@jgabJan what is this error? The code is working for me at home, but not on customers system. He has version 0.8 too
    --                                              CHILD DEVICE DEFINITIONS
    rule("child('ID1','SHS Zwave list button','com.fibaro.binarySwitch')")
    rule("child('ID2','SHS Zigbee list button','com.fibaro.binarySwitch')")
    rule("child('ID3','SHS Create cloud backup','com.fibaro.binarySwitch')")
    rule("child('ID4','SHS Create local backup','com.fibaro.binarySwitch')")
    -- CREATING CHILD DEVICE FOR LISTING ZWAVE DEVICES
    rule("initChildren()")
    --1.
    rule("#UI{id=ID1,action='turnOn'} => ID1_D:updateProperty('value',true)")  -- Map turnOn action
    --2.
    rule("#UI{id=ID1,action='turnOff'} => ID1_D:updateProperty('value',false)"-- Map turnOff action
    --3.
    rule("ID1:isOn => shs.DeviceList('zwave'); wait(00:00:02);ID1_D:updateProperty('value',false) ")
    -- CREATING CHILD DEVICE FOR LISTING ZIGBEE DEVICES
    --4.
    rule("#UI{id=ID2,action='turnOn'} => ID2_D:updateProperty('value',true)")  -- Map turnOn action
    --5.
    rule("#UI{id=ID2,action='turnOff'} => ID2_D:updateProperty('value',false)"-- Map turnOff action
    --6.
    rule("ID2:isOn => shs.DeviceList('zigbee'); wait(00:00:02);ID2_D:updateProperty('value',false) ")
    -- CREATING CLOUD BACKUP
    --7.
    rule("#UI{id=ID3,action='turnOn'} => ID3_D:updateProperty('value',true)")  -- Map turnOn action
    --8.
    rule("#UI{id=ID3,action='turnOff'} => ID3_D:updateProperty('value',false)"-- Map turnOff action
    --9.
    rule("ID3:isOn => checkBackupPossibilityAndCreateNew('remote'); wait(00:00:02);ID3_D:updateProperty('value',false) ")
    -- CREATING LOCAL BACKUP
    --10.
    rule("#UI{id=ID4,action='turnOn'} => ID4_D:updateProperty('value',true)")  -- Map turnOn action
    --11.
    rule("#UI{id=ID4,action='turnOff'} => ID4_D:updateProperty('value',false)"-- Map turnOff action
    --12.
    rule("ID4:isOn => checkBackupPossibilityAndCreateNew('local'); wait(00:00:02);ID4_D:updateProperty('value',false) ")
    What is the previous error(s) before the "for iterator". The problem seems to be that the children is not created (due to some earlier error) so when ER is looping (for iterator) over the children they don't exists and crash.
    So, the error I see is a follow up error of something that happened earlier in your time line...
    19 hours ago, Neo Andersson said:
    Jan, it is working for /backups endpoint, but it doesnt work for others, like the examples below, one for canCreateBackup
    the example above returns empty data. I tried also with some header combinations but no success.
    Also tried to delete some backups , but no success. In old fashion way, with hardcoded credentials i used to use this for deletion. and its working
    Yes, you are right - there seems to be something buggy about it. /backups return correct, other returns "" with type html/text... and if called through api.get we get an internal json.decode error...
    Upgraded to 0.84 and its working. Will check on it later.
    On 12/11/2023 at 10:44 AM, jgab said:
    Well, your (virtual) deviceIds has nothing to do with userIds so you need a mapping table
    So, USER(name) is an existing function that returns the HC3 user with the name name. It returns the whole struct, like you get from swagger.
    Then we just retrieve the .id that is the user Id and map it to the virtual device id
    should then work...
    Actually, there is a small bug - but it will work in v0.82 coming later this afternoon.
    hi Jan
    I integrated the PeopleMap and it works in Rules with One person being detected like this,
    Having Rule returning more than one person at home - i cant see how to use the table
    I tried wrap it in like this, but no success
    elog is the "extended" log function that has some extra %specifiers, like %l that inserts a list of values without the '[' ']'...
    Got it - Thank you
    I made HouseIsEmpty  a triggerVar.
    used at this rule
    also tried
    Very similary to the Rule you provided
    rule("@sunset & ask(1861,'Light automation', 'turn on X-mas tree?', 10) => xmastree:on")
    Rules:
    1:[Rule:1:People:isOff => log('House Is Empty...'); HouseIsEmpty = true --PeopleMap[LastPerson].id:msg=fmt('%s du har som den sidste person forladt hjemmeet',PeopleMap[LastPerson].name)] [enabled]
    2:[Rule:2:HouseIsEmpty & ask(LastPerson,'Vil du aktivere alarm?', 'Tryk yes at aktivere alarm?', 10) => 1:tryArm] [enabled]
    I am getting a crash when triggers - it looks that ask(LastPerson,'Vil du aktivere alarm?', 'Tryk yes at aktivere alarm?', 10)  causes the crash?
