    17 hours ago, ChristianSogaard said:
    Converting ER4>EV5
    Works in Ev4 but not in EV5
    [23.11.2023] [17:48:20] [ERROR] [QUICKAPP1961]: Last err: [Rule:57:trueFor(00:04:00,Flisegang:safe & entre.FliseAutoORManuelt) => 1184:off; entre..] Rule: nil is not a valid device trueFor(00:04:00,Flisegang:safe & entre.FliseAutoORManuelt) => 1184:off; entre.FliseAutoORManuelt=false ^
    Works in EV5
    is this by design or me messing up ?
    Ahhh, that was a big fat bug in my rule compiler - thanks for running into it. Will release a new version within an hour...
    17 minutes ago, Neo Andersson said:
    I am a bit confused now..
    I think || >> lines never needed any ; in ER4
    Only after the whole ||>> part is finished, and you needed to add some other statements after, there you needed the ;; to mark the end of the ||>> part
    Did this change in ER5 to some other pttern? I doubt,because my ER5 based home system never complained about this
    In ER4 I think you could end with an ';' before next '||'. In ER5 you can't. The double ';;' was to mark the end of the whole ||>> sequence.
    Jan for me it's not clear how to write in ER5
    I have HUE switch to open frontdoor
    If I try
    Result is hal.keukenDeur is breached in white! color
    What am I doing wrong?
    How to do for post or remote in a different color?
    Jan, i have nothing showing up in debug window except Setting up rules...
    This is the global debug settings from ER5
    I dont have any rule debug options directly in rules.
    Why don't I see nothing?
    So, per default it logs user logs on the tag QUICKAPP<ID>
    and "system logs" on ER<ID>, so you need to choose both tags in the console.
    It's actually a settings
    er.settings.systemLogTag = "ER"..self.id
    and if you set it to nil it will use the standard QUICKAPP<ID> tag for system logs too.
    er.settings.systemLogTag =nil
     When the rules are working it can be nice to just have the user logs in the console and not clutter/mix it with system logs too.
    and how to chage colors?
    Like this blue on the picture,
    Strange that it's blue....?
    Below the settings there is a custom rule log function
    and it should set the true and false to light green and lighter resp.
    Yeah i have noticed that but since for me its BLUE i thought this is not the place to define
    Actually the TRUE is in green
    Edited by Neo Andersson
    It's strange because it should translate to html font color, like
    <font color='lightgreen'>....</font>
    /monthly_2023_11/image.png.7a125b073d3b192198d54db1ca331ff8.png" />
    I think the lightgreen is okay, only the lightred doesnt work..its blue for me, maybe it is browser sepcific problem, but this blue for me is almost unreadable
    I have used #d45767 as in hex format for lightred and it works
    If I try
    You define warningOptions but use warnOptions which is nil…
    Jan, sorry just copied from you where you discribed  "You define warningOptions"
    How can I do simular for post or remote? to give it their own log color?
    How does the post and remote rules look like?
    3 hours ago, Neo Andersson said:
    @jgab Jan we also had a conversation about the better trace of timers in trueFor.
    Somehow, i need to get the information about a trueFor rule's timer. Where is the counting at a moment. ex how much seconds remains to the trigger..Like in case of delayed opening of a door, i can show the remaining seconds to the user..is that too complicated?
    And also we tlaked about action calls where the state should be chceked first and not performed any operation if the desired state is already present. Now i am using for it my own function that actuially follows this logic ... => device:isOff & device:on
    Sorry, one more thing
    using push and simplePush somehow..i think at this moment only push is working..notifications for devices doesn't have support even in ER4..maybe i am wrong
    Look at (and try) this rule(s)
    We have a trueFor that is started by assigning a triggerVar true.
    When a trueFor starts, run the action, or is cancelled, it will post an event #trueFor{status=..., time=<time>, id=<ruleId>}
    We save the rule in the variable tfr and check against tfr.id in our next rule.
    If it is a trueFor event from our previous rule (id=tfr.id) we check if status is 'started' and then we start to count down every second.
