...and because it happens seldom and to a few systems, I also suspect it has something to
    do with the systems "condition"...
