Jan, i have tried to use the inbuilt :last property for my purpose, but it seems to not fit my requirements, as PIR sensor do not have this value reported at all. I am attaching the swagger Json too .
They have lastBreached value.
So i decided to create my own property lastBreached and use it
then used it in our previous example
but this doesnt work. Throws error
Okay i realized that :last gives me the same as lastBreached relative to 00:00 i think, but for some reason when i run the test it still lists out a sensor that was breached today at 9:53
So if i keep using the :last property check, and test it with only one sensor, that i am sure was breached recently it still lists me out that sensor as it was not breached in last 24 hour
    :last should be relative to now, the number of seconds since it was last changed.
    Jan, the sensor above in the example was last breached / see ot swagger screenshot / at 9:53 today, but it is still listed in the  :devs = [ _:last > 24:00 in SensorsToCheck]
    for the sensor that was breached 9:53 and see what you get
    test a
    rule("id:last")
    test a
    rule("id:last")
    9.53 today, or 9:53 yesterday, or 9:53 last month?
    It was definitely today, but i cant cjeck it anymore, as my colleague stepped into that room,..but in previous pics you see it.
    On the other hand, this rule should log either the sensor is longer inactive than 24 or log me that is okay..
    It says uknonwn token type.
    Last err: [Rule:62:@12:39 => local devs = [ _:last > 24:00,fmt("%s:'%s'++\n",_,_:name) in Sensors..] Parser: unknown token type: rpar || size(devs) == 0 >> log('All devices are okay')) ^
    Isn't the size the right syntax for getting the lenght of a table?
    Yes, but the last has an additional ')'
    Jan if i got this warning ? Seemingly everything works, but for case i show you
    Host not found (authoritative) fetching https://raw.githubusercontent.com/jangabrielsson/TQAE/master/jgabs_QAs/Updater/MANIFEST.json
    Well, it's the hc3 (QAUpdater) that accesses the GitHub server to get the updates info - and couldn't find it...
    I would say that your DNS had a hiccup  - if it was github that was down we would have heard about it ...
    Jan, can we use += syntax? Like value += 15  (substitution for value = value + 15)
    I tried inside a rule: ... blind:value += 30, and it threw an error
    You can but not to :value - only to variables, ER variables, $variables, and $$variables (quickAppvariables).
    Because not all :properties have a set version, it's too complex to test.
    Pushed v0.62
    It's a candidate for v1.0
    Bugfixes and cosmetics.
    There is a rule stats that lists the last 10 rule actions in the QA UI.
    There is also a button that lists the last 100 actions (You need to add the button binding to your main)
    Jan, what is the syntax of UI button press call, or UI dropdown select call in ER5
    I still have to define the callbacks as class functions? like
    If not, how to catch a UI button press / like if i have created a button on ER5 interface
    How to cacth dropdown change etc
    I cant find description for ER5 about UI event hanbdling
    Well, it's not recommended to add your own buttons to ER. The reason is that the QAUpdater will restore the interface to the standard and you loose the buttons you have added.
    I would recommend that you create another QA that serves as the UI and sends commands (events) to ER.
    Jan I just see this error don't know when it started to be an error.
    badkamer is a number.
    It's a strange expression - it's not a rule because there is no "=>" in the expression.
    So, it will always do all the statements...
    Okay, rather i have created child devices..i suppose, they wont be affected by Updater right?
    No, they won't.
    @jgab Jan why is this error?
    [07.12.2023] [19:31:00] [ERROR] [ER1302]: [Rule:188:2]>> [Rule:188:@19:31 => local devs = [ _:last > 24:01,fmt("\n%s ► %s",_,_:name) in Sensors..] Runtime: ./include/utils.lua:37: bad argument #2 to 'insert' (position out of bounds) flsetup
    Sorry, found it.