     [17.12.2023] [16:25:28] [TRACE] [ER2059]: [Rule:7:9]>> FALSE #device{id=2120,va.. -> People:isOn => log('People at Home usi..
    [17.12.2023] [16:25:28] [TRACE] [ER2059]: [Rule:2:5]>> suspended triggered - callback
    [17.12.2023] [16:25:28] [TRACE] [ER2059]: [Rule:4:13]>> FALSE #TV{HouseIsEmpty=t.. -> People:value:bin:sum == 1 & !HouseIsEm..
    [17.12.2023] [16:25:28] [TRACE] [ER2059]: [Rule:5:13]>> FALSE #TV{HouseIsEmpty=t.. -> People:value:bin:sum == 1 & HouseIsEmp..
    [17.12.2023] [16:25:38] [TRACE] [ER2059]: [Rule:2:5]>> FALSE #TV{HouseIsEmpty=t.. -> HouseIsEmpty & ask(LastPerson,'Vil du ..
    [17.12.2023] [16:25:38] [ERROR] [QUICKAPP2059]: QuickApp crashed
    [17.12.2023] [16:25:38] [ERROR] [QUICKAPP2059]: Unknown error occurred:
    [17.12.2023] [16:26:04] [DEBUG] [QUICKAPP2059]:
    EventRunner5, deviceId:2059, version:0.84
    Edited by ChristianSogaard
    Typo
    @ChristianSogaard Is there a specific argument why you ask last person to arm the house instead of arming automatically when everybody left?
    Or are you using also Android phones?
    :-) good input @Sjakie
    No special reason. I think i just like the Option to choose better.
    Ok thanks. I do if everybody left automatic house will be armed. Problem of human is they forget or got distracted.
    Cheers
    Are there issue with timers?
    [17.12.2023] [21:51:59] [TRACE] [ER2059]: [Rule:3]>> scheduling daily for 22:53:00
    17.12.2023] [21:52:12] [TRACE] [ER2059]: [Rule:22:1]>> TRUE #UI{cmd="listTimer.. -> #UI{cmd='listTimers'} => listTimers()
    [17.12.2023] [21:52:12] [TRACE] [ER2059]:
    Timers:
    22:50:00 -> @[Rule:2]
    22:53:00 -> @[Rule:3]
    [17.12.2023] [21:52:12] [TRACE] [ER2059]: [Rule:22:1]>> result [Rule:22:1]
    But it dont seems to trigger ?
    @jgab something Fibaro?
    2-27 is executed 2-39 is listed here but happily not executed belongs to another part of an || rule.
    Weird it's traced
    Timers:
    Your last log  says 21:52:12 but the rule was for 22:53:00
    Weird it's traced
    You need to give me more info - listing of rules etc.
    You end the rule with
    so the double ';;' ends the ||>> statements and the last statement (log) will always be run.
    That was  embarrassing - too tired or too fast i guess. I am sorry Jan
    What about this one
    Im pretty sure i didnt do any typos and tested a lot
    17 hours ago, ChristianSogaard said:
    Got it - Thank you
    used at this rule
    also tried
    Rules:
    Isn't ask(PeopleMap[2120] a table with id and name?
    So you send a table instead of an integer as the first argument of ask? Could make the fibaro api barf...
    I will add a type check to the ask function in next version.
    i see..
    Using 1861 instead of LastPerson - gives me the trigger but also the QA Crash
    1: tryArm works in other rules (the Pointer show the Error is there, right?).
    If I want to use LastPerson, then lastPerson need to get the ID from the PeopleMap right?
    Like ... ask(PeopleMap[LastPerson].id
    But this gives me - Runtime: table is 'nil' for array reference
    I guess this because that LastPerson starts with being noting -> var.LastPerson = ""
    So i tried var.LastPerson = 2120 - the Runtime: table is 'nil' for array reference goes away - one down ;-)
    returns 2 for Admin user, when House is empty, that is correct but i need the mobile phone ID associated to the USER, right?.
    Jan you do message the iPhone with the user ID - not Phone ID - but it seems i cant do this with Ask - is that right?
    @jgab Jan how can i learn, what is the error that is shown in UI below?
    It is unsearchable inbetween logs, as it probably happened too long ago so the debug window can not list it.
    Is there a way to determine what caused this error?
    No, if it's "scrolled out of the console" it's lost.
    I could probably come up with a special log buffer for errors so one could list them...
