    15 minutes ago, jgab said:
    pushed v0.36
    Ok, the ';;' was a bug - I thought I fixed that weeks ago but somehow it was reverted to the old code... Now it should work.
    The newline I can't see whats' wrong. Strange that it works in rule("....=> text1 ++ '\n' ++ text2") but not the with the simplePush...
    I will try to look into it...
    Ahh, I know what it is. The first example is a multiline rule with [[]] isn't it? The problem is that Lua don't translate \n to newline in those strings. You get the string "\n".
    I could probably get around that by doing the translation in the parser - let me come back on that...
    Yeah, thats a mutliline, It would be nice if you could fix this, becuase i am sending PUSH messages to cusomters every evening about device statuses, and it looks really awfully without linebreaks. Its almost unreadable.
    THanks
    18 minutes ago, jgab said:
    pushed v0.36
    Jan what is this?
    Any1 got a suggestion on how to trigger on profile change?
    Found out this on is on the globals , but cant find any on profiles 😅
    rule("$Home == 'HOME' => AutoPirSov1:on")
    Edited by Brors94
    I haven't tried it in ER5, but in ER4 this should work according to @jgab
    Edited by Neo Andersson
    2 hours ago, Neo Andersson said:
    Jan what is this?
    Sorry, test variables that followed my release - will remove in next version.
    Yes, it works in ER5 too - I will try to come up with some short form....
    @jgabJan i just can get http calls working with rules.
    Any assist please would be appreciated.
    1. How to form a POST using rules. Please proved some example. Where to put data forexample when calling my raspberry? How to wrap this example below into a rule?
    2. I could run some GET call in rules but i cant get it working when returned data is a table
    3. If i need to process my returned data coming from my GET call in a custom function (callback), how to use it in a rule?
    Thanks so much
    Thanks so much
    2. This was a bug using key.key[index].key expressions. I missed that. Fixed in v0.5
    3.
    v 0.5 pushed.
    - fixed cosmetics...
    - \n\r\t are now translated in multiline strings
    - fixed bug in table indexing
    - fixed dangling ';;' bug.
    On 11/27/2023 at 1:14 PM, ChristianSogaard said:
    Thank you Jan
    Almost there :-)
    I need to filter out doublets - in below case there is 3 alarm zones -  and i get messages from both Partition 1+2  because they have overlapping sensors.
     In v0.5 there is a table.union that merges two lists removing duplicated. Change table.append to table.union in the example and it should work.
    On 11/14/2023 at 7:17 PM, jgab said:
    Alarm rules
    Alarm in the HC3 is implemented by Fibaro using the concept of partitions.
    Partitions are armed and disarmed. Individual devices (typically sensors) belongs to partitions
    and if a devices is breached that belongs to a partition, the partition is breached and we have an alarm.
    In ER5 we have properties to query partitions for their state
    <partition>:armed - returns true if the partition is armed - 0 means the house
    <partition>:tryArm - will try to arm the partitions - 0 means the house
    <partition>:isArmed - returns true if the partition is armed - 0 means the house
    <partition list>:isAllArmed - returns true if all partitions are armed
    <partition>:isDisarmed
    <partition list>:isAnyDisarmed - returns true if all partitions is disarmed
    <partition>:isAlarmBreached
    <partition>:isAlarmSafe
    <partition list>:isAllAlarmBreached - returns true if all partitions are breached
    <partition list>:isAnyAlarmSafe - returns true if any partitions is safe
    and properties to change the alarm states
    <partition>:armed=true - arms the partition - 0 means the house
    <partition>:armed=false - disarms the partition - 0 means the house
    <partition>:tryArm is special as it will try to arm the partition/partitions and if it doesn't succeed because their
    is a breached device in any of the partitions it will post an event that list the partitions and devices that are breached.
    Note that the arming will continue and if not cancelled, the partition will be armed and at the same time breached because of
    the breached devices.
    To handle that, one can make a rule that trigger on the posted event,
    Ex:
    To trigger a rule if there is a breached partition/home, it's easiest to trigger on the events generated (in the future there may be properties)
    Unfortunately, if a partition is armed using the web UI/Yubii app, we don't get any warning from the fibaro api before the partition is armed - maybe in the future...
    Hi Jan
    it looks like that tryArm always takes partition 0 (all zones) no matter what partition i type - example here is 2, but it arms alle partitions
    And how would a correct log syntax looks like - if i dynamic want to add the partition name in the log?
     || !0:armed >> 0:tryArm;    log(__TAG,efmt('Armed partition:%s',env.event.id))
    Edited by ChristianSogaard
    Typo
    Thanks so much
    http.post(url,options,data)
    2 hours ago, ChristianSogaard said:
    Hi Jan
    I don't see that problem when arming partitions..., some more details?
    Well, partition 0 is the house/home so that name is given. To get the name from a partition id you need an helper function
    (I may build something like it into ER5 in the next version...)
    Jan, this is strange. I am running at home on 0.36 and there is no newer version in updater, on the other hand I am running on 0.35 at customers project but there is not even 0.36 version in QAupdater? QA updater is on 0.67 on both systems.
    /monthly_2023_11/image.png.5851fd1aff3806c9a4922557d5631606.png" />
    Sure :-)
    This rule triggers and do 2.tryArm
    Should just arm 2 - right
    end up ARMing everything
    I updated this morning which means that QAUpdater got the new database that is stored on github - so it should work for you too.
    Note that the Web UI for QAs not always updates  correctly so you need to flip between tabs to get the labels to update...
    QAUpdate has it's own version number - it's been 0.67 since July 14, 2022.. ;-)  (I'm still running .66)
    QAUpdater can update and install different types of QAs, EventRunner5 being one of them
    You have to Refresh to get the new database of updates.
    Then select the QA update
    Then select the version of that QA update (usually 3 versions available so people can revert if something is wrong with the new update)
    Then selected the installed QA to update (if you have many ER5 QAs installed
    In a future version of ER5, ER5 will talk to QAUpdater and ask if there are any ER5 updates and then notify the user....
    • Like 3
    Sure :-)
    Can you post rule 5,6,7 too?
    The rule you posted was number 3 (with the keypress)
    Rules:
    Typo
    @jgab Jan it is probably my diasbility, but this doesn't worj for me.
    I am getting this debug in nodered when i try to use it with rules and when sending regularly.
    /monthly_2023_11/image.png.a181af43c5bcf96c76fc918085bd82d5.png" />
    1. It seems that i should have my data in  format like when sending with regular function. I dont know how to convert it in a rule.
    2. Also i noticed that using global variable ex $somevariable == 'en-En'  inside a rule post data, then it complains that it should be a string. Probably ERmechanism converts is somehow. How to not convert 'en-En'  and keep it as string?
    @jgabJan how can i access a nested table value in a rule?
    1.
    2.
    I cant wrap into one line nested II >> calls
    I have tried several ways..using {} for nested ||>, using ;;...ehhhh
