This EV5 Alarm rule works perf.
My old EV4 rule was a little optimised compared with one above, it could tell what sensor in what room that was breached. And i could send that as a message the the Phone or to SONOS speaker.
I tried migrating the message part, but its not triviel to me, how to do in EV5?
I have a few questions how to replace some rules:
example 1 - I think env.p.m is not exist in ER5
example 2
example 3
    example 2
    example 3
    1. The matching variables becomes local variables for the rule
    2, Should work....?
    If LogUpdateToER is defined on QuickApp, e.g. function QuickApp:LogUpdateToER() you can do
    3.
    This still works as you do.
    If you have the triggerVar variable defined in the beginning of QuickApp:main(er) you can do
    @jgabJan, child support is not yey included to ER5? When i click on child switch i get this
    Edited by Neo Andersson
    Are you running v.034 ?
    0.33
    0.33
    Okay, my bad...Sorry
    I have changed a bit QA layout but after upgrade via Updater it disapears :(
    @jgab I think it could be useful for others also
    Edited by petrkl12
    After update there is some bug i think
    /monthly_2023_11/image.png.52b6de5cfdf74e89f4d88f735f46ff1f.png" />
    I don't have the symbol 'bfxqctph' in the project - not even on my computer - sure it's not in your code?
    Yes, the updater updates the UI too.
    Don't know to do additional user defined elements yet.... need to think about that.
    Something like the last update thing is coming with a list of the last 10 rules that has been run and time
    I reloaded my previous QA running on 0.33..there is not any error
    If you check the picture what i posted, you see, that ER5 doesnt even show the version number
    i will try again
    i will try again
    Now it seems okay. Strange..I didnt touch my QA
    /monthly_2023_11/image.png.76517d27053770dd19701243137436ad.png" />
    Jan, in debug window there are still showing up nonexistent ER debug tags
    I tried closing browser, reopening Fibaro...
    /monthly_2023_11/image.png.f8087a0945d561baea82b76634659825.png" />
    Can't you design your rules so it doesn't matter if you get 2 released?
    The problem is that if you push the button nothing happends only release in history and false in debug.
    I never noticed that because the HUE dimmer operates directly to HUE bridge.
    I will use scene for this task, no problem.
    Hue switch
    first press>> on
    second press change in brightness
    third press nothing?
    Thanks for your support
    Yes, not ER specific.  it's Fibaro that probably hangs on to the tags as long as they keep the history, eventually they go away...
    Hue switch
    first press>> on
    You mean a Hue scene? Because I guess that in a Fibaro scene you will have the same problem.
    HC3 scene looks to work better. Will check later to implement in ER5. WAF works and thats the main issue.
    If it does't work perhaps I need to buy a real switch.
    If it works in a HC3 scene it should work in ER - let me know how it goes.
    Jan, how can i access HT table insisde a rule?
    I have a function that loops throught all the HT table elements and checks devices. But this throws error.
    Complains about that nil is passed to my function.  Should i make HT table global? I dont now how will it affect ER in general
    var.HT = HT
    declares 'HT' as a eventrunner variable, accessible in you rule above.
    No special effect on ER...
    Usually, people like to declare the first keys of a HT as event runner variables
    Ex.
    and one wants 'kitchen' and 'bedroom' as event runner variables.
    But then one just loops the first level of the HT
    or use er.defvars(HT)
    15 minutes ago, jgab said:
    var.HT = HT
    Ex.
    Jan i just dont get it, i tried to run the function without a rule, but still the same
    HT is still nil when passed to my function
    This is how i load my stuff..
    My functions are loaded before the rules
    var.HT = HT didnt help
    When I json.encode HT table (right after the table end) and print it out, it gets printed, but when I use it as my function argument, then its nil.
    Where is shs declared? and how is  shs.checkAllDeivicesInTable(HT) defined? Is shs local or global and in what file is it declared?
    So,  shs.checkAllDeivicesInTable(HT) outside a rule works like in the example above but
    rule("shs.checkAllDeivicesInTable(HT)") fails?
    shs is declared as a global variable in a separate file (u_shsExtra) where all my functions are defined.
    shs.checkAllDeivicesInTable(HT) doesnt work. Neither inside a rule nor outside. I called it for test right after the HT table definition and it still claims that HT is nil.
    It is like my functions are loaded/defined before HT table is created, but this is not true see below my Main file, and rules are loaded in u_myRules file,
