@jgab
Jan i have another issue..This line used to work on my all installations
@jgab
Jan i figured out that variable office_controller_lastPressed can not be accessed inside the rule..that's why it doesn;t work, but this was working so far
Edited by Neo Andersson
Jan whats wrong? Test 5 result is gordijn_toestemming=false but triggers are true
I checked there are no other rulesor checks  with gordijntoestemming=false
I opend and closed window/ door to update again their status
    15 hours ago, Neo Andersson said:
    @jgab
    @jgab
    So, where do you update office_controller_lastPressed ? When the rule tries to do the subtraction it says that the value of office_controller_lastPressed is a boolean.
    So have a ook in other places you assign something to office_contrioller_lastPressed.
    If I add this it works for me
    office_controller_lastPressed = os.time()
    Im trying to create a Rule that triggers when a count of minimum 4 breached from a PIR sensor within max two minutes.
    To "measure"  that someone is staying at a room, and not just passing.
    Something like this
    rule("236:Breached & BreachedCounter >= 4 & @Now < (2 minutes since first breached of the last 4 breached) => Heater:on ; Reset BreachedCounter
    rule("236:Breached => BreachedCounter = BreachedCounter+1
    Getting the time from the last trigger of these 8 can gathered from the History. But is not trivi to get the oldest timestamp
     => api.get("/events/history?from=@now-120&objectType=device&objectId=236 (Then i need to count events, should be more than 4) actually it need to be 8, because the output is not separating Breached & Safe
     => api.get("/events/history?objectType=device&objectId=236&numberOfRecords=8 (then i need to check last event is les then 120 sec old.) actually it need to be 8, because the output is not separating Breached & Safe
    Will return eight almost identical data sets, were I need to check the oldest timestamp should not be older than @Now-120
    What is a good way of creating a Rule that triggers when a count of minimum 4 breached from a PIR sensor within max two minutes. ?
    So, if you run rule("test5=true") to test your check, it doesn't mean that the first  rule run and set gordijn_toestemming=true.
    Change the last rule to
    to verify.
    I would suggest you add a .start() to the first two rules so they always run and update gordijn_toestemming to the correct value.
    16 hours ago, Neo Andersson said:
    @jgab
    @jgab
    Do you declare it local ?
    locally declared lua variables have never been accessible in ER rules.
    17 hours ago, Neo Andersson said:
    @jgabJan how can i access a nested table value in a rule?
    1.
    2.
    I cant wrap into one line nested II >> calls
    I have tried several ways..using {} for nested ||>, using ;;...ehhhh
    This works now?
    25 minutes ago, jgab said:
    This works now?
    Jan, yes this works, but i still dont know how to do nested ||>> statements. I have tried many many combinations
    EX how to formulate this
    or should I aviod using ||>> when the code is more complex?
    Something like this
    You need some "sliding window" to keep the last 4 values. Usually one does that with a table but it's a bit clunky in ER (reminds me I should improve table handling in ER).
    Anyway, you can implement that window with 4 variables
    Here I replace you sensor with a keypress to test (bct1 stands for breached counter time 1...)
    of course, if you looking for 10 presses within x time this becomes clunky...
    then you make a queue data type that you can use . here called windows, that has a set size
    I think a way more convinient way is to set this in parameters of PIR sensor. Almost all PIR sensor do have this feature.
    /monthly_2023_11/image.png.fc03b21e0ba4bf32cf2cbb405d61a702.png" />
    Thank you for sharing - i was looking at this also. But i need the "normal" breached and this extended at the same time.
    Yes,||>> is just a more convenient way to write if-then-elseif.....elseif...else end.
    When it becomes nested it doesn't work so well, as there is no way to tell the difference between '||' on top-level and '||' in a subexpression....
    if-then-elseif... you can nest to any levels...
    But, of course there was a bug in the code which prevented ||>> to be nested in anything else,
    ...so I pushed v0.52 where you can do either
    if test1 then
       || test2 >> dosomething2
       || test3 >> dosomething3
    or not so elegant
    || test1 >>
    I will try to come up with a proper case expression, something like
    rule([[key fob:key =>
           case fob:key of
              '1:pressed' : <statements>
              default:        <statements>
    but haven't decided yet for the syntax...
    On 11/29/2023 at 2:56 PM, ChristianSogaard said:
    Rules:
    Did you get a solution?
    I'm trying my best and I can't reproduce the problem.
    2:tryArm is implemented as a api call  api.post("/alarms/v1/partitions/"..id.."/actions/tryArm") - so it's kind of Fibaro that handles it ....
    and shouldn't have any side effect. Unless of course you have some rules that trigger and start to arm the whole house - but it doesn't look like that, looking at your rules...
    Could you disable your alarm rules and just try
    rule("2:tryArm") and see if it still causes the other partitions to arm?
    Do all your partitions share common devices? That's the only difference I can think of is that I have unique devices in each partition - however it would be interesting of overlapping devices cause this "side-effect"....
    I re-entered the rule, and now im getting this when triggered
    I also deleted all my Alarm rules in EV4 - but i didnt see any overlapping issues
    rule([[#Key951_2_Pressed2_4_Pressed2 =>
     || 0:armed >> 0:armed=false;   log('#Disarmed from Matrix as Keypad')
     || !1:armed >> 1:tryArm ; log('#Try to Arm the house from Matrix as Keypad')
    2 and 1:tryArm is not working (Above error)
    0:tryArm is working
    Edited by ChristianSogaard
    Typo
    Perhaps it will help?
    I did't use tryArm because it gave some difficulties at the beginning and regret I can't remeber why.
    partiton zero I also don't use because it messed in ER4 my alarm up, there I had 4 partitions. Now in Alarm my lowesst ID = 1
    I use 2 main arm partitons and 2 for guests
    if I activate tryArm partition 1 or partiton 2 in both cases it arm my appartment
    if I use common devices it will also both arm the partitions
    Update...
    I created these rules
    They actually arms the right partitions
    but im getting errors when triggered...
    [02.12.2023] [09:44:15] [ERROR] [ER2047]: [Rule:4:2]>> [Rule:4:951:key == '2:Pressed' => 2:tryArm] Runtime: ./include/fibLib.lua:191: attempt to get length of a nil value (field 'breachedDevices') prop
    3 minutes ago, ChristianSogaard said:
    Update...
    Ok,  good we have an error :-) will check it later today. ,
    Ok, there was a bug in tryArm if there were no devices breached.
    I've pushed v0.54 with a fix.
    Thank You Jan :-)
    Jan - simple one, thought this was working but getting an error.
    This is an example from your interval rules post
    rule("@{10:00,15:00} => log('It is 10:00 or 15:00')")
    Last err: [Rule:38:@{10:00,15:00} => log('It is 10:00 or 15:00')] Rule: Invalid daily time: table: 0xaaaae2595b10
    Sorry, it was a bug that snuck into one of the last versions.
    I pushed 0.56 with a fix and added your name to the official bug hunters :-)
