    Just now, ChristianSogaard said:
    I have a lot of rule like this - i guess i can convert them to the new format ?
    rule("matrix_Kitchen_Bottom:central.keyId==4 & matrix_Kitchen_Bottom:central.keyAttribute=='Pressed' => {1980,1981}:close")
    Yes, the :key property will be built in from next version. (v0.32 later this evening)
    Really cool, thank you Jan
    Please remember the rule("uptimeMinutes < 5 => post(#HC3_restart)") you mentioned earlier, i dont work for me yet
    Ah, sorry it's not a rule (no =>), just a test that is run when the rules are loaded. I changed the original post too.
    rule("uptimeMinutes < 5 & post(#HC3_restart)") --  If less than 5 minutes uptime, assume that we restarted.
    2 hours ago, jgab said:
    @jgab
    1. Jan where should we place these functions definitions above for user defined properties? Right into Main function?
    2.  The keyppress event handling not fully clear to me.  I think simplifying this keypress handling is one of the most anticipated features in ER5. At least for me. So this is for me kinda magic solution. My customers are usin 12 button remote controllers , each button 3 different functionalites..errr...
    However, i don't know, should we wait for the version upgrade, and it will contain this feature kinda inbuilt, or we should use the syntax anyway from your example (below),
    So just define like this
     then use it like
    i mean wil there be any difference in usage in the new version, or we will use this anyway this way?
    1 hour ago, Neo Andersson said:
    @jgab
     then use it like
    Ok, I pushed v0.32 of ER5 now with :key
    If you know exactly key and attribute you use standard equal '==' e.g. 2 equal signs
    and :key returns a string so you compare against "2:heldDown"
    You can also pattern match against the string using '===' e.g. 3 equal signs
    matches any key attribute for key 2
    However, there is one more trick. You can further index :key with .id and .attr to get the values
    rule("1526:key === '2:.*' => log('Key %s and attribute %s', 1526:key.id, 1526:key.attr)")
    or we can do
    etc etc.
    or we can do
    etc etc.
    Can i change these rules to one rule?
    like...
    rule([[matrix_SiljeV:key == ???
    || 1:Pressed' => 1026:toggle")
    || 1:HeldDown' => {1026,1276,1275}:off")
    || 2:HeldDown' => {1026,1276,1275}:off")
    || '2:Pressed' => {1026,1276,1275}:on")
    Edited by ChristianSogaard
    Typo
    Jan, it seems that it doesn't work if device is a table..like
    then i have tried with single device, still doesn't work for me.
    How do you get this extended logging ?
    /monthly_2023_11/image.png.f2ef68516a0e327cd75f39949d316f98.png" />
    1 minute ago, Neo Andersson said:
    Thanz - sry for not being more accurate
    the "triggered" line with red arrow - i dont see them in my logd
    I did nothing just enabled both debug tag sa you see on my picture. Not only ER2648 that is the ER5 debug, but the QA debug itself. And this is my settings from ER5
         er.debug.ruleTrigger    = true -- log rules being triggered
            er.debug.ruleTrue       = true  -- log rules with condition succeeding
            er.debug.ruleFalse      = true  -- log rules with condition failing
            er.debug.ruleResult     = false -- log results of rules running
            er.debug.evalResult     = true  -- log results of evaluations
            er.debug.post           = true  -- log events being posted
            er.debug.sourceTrigger  = false  -- log incoming sourceTriggers
            er.debug.refreshEvents  = false  -- log incoming refreshEvents
            -- Global settings
            er.settings.marshall       = true          -- autoconvert globalVariables values to numbers, booleans, tables when accessed
            er.settings.systemLogTag   = "ER"..self.id -- log tag for ER system messages, defaults to __TAG
            --er.settings.systemLogTag  = nil
            er.settings.ignoreInvisibleChars = false   -- Check code for invisible characters (xC2xA0) before evaluating
            er.settings.truncLog       = 100           -- truncation of log output
            er.settings.truncStr       = 80            -- truncation of log strings
            -- Global settings
    Thank you
    i used the updater and downloaded a new version of ER5 and the manually updated my main, there was a lot of differences.
    like...
    You can do like
    Yes, it didn't work with tables - I pushed v0.33 and now it does.
    Actually this is/was a problem in ER4 too.
    The problem was when we had a table like {id1, id2, id3} and we want to apply a :property function that only worked on a single id.
    The intuitive solution is that we should only apply the :property function to the id that triggered the rule.
    To pick that id out from the list we need another :property function. In ER4 it was called :dID but in ER5 it is called :id and will always need to be followed by some other :property method
    The first :id will return the fob that triggered the rule and then we apply :key on that fob returning the relevant key pressed
    8 hours ago, ChristianSogaard said:
    Thank you
    Yes, main is still changing a bit... by Dec1 I hope main will be more stable.
    If I manage to release v1.0 by then I would recommend all to update their main manually...
    13 hours ago, Neo Andersson said:
    @jgab
    Yes you could. Or you could create a separate file u_myfuns
    where you setup your own stuff
    and then back in function QuickApp:main(er) you do
    SETUP(er)
    somewhere in the beginning - before you start to create rules.
    You can use this approach to have a separate u_file where you define your rules outside main()
    @ChristianSogaard does something like that with all his rules.
    The important is just to pass the variable 'er' from QuickApp:main(er) to the other functions and in those functions setup the rule function etc.
    The drawback is that they need to be global to be accessible from the main file. One can limit the number of globals by having one global table with the functions
    and in main() do
    However, I'm thinking of building something like this into ER5...
    Jan, i dont have version 0.33 in updater
    Just do a refresh
    1 minute ago, ChristianSogaard said:
    Just do a refresh
    ohh sorry, i forgot, thanks
    Even after upgrade to 0.33 i am getting error when using table
    /monthly_2023_11/image.png.53684a46537bd4a082498c8aefde3644.png" />
    Okay, it turned out that one of the devices in table doesn't exits anymore. That was the problem. I have no clue why, but it doesn't exist in my syste. Interesting..:-)
