Converting ER4>EV5
Works in Ev4 but not in EV5
[23.11.2023] [17:48:20] [ERROR] [QUICKAPP1961]: Last err: [Rule:57:trueFor(00:04:00,Flisegang:safe & entre.FliseAutoORManuelt) => 1184:off; entre..] Rule: nil is not a valid device trueFor(00:04:00,Flisegang:safe & entre.FliseAutoORManuelt) => 1184:off; entre.FliseAutoORManuelt=false ^
Works in EV5
is this by design or me messing up ?
Jan sorry wrong statement
Edited by Sjakie
    1 hour ago, ChristianSogaard said:
    I tried on version 0.300 - and i get no trigger -uptimeMinutes
    It's not a trigger, just a predefined variable. Just check the value at upstart and log/do something. Like in my previous example.
    Hi Jan
    How do i do Util.defTriggerVar - in ER5
    It er.defTriggerVar(...) or Util.defTriggerVar(...) if you have the standard main() function that declares
    Util (similar like the 'var' discussion we had).
    There is also a 'triggerVar' variable defined the same way as 'var' to declare triggerVariables.
    Ex
    triggerVar.SiemensCookTop = 0
    If you have your own local mains in modules you need to set the variables up yourself...
    Ex
    Got it - that part is running now
    [QUICKAPP1961]: Last err: [Rule:21:#device{id=extractor_hood,value='$value'} => || value < 10 & value > 0 >> extr..] Parser: bad expression || value < 500 & value > 225 >> extractor_step=4; extractor_light = 1 ^
    I removed the last ; in each line
    I was a litte unsure for the last "log('%s %s',extractor_step,extractor_light)"  normal the libefore would have ;; but i removed both
    All variables should be declared, so what is the Parser: bad expression about
    i dont want to say something stupid, so forgive me if i am wrong, but i learnt from Jan in some of my toipcs that separating the || >> part from other statements should be done by ;; So before the log( ) part you need to put a double ; i think
    Sorry if i am wrong
    Edited by Neo Andersson
    Sorry if i am wrong
    Yes correct, it should be
    @Neo Andersson, maybe it's time to move to ER5? ;-)
    If you don't have ;; it does't give error
    @jgab is it safe to move in production? I mean i have dozens of systems running with ER4. Somewhere more than 150 rules.
    If so, what is the best way to upgrade? Just copy paste rules into ER5 Main function?
    If you ask me it's reliable to use!! I am on ER5 since the first release and arming halfway.
    I had QA's with over 500 rules what is't a problem at all. They are reduced now in our new appartment
    If you doubt you can test;
    create back-up
    copy and past all your excisting QA's in one,
    delete all others,
    see the result it's amazing it will still work.
    The compliments to Jan!
    ps working with colors in debug is easy and it can help you with a fast check of your triggers or execution
    Edited by Sjakie
    add color
    [24.11.2023] [08:23:38] [TRACE] [QUICKAPP1062]: media.wcd_SubWoofer = Uit[24.11.2023] [08:23:38] [TRACE] [QUICKAPP1062]: tv_aan=false[24.11.2023] [08:27:29] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Uit[24.11.2023] [08:27:29] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Uit met als gevolg 1[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: keuken.Bovenkastrechts = Uit[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Syncbox_Uit = 2[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Lezen_Uit = 00:00:02[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Kunst_Uit = 00:00:03[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_TV_Uit = 00:00:04[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Woonkamer_Salonlampen_Uit = 00:00:05[24.11.2023] [08:27:30] [TRACE] [QUICKAPP1062]: #licht_Eethoek_Uit = 00:00:10
    create back-up
    delete all others,
    Thanks Sjakie
    Okay, i have transposed my home system to ER5
    I ran into errors around these rules.
    First error complaining about nonexistent diarmed property. I suppose in ER5 there is different approach.
    The second does not give me any sense, as it is complaining about miising >> operand byt it is there
    UPDATE:
    Okay, first error i solved by using
    and the second by reformatting the rule to
     CASE sloved
    11 minutes ago, Neo Andersson said:
    UPDATE:
    Okay, first error i solved by using house_alarm_sirene:armed == false
     CASE sloved
    Ok, this will be interesting :-) Keep us posted how it goes. There are some small changes to the "language" - mostly I would say missing stuff - that I would like to keep out from ER5 (there were always 4 different ways to accomplish the same thing in ER4).
    I'm thinking of some module model for extra stuff to ER5 - ex. the child device support - very few use it and I'm unsure it motivates to be a standard part of ER5.
    I think where ER5 differs most is the rule management and life-cycle. Much more options to tailor logs and outputs - and hopefully better error messages. I haven't documented it all yet. However, I'm open to implement stuff you need and that I haven't carried over from ER4...
    There is also the possibility to create user defined :property functions - I'm not sure how useful that is, but if I have forgotten something, users can add.
    ... and a lot more stuff....
    How to set up user defined properties with :
    I couldn't find any description. I think it is very usefull.
    Also, i think child support is very usefull.
    Like this
    So, if you want custom color for the log output I think it's better to use the rule options than to add #C: directive to the rule.
    The rule function takes the "rule string" but also an optional options argument.
    Ex.
    This will log the text in green for this "rule".
    In fact, it's not a real rule, just an expression that we run to log, so we are not really interested in that the rule call returns the result and logs that - which is the string ''This is a test"
    We can make the rule function quite by telling it to not log the evaluated result
    Now, this will only log the text in green in the console.
    The options table is a bit long to send to "log rule" so we can create a couple of predefined options tables and reuse them
    and we can define our own versions of the rule functions using these options
    etc.
    Like this
    Ok, I can add child support in next version.
    No, the user defined :props are not documented yet - this weekend.
    @jgab Jan we also had a conversation about the better trace of timers in trueFor.
    Somehow, i need to get the information about a trueFor rule's timer. Where is the counting at a moment. ex how much seconds remains to the trigger..Like in case of delayed opening of a door, i can show the remaining seconds to the user..is that too complicated?
    And also we tlaked about action calls where the state should be chceked first and not performed any operation if the desired state is already present. Now i am using for it my own function that actuially follows this logic ... => device:isOff & device:on
    Sorry, one more thing
    using push and simplePush somehow..i think at this moment only push is working..notifications for devices doesn't have support even in ER4..maybe i am wrong
    Reason for the post, is that i am moving to ER5 ;-) you can see that i removed the ; in || each
    line
    Edited by ChristianSogaard
    Typo
    Jan, can you take in consideration
    standard devieces isOn yellow, isOf lighter or darker form of yellow
    device trigger=true green, device trigger=false lightgreen
    $GV set pink,
    $$QA gv>> violet
    Perhaps as custom setting?
    Thanks in advance
    line
    I am a bit confused now..
    I think || >> lines never needed any ; in ER4
    Only after the whole ||>> part is finished, and you needed to add some other statements after, there you needed the ;; to mark the end of the ||>> part
    Did this change in ER5 to some other pttern? I doubt,because my ER5 based home system never complained about this
