Jan I have a problem how to tackle? I do one cycle deur OPEN and Nachtslot
than I press an press and press............................no action only false.
I have 3 HUE switches who act all the same. I also tried HoldDown same result.
In history I see every push on the button
    How are these Hue switches integrated with the HC3? Using childrenOfHue?
    Yes in your COH 1.22
    Pressed followed automaticaly by released,  HoldDown >> shows in history
    There is also the approach that one builds a more complex tree of devices, like
    local HT = {
       kitchen = { lights = { tableLight=88,  roofLamp=99 }, sensors = { sensor1 = 53, sensor2 = 51 }},
       hall = { lights = {  roofLight1 = 101, roofLight2 = 109 }},
       bedroom = { lights = { roofLight = 201, bedTableLight1 = 204, bedTableLight2 = 205 }}
    One could also generate this table by leveraging the rooms and sections that devices are placed in.
    Anyway, I'm sharing a feature that comes up in next version, a new property called :leaf
    The reasoning is that the hometable, (or other ER defined variable with deviceIds) can be seen as a tree,
    where ex. kitchen in this example has 2 leafs, tableLight and roofLight.
    This is a good structure, but it also means that we can't do
    because kitchen.lights is not a list of devices, it's a key-value table, so it doesn't work.
    Well, :leafs takes an arbitrary complex key-value table and returns a list with the leafs (removing duplets)
    so, we can now do
    ...and it turns on all lights in the kitchen, without the need for a duplicate list variable.
    I'm also thinking how to filter out appropriate devices from the list , ex. only the lights or only the sensors...
    I'm not sure I understand what you want to do. The log show that the rules trigger on 1:Pressed and 4:Pressed
    What is not working as expected?
    Jan with the lights on/off I don't have a problem.
    I have aproblem withGV's sometimes they don'follow the rule fa
    If I check it's still $Verl_Dagdeel = 'Middag_Vroeg' so it skipped two other parts???
    the false in the log are also press the button
    but no respond in QA it show the action in History
    Jan I never used those HUE dimmers in HC3.
    Here in ER% I got the idea to use them for enable arming if we go to sleep and to open manual by this switch the Dana lock, both a WAF project.
    So no experience how it should behave
    For HUE lights I have the grouped them in HUE app and don't often use a single light, if Ido it's to set different valus for brightness
    Edited by Sjakie
    add HUE
    The false in the logs are "Released" or "HeldDown" or the wrong keyId and thus false as far as I can see.
    Well, using an interval like this as a trigger is not so good.
    An interval like 12:00..16:15-1
    will trigger the rule at 12:00 and at 16:15-1+1
    The first trigger will be true, because it's 12:0, the second will be false because the time is > 16:15-1
    So, in effect, your rules trigger at 12:00, 16:15, and 18:00 respectively.
    That means that if you restart the QA at 18:15 it will not trigger and change the variable.
    You could add a .start() at the end of the each rule to trigger them at restart so that the varible is set accordingly.
    All button pressed after 19:53:32 are false!!!
    In history I see
    Losgelaten>>Releasedbut I also press before I can release??
    It's the same device
    5 hours ago, ChristianSogaard said:
    When using tryArm like this
    seems to work fine -ALARM cancel the arming if a windows is opened.
    But next step is post a message, which windows is opened. and i was expecting that below rule would give me that,.
    from the log, it seems that it newer triggers ?
    Its strange
    Trigger of the rule works.
    But even if my 3 alarm zones already are armed, it always run the !0:armed >> 0:tryArm.
    It sould be a toggle function enable/disable the alarm.
    Jan error posting scene events. I have added "sceneEvent" to self:enableTriggerType
    I use scene event, the scene itself is empty and used as a trigger that ER can read to do its thing (your code aswell :) )  I can then also use an apple shortcut to set an alarm dynamically called sunrise nursery to call the same scene.
    I'm getting this error
    [26.11.2023] [13:33:01] [TRACE] [ER311]: [Rule:28:3]>> TRUE #sceneEvent{id=11,.. -> #sceneEvent{id=11,value='started'} => ..
    [26.11.2023] [13:33:01] [TRACE] [ER311]: [Rule:28:3]>> Posting #sceneEvent11{} at Sun Nov 26 13:33:01 2023
    [26.11.2023] [13:33:01] [TRACE] [ER311]: [Rule:29:3]>> TRUE #sceneEvent11{} -> #sceneEvent11 => 60: value = 0; 60:on;..[
    26.11.2023] [13:33:01] [ERROR] [ER311]: [Rule:29:3]>> [Rule:29:#sceneEvent11 => 60: value = 0; 60:on; 60:dim = {00:15:00, 'up', 00:00:01, 'Li..] Runtime: ./include/utils.lua:319: attempt to call a nil value (method 'post') putprop
    #sceneEvent11 => 60: value = 0; 60:on; 60:dim = {00:15:00, 'up', 00:00:01, 'Linear', 0.99}; log('sceneEvent11 Sunrise nursery started')
    hi jan
    EventRunner 5
    In
       -- Bathroom, uses a local flag (inBathroom)
       rule("trueFor(00:00:20,Livingbath_sensor:safe & Livingbath_door:value) & !inlivingBathroom => Livingbath_light:off")
       rule("Livingbath_sensor:breached => Livingbath_door:safe & inlivingBathroom=true; Livingbath_light:on")
       rule("Livingbath_door:breached => inlivingBathroom=false ")
       rule("Livingbath_door:safe & Livingbath_sensor:last<=3 => inlivingBathroom=true")
    Doesn't this rule support this action?
    Normal in ER4, error in ER5
    Sorry, this was a bug in the dim code. Next version today will have a fix.
    11 hours ago, ChristianSogaard said:
    Its strange
    What error do you get?
    3 minutes ago, jgab said:
    Sorry, it was a bug in 0:armed (whole house). Fixed in next version.
    [2023-11-26] [03:23:10 PM] [ERROR] [QUICKAPP2300]: Last err: [Rule:2:Livingbath_sensor:breached => Livingbath_door:safe & inlivingBathroom=true; Li..] Parser: left hand side of assignment unsupported Livingbath_sensor:breached => Livingbath_door:safe & inlivingBathroom=true; Livingbath_light:on ^
    Yes, there is a change in ER5 language.
    In ER4
    a & b = c & d
    was interpreted as
    a & (b = c) & d
    in ER5 it is interpreted as
    (a & b) = (c & d)
    because & has higher priority than =
    To fix you rule add parenthesis around the assignment
    v0.34 pushed
    Fixed bugs causing problems for @Sjakie and his key rules
    Also, a general bug for trigger handling so I recommend all to update.
    Fixed 0:armed bug ( @ChristianSogaard )
    dim bug fixed ( @Pica2017 )
    Good morning and thank you verry well!
    4 hours ago, minsad79 said:
    hi jan
    EventRunner 5
    In
    When I got this problem report from @minsad79 I tried to run it, but I figured out quickly that it was an issue with the new language in ER5.
    However, to debug this kind of rules, one can setup a simple simulation of the devices involved.
    Redefine the sensors and lights 'Livingbath_x" with simulated binaryDevices.
    er.createBinaryDevice() creates a simulated binary device and returns the assigned deviceId.
    Then we have the bathroom rules as usual - now using our simulated devices.
    Then I setup a remote/keyfob so key presses toggles the door and motion sensor and logs a message what new state they have.
    I also setup debug options so the console output is not so noisy
    Then I can lean back, press the remote to toggle the state of the door and the sensor and see how the rules are triggered...
    WIthout having to run to the bathroom and open and close any door or breach any sensor :-)