    Here we could do other stuff, like update an UI label.
    If the rule is triggered by an #trueFor event with another status ('cancelled' or 'action') we don't start the loop and count down.
    ....but because we have set the rule to .mode('killOthers') it will kill the first instance of the rule that is counting down...
    Let me come back on push - I'm just using what's available in the fibaro api and I think there is no simplePush anymore...
    Ok, you have different colours for different logs in the same rule - then you need to do something like you do.
    The option option is only for the whole rule.
    Pushed v0.31 with a bug fix, thanks @ChristianSogaard
    Also some small additions.
    ok, thanks.
    How to write as trigger?
    3 minutes ago, Sjakie said:
    ok, thanks.
    rule("hal.Switch_Voordeur_Slot:central.keyId==1 & hal.Switch_Voordeur_Slot:central.keyAttribute=='Pressed' => ...
    ...but there is coming a better (shorter) way of doing it....
    Custom properties
    Defining your own properties can be done in two ways.... (Obs. need v0.31)
    This describes the first way - adding property functions to standard devices - the devices/resources we describe with numbers.
    Like
    55:isOn
    To add an :onIfOff property we can do
    and use it like
    So there are 3 things ER want to know about a property to be able to use it.
    What should
    <id>:<property>
    mean. We call this the 'getProp' function for a property. It is when we return the property value of a device/ID.
    Then, what should
    <id>:<property> = <value>
    mean. We call this the 'setProp' function of a property.
    And lastly, when used in the condition part of a rule, what sourceTrigger should it trigger the rule on.
    If we leave the setProp out we can't assign to the property (which is ok for some properties)
    If we leave the trigger out they will not act as triggers in the condition part of a rule (which is also ok for some properties).
    Assume we have a property 'windowOpened' and we would like to make that a user :property.
    Here we declare the getProp, and it just returns the fibaro.get(id,'windowOpened')
    We also define a setProp function (I'm not sure we can set it but lets pretend) that sets the property
    and lastly we define how the sourceTrigger should look like for triggering the rule.
    We can now write
    rule("8888:windowOpened == true => ....")
    and the rule will trigger when device 8888's property 'windowOpened' changes value.
    In the condition we access the value with the getProp function and we compared it to true and if ok we run the action.
    A useful extension is to make a simpler centralSceneEvent property - we know it's a key and a keyAttribute
    Now we have a :key attribute that returns the key..":"..keyAttribute as a string
    The
    3x'=' is the string match function and the same as string.match(a,b)
    So the rule triggers on centralSceneEvent, return the :key that is something like "4:Pressed"
    and we string match that against "4:.*" that will match keyId 4 and any keyAttribute in this case.
    If we are only looking for "Pressed" we can just do
    Custom objects
    The other :property functions are those we define for custom objects.
    The stdProp in the previous example assumed that the id was a number, the way we describe devices and rooms and sections and alarmPartitions etc.
    If we would like to have a weather property we can't use this approach as the weather resource don't have a number id.
    But we can define our own custom object and define property functions on that
    We define a new class Weather and for that class we define property methods similar to the previous example, getProp, setProp, and trigger functions.
    In this case we don't have setProps as we can't change the weather...
    To use this we need to make the Weather object available in ER so we declare a variable
    var.weather = Weather()
    We can then in rule use
    rule("weather:temperature > 40 => log('It is hot!')")
    In fact, the weather variable/object is already available in ER5 defined in this way - so go ahead and use it...
    Anyway, this is a bit more advanced usage, but works if we want to define :property methods for resource that doesn't have number ids...
    1 hour ago, jgab said:
    Custom properties
    Like
    55:isOn
    and use it like
    What should
    <id>:<property>
    Then, what should
    We can now write
    The
    I have a lot of rule like this - i guess i can convert them to the new format ?
    rule("matrix_Kitchen_Bottom:central.keyId==4 & matrix_Kitchen_Bottom:central.keyAttribute=='Pressed' => {1980,1981}:close")
