21 minutes ago, Neo Andersson said:
@Neo AnderssonJust for inspiration
I set the HTTab from a Scene - and when run, its added to a global variable,
                Motion      = {1122},
        guidelight = {
                Windows     = {35, 1002},
                Doors       = {33, 1000},
                alarm       = {155,1182},
fibaro.setGlobalVariable("HTab",json.encode(HTab))
fibaro.debug(tag,json.encode(HTab))$
And read it in main like this.
    local HT = json.decode((fibaro.getGlobalVariable("HTab")))
    er.defvars(HT)
    er.reverseMapDef(HT)
I also have a rule - detecting if the global var has been updated
so every time my scene is updated and saved, Eventtunner, restarts with the new variables
Edited by ChristianSogaard
Typo
22 minutes ago, Neo Andersson said:
Jan, i also noticed a bit strange starting time. In ER4, that is still running on my customers's systems, when I made a change and saved the ER4, in debug window i could see immediatelly all the setup stuff, and definitions debugged.
In ER5 after a save, I see the orange bar immediatelly, but after that it takes around 6 second while i see the first rule definitions debugged.
    Yes, there is some unoptimised code that calls api.get("/devices") twice at startup - If you have many devices it can take some time - but 6s is long are you doing other http/api calls in your setup?. (it will be optimised in next version and will read devices on-demand instead)
    Is 6s also the time reported in the second orange bar?, "Rules setup time - reported under ER<ID> tag in console ? (it's a bug, should be under user tag like the first bar)
    Hi, I am trying to use a s2 input from a Heatit zm dimmer:
    When I use a Dimmer 2 with scene id 20 it works greath.
    But as I see in when using it in scenes it is diffrent from the Dimmer 2:
          id = 1648,
          isTrigger = true,
          operator = "==",
          property = "centralSceneEvent",
          type = "device",
          value = {
            keyAttribute = "Released",
            keyId = 2                    --Heatit Dimmer
          id = 36,
          isTrigger = true,
          operator = "==",
          property = "sceneActivationEvent",
          type = "device",
          value = 20         --Dimmer 2
      operator = "any"
    rule("dimmer2S2:scene == 20 => PirHeatit:on")
     rule("dimmer2S2:scene == 21 => PirHeatit:off")
    This rule work with dimmer 2.
    But I cant figure out how to use the Released and key id 2 in a rule?
    any suggestions? :D
          id = 1648,
          isTrigger = true,
          operator = "==",
          type = "device",
          value = {
          id = 36,
          isTrigger = true,
          operator = "==",
          type = "device",
      operator = "any"
    any suggestions? :D
    See this post
    v0.35 pushed - bug fixes and some optimisations...
    Jan how to write?
    No, in the second orange bar it shows very fast..0.38ms, however, the second orange bar appears after 6 sec. It doesn't bother me, i just want to help you to find any hiding bugs or wathever..
    BTW, regarding my previous problems about HT table not accessable as an argument...After several tests i can confirm. Whatever i do, wherever i define my custome function, if i want to send HT table as an argument to my custom function it will be always nil. On the other hand, if i use HT table direclty inside my custome function, then it works.
    20 hours ago, ChristianSogaard said:
    This EV5 Alarm rule works perf.
    My old EV4 rule was a little optimised compared with one above, it could tell what sensor in what room that was breached. And i could send that as a message the the Phone or to SONOS speaker.
    I tried migrating the message part, but its not triviel to me, how to do in EV5?
    Jan - would it be possible that you convert this rule for me?  - i have 3-4 rules like this. And when converted, i can decomission EV4 - and run full on EV5..
    The time reported is os.clock(), which is the cpu time used.
    This means that 6.0 - 0.38ms is spent hanging in api calls (you don't do any fibaro.sleep() do you?).
    Have you tried v0.35 where I removed the api.get("/devices") at startup that probably takes some time if there are a lot of devices...?
    No i dont do any sleep / i didn't even know that sleep function still exists :-)
    No i haven't tried 0.35. will try today
    Try this
    We ignore the partition id's and just collect all breached devices in the table 'devs'.
    We then iterate overt he deviceIds and create info about them (id, name, room)
    and lastly we concatenate it all together.
    Now it just logs (warning) the message 'msg' - you can send the string as a msg to a user also.
    Note, that you may need to change the html break to a "\n" character for it to break in a push message.
    It needs v0.35 because I added table.append() to that version.
    2 hours ago, Sjakie said:
    Jan how to write?
    If summer_daytime is not a triggerVar you can  do
    If summer_daytime is a triggerVar you can't assign it a value on the left side of the '=>', but you can use a temp and do
    The reason why we still want the interval sunrine+00:30..sunset-00:30 on the left side is that we want the rule to trigger on those intervals.
    Don't forget to add .start() so it is set at startup/restart.
    3 hours ago, jgab said:
    Try this
    Thank you Jan
    Almost there :-)
    I need to filter out doublets - in below case there is 3 alarm zones -  and i get messages from both Partition 1+2  because they have overlapping sensors.
    Typo
    @ChristianSogaardsplit in alarmzone X in your case 1,2,3 than automaticaly you get only that partition
    How to pass the year?
    Edited by Sjakie
    Jan, hello
    Is there any change in ||>> pattern?
    Jan, hello
    ||>> is a chained if-then-elseif, so it looks for the first condition that is true and skips the rest. if senzor1:breached then it will skip all the other tests, and do the log after ;;
    You want to so something like?
    Alt. (and much faster)
    38 minutes ago, jgab said:
    Jan we tried this, as i wrote you. This doesnt work. Throws error.
    Parser: missing first argument for ; ||
    Edited by Neo Andersson
    Jan, please, i am struggling like a day with  getting a linebreak into a push message text.
    This never works
    This always prints out \n as a regual string.
    But  this works
    This never works
    But  this works
    pushed v0.36
    Ok, the ';;' was a bug - I thought I fixed that weeks ago but somehow it was reverted to the old code... Now it should work.
    The newline I can't see whats' wrong. Strange that it works in rule("....=> text1 ++ '\n' ++ text2") but not the with the simplePush...
    I will try to look into it...
